Has anyone successfully used gold wire to wirebond to an immersion silver PCB surface finish? I'd like to know of anyones experience with this or any long-term issues with current immersion silver finishes (MacDermid "Sterling" for ex.)? The reason I'm asking is that a PCB I'm working on needs to be both wire-bondable & solderable. A common metal or alloy for the pads would be best, but these components are only available with certain pad coatings (few options, the parts are ~ 0201 size). Gold & aluminum pads and standard SMT components with a nickel/lead/tin finish will be used on the board. I've searched the web over, and immersion silver seems to be recommended for aluminum wire-bonding but not for gold. There's a bit of anecdotal evidence that gold WB/silver immersion finishes work well, but I haven't come across any definitive studies. I've done some experiments wire-bonding gold wire to silver immersion PCB pads, and the results (pull-test & visual quality of the joint) seem to equal gold-to-gold (ENIG) bonding, but long-term reliability is a concern.
A gold surface finish (ENIG or soft gold) is usually recommended for this kind of PCB, it would be a plus in production to use a lower cost, standard surface finish that is both wire-bondable and solderable. Immersion tin & OSPs are not suitable for wirebonding. Thanks for any help. - CAL
