what am I doin' wrong?
gerty
I've pulled out what's left of my hair, the goal is to generate a tone for a pa system . What I have is a 24-7 time clock, the contacts close for 1 minute minimum, and I need to cycle a tone for about 2 seconds. A simple task for a pic you say!! Well I've got the tone, but cannot figure how to make it cycle. what I'm using is a MikroE Easy PIC4 developement board and I used a sample program form them (basic). The sample had several tones,I only needed one, so I removed the rest. What it does:upon programming the tone sounds for 2 seconds and stops (good so far) when I press the button for input at porta.0 ,nothing happens. If I press the reset (mclr) button, it sounds for 2 seconds.
This is my first foray into programming, except for the old allen bradley PLC-2.
Here's the code,can someone help?
  • chimes.txt
program Chimes
sub procedure Tone1
  Sound_Play(130, 6200)
end sub
sub procedure Melody
  Tone1
end sub
main:
  TRISA = 1
  Sound_Init(PORTB,2)   ' Initialize sound engine
  IF PORTA.0 = 1 THEN        '   if input at porta.0 goes high
  PORTB.2 = true              ' output at portb.2 turns on
     END IF
  DELAY_MS(2000)           'play for 2 seconds
   Melody                ' Play the chimes
end.
How about instead of PORTB.2 = true
TRISB.2 = 0
PORTB.2 = 1
also when you press the button what do you want to happen? All its going to do is set the PORTB.2 to output.
Also dont you need a endless loop?
example:
program Chimes
sub procedure Tone1
end sub
  Tone1
end sub
main:
  TRISA = 1
  TRISB.2 = 0
  PORTB.2 = 1              ' output at portb.2 turns on
     END IF
   goto main
end.
or
program Chimes
sub procedure Tone1
end sub
  Tone1
end sub
main:
  TRISA = 1
  TRISB.2 = 0
e_loop:
     END IF
   goto e_loop
end.
I tried both of them..no effect.
How do you post the code like that?
Yes I need it to loop for 2 seconds.I would like it to put out a tone (2 sec) when button pressed.
the # button or use the [ code ] [/ code] syntax
Refresh the page and check new code. I need to see the rest of the code to help ya out. How are you sending a tone to begin with?
Try this:
program Chimes
sub procedure Tone1
end sub
  Tone1
end sub
main:
  TRISA = 1
  TRISB.2 = 0
e_loop:
    PORTB.2 = 0              ' output at portb.2 turns on
  END IF
   goto e_loop
end.
That is all the code. clock speed is 8 mhz. Like I said I used an example program from mikroe and removed 4 extra tones I didn't want. I'm just now trying to get this programmed, so there isn't a schematic. If you're not famalliar the developement board has a pushbutton for every input and a led for every output (when programmed as such) . there is a header to connect to the 'real world' and I've got a amp/speaker connected see attached:
I don't know what the code is supposed to look like (herein lies the problem!).
almost forgot! tried changes and tone cycles on/off every 2 seconds,all by itself
Put JP17 to GND and try the code again if doesnt work try JP17 to VCC and use
program Chimes
sub procedure Tone1
end sub
  Tone1
end sub
main:
  TRISA = 1
  TRISB.2 = 0
e_loop:
  IF PORTA.0 = 0 THEN        '   if input at porta.0 goes high
  END IF
   goto e_loop
end.
in there code they check a button like:
    if Button(PORTB,2,1,1)=true then          ' RB2 plays Melody
      Melody()
    end if
so try :
program Chimes
sub procedure Tone1
end sub
  Tone1
end sub
main:
  TRISA = 1
  TRISB.2 = 0
e_loop:
    if Button(PORTA,0,1,1)=true then       '   if input at porta.0 goes high
  END IF
   goto e_loop
end.
Philba: watchdog is off
Atomsoft: tried new code and now it doesn't do a thing. Here is the original code from Mikroe that I modified. Did I do/not do something really stupid?
' Project: Sound
' This project is a simple demonstration of how to
' use sound library for playing tones on a piezo speaker.
' The code can be used with any MCU that has PORTB.
program Chimes
sub procedure Tone1
  Sound_Play(70, 150)
end sub
sub procedure Tone2
  Sound_Play(60, 150)
end sub
sub procedure Tone3
  Sound_Play(50, 200)
end sub
  Tone1
  Tone2
  Tone3
end sub
main:
end.
Make sure its pull up meaning when nothing is pressed its at a logical 1 and when press it jumps to 0v.
program Chimes
sub procedure Tone1
  Sound_Play(130, 6200)     ' The 6200 controls the tone length
end sub
  Tone1
end sub
main:
  TRISA = 0xFF
e_loop:
  IF PORTA.0 = 0 THEN        '   if input at porta.0 goes low
    DELAY_MS(2000)           'This just delays 2 seconds not play
  END IF
   goto e_loop
end.
Pullup is working (10K) and when button pressed it goes low. Still no tone, I can see I have a lot to learn. The terminology is killing me more than anything. I'll try more in the morning.
Thanks a lot for all your help, really appreciated.
