DaveInDurban
I need to make something to annoy monkeys - I'm in Durban, South Africa - and I understand that they do not like ultrasonic noise. If I take a basic noise generating circuit (e.g. reverse biased base-emitter of an npn transistor, or zener diode, amplified with a single transistor amplifier), and simply feed it thru an RC high pass filter to a cheap 8 ohm tweeter, will it generate enough noise between say 20kHz and 40kHz? I don't know the frequency range of the reverse-biased junction.
I can go ahead and try it, but I don't have an oscilloscope, so I can't check that it is producing a signal, and I won't be able to hear it if it does. I think there are commercial noise makers to chase away dogs, so hopefully there is a circuit that is known to work.
This is meant to be part of an automated garden watering/monitoring system: I am adding motion detectors and the monkey deterrent to keep monkeys out of the garden.
