typecast and bit shift
TucsonDon
C:
uint8_t data[4];
uint32_t time;
time = (uint32_t) ((data[0] << 24) | (data[1] << 16) | (data[2] << 8) | data[3]);
I want to shift the array into 32 byte variable, but all I get is data[0] at LSB. How do I typecast and shift?
You could put both types in a union, so the bytes in the int32 are individually accessible.
Or this may work (without verifying the syntax):
time = *(uint32 *) data;
But be wary of byte order..
You were left shifting a byte variable multiple bytes wider that
its type before you cast it into a 32 bit variable.
Cast the byte variable then do the shift and OR ?
Not a C expert here, still a novice.....:)
Regards, Dana.
rjenkinsgb time = *(uint32 *) data worked I just had to change the way that the data is loaded into the array (in reverse)
