total newbie to pic and i need some help!!
dilly_dally
I need to count the number of objects passing a sensor on a conveyor system and display them (the count that is).
I would also like to add a check to ensure that a object does in fact exist on the conveyor and its not a spike.
Using a 16f84 chip.
I've read a few articles but am just as confused as when i started.
Any help gratefully received
thanks
wiz
Using a 16f84 chip.
A good way to count would be to use an IR beam, suitably modulated you shouldn't get any errors or spikes, and you could always use two beams - where both beams need to break to show an object has passed.
The 16F84 is pretty well obselete, the 16F628 replaced it a good while ago, it's pin compatible, cheaper, and has a higher spec.
