Hi all,
I need some help...I'd like to build a circuit that will simply toggle between two outputs when power is applied to an input. That is, the first time power is applied, light A should turn on, then turn off when power is removed from the input. The second time power is applied, light B should turn on, then turn off when power is removed. The third time power is applied, light A comes on again, and so on.
Is there any digital or analog circuit that will do this? Simplicity is key, but I'll try just about anything once.
Thanks,
Jack
Thanks,
Jack
