TIL81
praevaleo
I'm looking for the datasheet of a photodiode - TIL81, I cant really find it on the search engines. Can someone help? Thanks.
It's pretty old... Just scanned from my old TI catalog '83.
I have a 1976 TI data book that lists the specs, I have no way to scan the pages for you. Here is the maximum ratings, It NPN planar silicon phototransistor.
Collector -Base Voltage 50V
Collector-Emitter Voltage 30V
Emitter-Base Voltage 7V
Emitter-Collector Voltage 7V
Continous Collector Current 50mA
Continous Devie Dissipation at 25 degrees 250mW
Hfe typical when VCE=5V IC=1mA
If you need any other specs let me know
Another one, but not much more info. But they do list it as being used as a photo-diode or a photo-transistor.
Ken
  • TIL81.pdf
Results 1 - 10 of about 20,300 for TIL81. (0.22 seconds) on a google search:confused:
I have a faded 6-page data sheet, but the questions need to be less vague than simply
Working of til-81
, especially a first and only post.
I'll try to answer the most common questions:
Peak sensitivity 940 nm, skirts to near zero around 500 and 1100 nm, 50% points around 740 and 990.
With 100 ohm load, switching time as photodiode typ 500 ns, as phototransistor typ 8 us.
Angular sensitivity about +/- 10 degrees.
At 10 mW/cm^2, as photodiode, light current is typ 170 µA
At 5 mW/cm^2, as phototransistor with VCE=5V, typ 22 mA.
