Thyristors,SCR,Diac,Triac,UJT theory
walters
Banned
What are Thyristors,SCR,Diac,Triac,UJT used for?
How do i use a Thyristor?
How do i use a SCR?
How do i use a Diac?
How do i use a Triac?
How do i use a UJT?
What type or circuits use them ?
What kind of Applications can i use these components for?
I don't use these components much because i don't know how to use them or what they do can u guys please help me out with these components
I'm not certain about the the others, but SCRs and Triacs both fall under the Thyristor category. The SCR (Silicon-Controlled Rectifier) is a 3-terminal device that is effectivly a diode that won't conduct a forward current until a current enters the gate terminal. After that, the SCR continues to conduct even after the gate current has been removed. It's not to be confused with a transistor because it only operates on an on/off basis. This is to say it can't truely amplify.
A triac is essentially two SCRs paralleled with on another, except they're back-to-back so that it can conduct current in either direction once the gate current arrives.
Looking at The First Google Result for "Thyristor" that came up, I found a more detailed description of them. If anyone can describe them in a little more detail, I'm interested because SCRs and Triacs aren't really discussed a lot in the EE courses.
Thanks for the help
most of theses components have a GATE or Trigger input
Whats the difference between the Gate VS the trigger?
These components won't conduct unless a voltage or pulse is at the Gate or trigger input mostly
walters said:
Thanks for the help
A trigger is a signal (imagine it as a binary gate, either open or off), when given turns on the device,and the device will not turn off until some other condition(depends on the device) occurs.Once triggered . the subsequent trigger has no control over the current . read the working of the device for more details
A gate on the otherhand can control the current flow thru the device.
Thanks for the help
make the current flowing thru the device below 'holding current'
How is this done?
How do i make the device "holding current" ? how is this done?
Dear GOD, Walters getting into Power electronics!!!!
My nightmear has come true
styx
I don't understand about diac and triac
The diac can "Conduct current" in either direction its bidirectional
The Triac has a GATE
What are they both used for i don't get they are used for
The Triac and FET/UJT both has gates. does they function similar ?
The GATE resistance is different i think so the current controlled is different
what is described as the breakover voltage of a diac?
when reverse voltage before the diac breaks down
Ans incomplete/wrong . The question was not what "u think".
Are u shure it is the "reverse" voltage reqd to breakdown,if yes what is the difference b/w diac and zener ?.Does a diac has forward breakdown voltage?
Why does a diac have no trigger to conduct ?
Sorry i don't know
The voltage drop before it breaksdown i guess
Does a diac has forward breakdown voltage? yes it does
Why does a diac have no trigger to conduct ? because its bi directional
but i don't know why
or whats its used for
sorta of i mean what do they do different than regular components?
Do they do something different to the current/phase/voltage?
I'm not sure what they do really ?
