The nominal HV programming voltage (Vpp) is not always 13 Volt
ljcox
I recently discovered - by looking at some of the files in the MPLAB IDE Device folder (see Program Files (x86)\Microchip\MPLAB IDE\Device) - that the nominal programming voltage (Vpp) is not always 13 Volt. Some examples (taken from the respective .dev files) are shown below - note that the PIC 16F684 is 11 Volt nominal with a maximum of 12 Volt!
PIC16F84
vpp (range=12.000-14.000 dflt=13.000)
PIC16F88
vpp (range=12.500-13.500 dflt=13.000)
PIC12F675
vpp (range=12.750-13.250 dflt=13.000)
PIC16F684
vpp (range=10.000-12.000 dflt=11.000)
PIC16F917
All of the PIC programming hardware I have seen are designed to apply about 13 Volt. So I don’t know what would happen if one of these was used to programme a 16F684 or a 16F917.
I recently purchased three 16F684 PICs so I intend to modify my programmer so I can switch it between a 11 and 13 Volt using a jumper shunt.
One of the programmers I constructed is the dSPIC/PIC Programmer published by Silicon Chip in their May 2008 issue. This one will be easy to modify so I will do it in the new year and post the details in this forum.
The original Pickits 2 /3 have a PWM style VPP generator... This means they can generate the correct VPP for the chip chosen..... I wouldn't use any other programmer..... I my opinion, it costs nearly as much to make one as it is to buy one.. Every time I see this topic, someone has had a headache for some reason or another.... For less than £30 why go through the ordeal!!!
i remember that above 10.5V , it should work without any issues.the voltage depends on other factors like load on Vtarget and thereby on the Vusb
It cost me very little to make mine as I had most of the parts on hand.
I don't find it is a ordeal. All I need to do is add a jumper shunt & a resistor or 2 so I can alter the voltage from 13 to 11 when necessary.
Thanks for the responses.
Just supply 13.6v via a 10k resistor and each chip will take care of itself.
You need 13.6v for some chips.
It's the same pin but it has 2 functions.
MCLR -Master Clear, resets the chip when it goes low so if MCLR is enabled, it needs to be held high via a 10k resistor for the chip to work.
Vpp is the high voltage mentioned above that is used to initiate programming of the chip.
