Jamie Pocock
I was thinking of building something similar using a pile of old flashes to make a small ringflash for macro work. You might want to add the ability to shut off half the flash to provide some shadowing if your wife plans to use it at all for macro work. Are you using a bundt pan for the reflector? I havent gotten around to collecting all the parts yet, so I will watch your posts with interest. also remember you can connect smaller higher ohm resistors in parallel to make a higher wattage bridge. Caleb
bundt pan is indeed what I have use with a bicycle handle grip on a peace of copper water pipe to hold the flash, the rest of the unit including the camrea mount and a fibra glass back case is yet to be made.
