hi everybody .
here its is what i want to do exactly and wat i got .
i want to connect 4 pic16f84a to 1 pic18f4550 serially . and every pic16 send
its portb value to pic18 serially . then pic18 send the value to my pc usb . so i write the code for pic16 and test it on my pc serial port and its working fine and send the right value . what when connect to pic18 , pic18 send wrong values . here is my code and hope to find anything wrong ?
' pic16f84a code
include "modedefs.bas"
define osc 4
TRISB = %11111111 ' portb all input
PORTB = %00000000 ' portb 0
TX VAR PORTA.2 ' transmmit
B0 VAR BYTE ' var for store portb value
B1 VAR BYTE ' var for store portb value
start :
B0 = PORTB
PAUSE 100
B1 = PORTB
IF B1 = B0 THEN start
IF B1<> B0 THEN SEROUT TX,N9600,[B1]
B1 = B0
GOTO start
'pic18f4550 code
Include "modedefs.bas"
INCLUDE "DT_INTS-18.bas"
DEFINE OSC 20
PORTD = 0
TRISD = %11111111
ASM
INT_LIST macro
INT_Handler USB_INT, _DoUSBService, ASM, yes
endm
INT_CREATE
endasm
USBBufferSizeTX con 8
USBBufferSizeRX con 8
USBBufferCount Var Byte
USBBufferIn var byte[8]
USBBufferOut Var Byte[8]
DataToSend var byte[8]
RX VAR PORTD.1
VAR0 VAR BYTE
asm
SendUSB macro array
variable i=0
while i<8
MOVE?BB (array+i),(_USBBufferOut+i)
i+=1
endw
L?CALL _DoUSBOut
endm
endasm
SwHwInit:
GOSUB DoUSBinit:
Start:
serin rx,N9600,VAR0
datatosend[4] = VAR0
@ SendUSB _DataToSend
gosub dousbin
goto start
DoUSBIn:
@ INT_DISABLE USB_INT
USBBufferCount = USBBufferSizeRX
USBService
USBIn 1, USBBufferin, USBBufferCount, Timeout
Timeout:
@ INT_ENABLE USB_INT
return
DoUSBOut:
WaitPC:
USBBufferCount = USBBufferSizeTX
USBService
USBOut 1, USBBufferOut, USBBufferCount, Waitpc
return
usb_device_state var byte EXT
CONFIGURED_STATE CON EXT
DoUSBinit:
pause 500
usbinit
repeat
usbservice
until usb_device_state = CONFIGURED_STATE
return
DoUSBService:
usbservice
@ INT_RETURN
thanks , regards
' pic16f84a code
define osc 4
start :
B0 = PORTB
PAUSE 100
B1 = PORTB
B1 = B0
GOTO start
'pic18f4550 code
DEFINE OSC 20
PORTD = 0
TRISD = %11111111
ASM
INT_LIST macro
endm
INT_CREATE
endasm
RX VAR PORTD.1
VAR0 VAR BYTE
asm
SendUSB macro array
variable i=0
while i<8
i+=1
endw
L?CALL _DoUSBOut
endm
endasm
SwHwInit:
GOSUB DoUSBinit:
Start:
serin rx,N9600,VAR0
gosub dousbin
goto start
DoUSBIn:
USBService
Timeout:
return
DoUSBOut:
WaitPC:
USBService
return
DoUSBinit:
pause 500
usbinit
repeat
usbservice
return
DoUSBService:
usbservice
@ INT_RETURN
thanks , regards
