    Dismiss Notice
STM32F4-Discovery PDR_ON
Discussion in 'ARM' started by AtomSoft, Mar 6, 2012.
  1. AtomSoft
    AtomSoft Well-Known Member
    Feb 7, 2008
    5,670
    41
    Brooklyn, NY US
    Ok there is a PDR_ON pin which i can see is the Power Down Reset pin.... but how does one connect to it?
    I tried following the schematic on the STM32F4-Discovery board but it tells me R27 isnt fitted.. i assume that means its not populated and it says nothing on R28. Both resistors touch the PDR_ON pin. So im not sure what to follow?
    Should i do whats on the board and FIT a 0 ohm or straight connect VDD.... ? or listen to schematic and tie to GND?
    Im kind of lost... Attached are pictures of the schematic portion from the Discovery Datasheet and the actual board image where R27 is in place but not R28...
    Perhaps its a silk screen error?
  2. AtomSoft
    Feb 7, 2008
    5,670
    41
    Brooklyn, NY US
    Ok in another datasheet i notice:
    So i think i should tie to VDD with either a 0 ohm or straight
    UPDATE: It is tied to VDD on my board... just used a DMM to figure it out. So i guess R27 is fitted and R28 isnt fitted. Perhaps a schematic note error.
  3. AtomSoft
    Feb 7, 2008
    5,670
    41
    Brooklyn, NY US
    In another datasheet i found this info:
    Crazy how all of this is separated into different parts... But I will conclude that it has to be:
    TIED to VDD
    Even tho it says its not used on LQFP100 and LQFP64 but JUST IN CASE! since it is available i recommend to tie it to VDD since that's what's need to be done for the other packages and what is done on the actual PCB.
    I hope this is useful to others out there.
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. AtomSoft
    Feb 7, 2008
    5,670
    41
    Brooklyn, NY US
    Take a look:
Share This Page
