The problem: For some reason the UIF (update interrupt flag) in the status register goes high before TIM6 overflows (reaches the value in the auto reload register).
When in debug mode, when I set a break point at the line indicated (then immediately hit continue when stopped) the status register behaves as it should (UIF does not go high until the timer overflows). At first I thought it might be a timing issue, but if I set a reasonably long delay before this line it still doesn't behave as expected.
Here is my code, in full:
Thanks in advance.
; Timer - in ms
;Directives
PRESERVE8
THUMB
;Constants
INITIAL_MSP EQU 0x20002000 ;initial main stack pointer
;TIM6
TIM6_CR1 EQU 0x40001000
TIM6_CR2 EQU 0x40001004
TIM6_DIER EQU 0x4000100C
TIM6_SR EQU 0x40001010
TIM6_EGR EQU 0x40001014
TIM6_CNT EQU 0x40001024
TIM6_PSC EQU 0x40001028
TIM6_ARR EQU 0x4000102C
;CLOCK
RCC_APB2ENR EQU 0x40021018 ;Memory for configuring and enabling clock source
RCC_APB1ENR EQU 0x4002101C
;Vector Table Mapped to Address 0 at Reset, Linker requires __Vectors to be exported
AREA RESET,DATA,READONLY
EXPORT __Vectors
__Vectors
DCD INITIAL_MSP ;stack pointer at top of RAM
DCD Reset_Handler ;reset vector
DCD nmi_ISR ;interrupts
DCD h_fault_ISR
DCD m_fault_ISR
DCD b_fault_ISR
DCD u_fault_ISR
ALIGN
;My program, Linker requires Reset_Handler must be exported
AREA LCDDRAFT,CODE,READONLY
EXPORT Reset_Handler
ENTRY
; Start up code
Reset_Handler PROC
clock_init
;Enable TIM6 [4]
ldr R6,=RCC_APB1ENR
mov R0,#0x0010 ;0000 0000 0001 0000
str R0,[R6]
tim6_init
;1 clock/ms = 1kHz
;PSC = 8Mhz/1kHz - 1 = 7999
ldr R6,=TIM6_PSC
mov R0,#7999
str R0,[R6]
ldr R6,=TIM6_ARR
mov R0,#0xFFFF ;count all the way up
str R0,[R6]
ldr R6,=TIM6_CR1
mov R0,#0x0005 ;[bit2]only under/overflow generates interrupt [bit0]counter enable
str R0,[R6]
ldr R6,=TIM6_CNT
mov R0,#0x0000 ;reset count to 0
str R0,[R6]
; mov R1,#0xFF
;delay
; subs R1,#0x0001
; cmp R1,#0x0000
; bgt delay
ldr R6,=TIM6_SR
mov R0,#0x0000
str R0,[R6] ;clear the status register *BREAKPOINT HERE
ENDP
; START OF MAIN PROGRAM
main PROC
ldr R5,=TIM6_CNT ;get current count
ldr R0,[R5]
ldr R5,=TIM6_SR ;get status register
ldr R1,[R5]
b main
ALIGN
ENDP
; Interrupt Handlers
AREA HANDLERS,CODE,READONLY
;default handlers for interrupts and faults
;all are infinite loop
nmi_ISR
b .
h_fault_ISR
b .
m_fault_ISR
b .
b_fault_ISR
b .
u_fault_ISR
b .
END
Thanks in advance.
