I want to convert our well pump to solar. It turns out that it consumes right much power and adds to our monthly power bill.
Initial Thoughts:
It is an above ground 120 volt pump. I'm not yet sure how many amps/watts it consumes per hour. It is housed in a small pump house. (The roof of the pump house is unsuitable for solar panels.)
The pump feeds a 12 gallon pressure tank (I intend to increase the size of this tank to 20 or 40 gallons so the pump won't run quite as often).
I anticipate that initially I'll use six 120 watt panels to charge two Trojan 105 batteries. These are six volts. So to get 12 volts I'll have roughly 225 reserve amps of current. Going by the formula of using only 20% of their reserve, I'm figuring on roughly 45 amps being available. It is doubtful that the solar panels can fully provide this much power on a daily basis. The number of panels may need to be 8 or 10 - especially for winter months.
So, we have to have the capability to switch the pump back to the grid if the power used exceeds that 45 amps.
I have a south facing roof that is perfect for the panels. It gets lots of sun Summer and Winter. I do not plan to use solar trackers, so I won't get full power all day long.
One thing I'll need to plan is the electronics needed to control the source of the voltage going to the pump. Ideally I'd like to have the pump run from the batteries through an inverter. Then when the drain on the batteries reaches the 45 amp point, switch the receptacle in the pump house over to the grid.
The complicating factor is how to keep the battery/inverter power from backfeeding into the grid in the event of power failure.
I'd guess that some here have done something like this. I'd appreciate any tips and advice you might offer.
My initial thoughts on a budget is about $2 to $3 thousand US dollars. Does that sound anywhere close to realistic? (I wasn't planning on buying a new pump.)
Bach On
Initial Thoughts:
Bach On
