Phase Angled, Pulsing, Zero Fired, Three Phase, there's even on called standard.
I get the Pulse vs Standard Standard has to be energized the whole time to complete the high voltage circuit and then breaks the circuit when 3VDC power to the SSR is cut. The pulsing type switches from on to off based on receiving a signal pulse and defaults to open when powered down entirely.
I'm looking to drive a series of Water Heater Elements at various levels of energy output by using SSRs to cycle in response to a thermocouple input.
I think I want a zero fired standard configuration SSR, but I'm unsure.
Driving the SSR would be an Ardunio open sourse controller or maybe PIDS both of which put out 3 volts to run the SSR they are in circuit with.
Also I'm thinking that I only need an SST for each hot lead and not the neutral that combined with a dual pole throw switch should effectively isolate the heater elements.
Any wisdom from the gathered minds about relays?
