    Dismiss Notice
Solar/Wind/Current Boats
Discussion in 'Alternative Energy' started by dknguyen, Jul 18, 2006.
  1. dknguyen
    dknguyen Well-Known Member
    May 6, 2006
    6,668
    64
    Has anyone see heard of that boat called the Orcell that uses solar, wind, and water current generators in addition to diesel to run?
    How effective is it to take a tiny pager-type motor and stick some kind of fan blades or propeller on it to get it to generate power from the wind (or water for that matter)? In another thread in another section someone said that it wouldn't work very well because the motor is designed to be efficient at around 3000RPM.
    The idea is to charge up a bank of supercapacitors to power electronics and the ocassional sail winch servo or rudder every now and then (miniature model-sized boat). It'd be nice to be able to augment the solar cells with wind power or water current power, with wind sails doing most of the movement work.
  2. audioguru
    audioguru Well-Known Member Most Helpful Member
    Mar 16, 2004
    32,445
    937
    Canada, of course!
    Like the guy who used a computer fan as a generator for his LED array headlamp on his bicycle. It lighted a single LED dimmly when he pedalled as fast as he could go, and didn't charge his battery.
    For your propeller generator to do anything, it will have wind resistance so will act like a sail.
  3. oldtimer
    oldtimer New Member
    Jul 3, 2006
    94
    0
    Florida (english ex pat)
    I had a 30 foot sailing boat with a keel instead of lead I installed lead acid batteries and two 100 watt solar panels on the coach roof. I scrounged a golf cart motor 3 H.P and I never bought any fuel after 11 years in the Med. I also had two wind generators which are easy to build.
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. bristol188
    bristol188 New Member
    Aug 12, 2006
    50
    0
    Karuah Port Stephens NSW Aust.
    That's interesting. Are you a saying that you lowerd the batteries down into
    the keel cavity with webing staps or sim. And they (the bat.s) would have to
    be sealed gelcell wouldn't they?
    Rog.
  6. oldtimer
    oldtimer New Member
    Jul 3, 2006
    94
    0
    They were sealed gell electrolite batteries, I built the keel seperately from the boat then bolted it on. The top of the battery case was sealed to prevent gasses from getting into the cabin. Why carry lead around when it can be put to good use.
  7. philba
    philba New Member
    Mar 12, 2006
    1,886
    8
    Seattle
    how do you replace the batteries when they, inevitibly, go bad?
  8. Nigel Goodwin
    Nigel Goodwin Super Moderator Most Helpful Member
    Nov 17, 2003
    39,227
    641
    Derbyshire, UK
    I would have thought it's fairly obvious?, you remove the keel to get at them!.
  9. philba
    philba New Member
    Mar 12, 2006
    1,886
    8
    Seattle
    oh, that sounds pretty easy...
  10. Nigel Goodwin
    Nov 17, 2003
    39,227
    641
    Derbyshire, UK
    Nobody said it would be easy? :D
  11. philba
    philba New Member
    Mar 12, 2006
    1,886
    8
    Seattle
    I guess rhetorical questions loose their meaning around here...
    to be more explicit. since gelcells are typically designed for a 3-5 yr lifespan, anything that makes it hard to replace them is a huge usability issue. I just wonder what oldtimer's experience here was. I also wonder how salt water invasion was handled - seems another big issue what with salt water being conductive...
    oldtimer?
  12. Hero999
    Hero999 Banned
    Apr 6, 2006
    14,902
    79
    England
    I bet that was slow, there again I suppose you're not after speed.
Share This Page
