SILCAVO ATLAS Help
mabenz33
Hello, I want a person who helped me be able to program simulation of hetero junction cell on Silcaco Atlas:
Here's the program I have but it does not work on DECKBUILD, who could help me thank you:
PS: I already know I have a blem with the file .Opt .But I know how to solve
MANy Thanks
go atlas
set cellWidth=5.000000e+002
set capWidthpercent=8.000000e+000
set divs=1.000000e+001
set contThick=1.000000e-001
set capThick=3.000000e-001
set capDop=1.000000e+020
set windowThick=0.01
set winDop=2.15e17
set emitterThick=0.01
#changed emitDop from 1e16 to 1e20
set emitDop=1e16
set baseThick=3.19467
#changed basDop from 1e16 to 1e20
set baseDop=1e16
set bsfThick=0.03533
set bsfDop=2.15e19
set cellWidthDiv=$cellWidth/$divs
set width3d=100e6/$cellWidth
set capWidth=0.01*$capWidthpercent *$cellWidth/2
set capWidthDiv=$capWidth/($divs/2)
set cellWidthHalf=$cellWidth/2
set bsfLo=0
set bsfHi=$bsfLo-$bsfThick
set bsfDiv=$bsfThick/$divs
set baseLo=$bsfHi
set baseHi=$baseLo-$baseThick
set baseMid=$baseLo-$baseThick/2
set baseDiv=$baseThick/$divs
set emitterLo=$baseHi
set emitterHi=$emitterLo-$emitterThick
set emitterDiv=$emitterThick/$divs
set windowLo=$emitterHi
set windowHi=$windowLo-$windowThick
set windowDiv=$windowThick/$divs
set capLo=$windowHi
set capHi=$capLo-$capThick
#set capDiv=$capThick/$divs
set contLo=$capHi
set contHi=$contLo-$contThick
set contDiv=$contThick/$divs
set lightY=$emitterHi-5
mesh width=$width3d
## X-Mesh
x.mesh loc=-$cellWidthHalf spac=$cellWidthDiv
x.mesh loc=-$capWidth spac=$capWidthDiv
x.mesh loc=$capWidth spac=$capWidthDiv
x.mesh loc=$cellWidthHalf spac=$cellWidthDiv
## Y-Mesh
# Top contact
y.mesh loc=$contHi spac=0
y.mesh loc=$contLo spac=0
# Cap
# Window
y.mesh loc=$windowHi spac=$windowDiv
y.mesh loc=$windowLo spac=$windowDiv
# Emitter
y.mesh loc=$emitterLo spac=$emitterDiv
# Base
y.mesh loc=$baseMid spac=$baseDiv
# BSF
y.mesh loc=$bsfHi spac=$bsfDiv
y.mesh loc=$bsfLo spac=$bsfDiv
## Regions
# Cap
region num=8 material=Vacuum x.min=-$capWidth x.max=$capWidth y.min=$contHi y.max=$contLo
region num=1 material=InGaN x.min=-$capWidth x.max=$capWidth y.min=$capHi y.max=$capLo x.comp=0.20
region num=2 material=Vacuum x.min=-$cellWidthHalf x.max=-$capWidth y.min=$contHi y.max=$capLo
region num=3 material=Vacuum x.min=$capWidth x.max=$cellWidthHalf y.min=$contHi y.max=$capLo
# Window [for Ge cell, use AlGaAs with x.comp=0.2]
region num=4 material=InGaN x.min=-$cellWidthHalf x.max=$cellWidthHalf y.min=$windowHi y.max=$windowLo x.comp=0.20
region num=4 material=AlGaAs x.comp=0.2 x.min=-$cellWidthHalf x.max=$cellWidthHalf y.min=$windowHi y.max=$windowLo
# Emitter
region num=5 material=InGaN x.min=-$cellWidthHalf x.max=$cellWidthHalf y.min=$emitterHi y.max=$emitterLo x.comp=0.20
# Base
region num=6 material=InGaN x.min=-$cellWidthHalf x.max=$cellWidthHalf y.min=$baseHi y.max=$baseLo x.comp=0.20
# BSF
region num=7 material=InGaN x.min=-$cellWidthHalf x.max=$cellWidthHalf y.min=$bsfHi y.max=$bsfLo x.comp=0.20
## Electrodes [for InGaP cell, add cathode (gold) and remove cathode (conductor)]
electrode name=cathode material=Gold x.min=-$capWidth x.max=$capWidth y.min=$contHi y.max=$contLo
#electrode name=cathode x.min=-$cellWidthHalf x.max=$cellWidthHalf y.min=$windowHi y.max=$windowHi
electrode name=anode x.min=-$cellWidthHalf x.max=$cellWidthHalf y.min=$bsfLo y.max=$bsfLo
## Doping [for InGaP cell, uncomment cap doping]
# Cap
doping uniform region=1 n.type conc=$capDop
# Window
doping uniform region=4 n.type conc=$winDop
# Emitter
doping uniform region=5 n.type conc=$emitDop
# Base
doping uniform region=6 p.type conc=$baseDop
# BSF
doping uniform region=7 p.type conc=$bsfDop
## Material properties
# Opaque contact [comment out for InGaP cell]
material region=8 real.index=1.2 imag.index=1.8
# Vacuum (for zero reflection) [change to match window material (InGaP use Vacuum_AlInP)]
# [for InGaP cell, comment out region 1]
#material region=1 index.file=Vacuum_InGaP.opt
#material region=2 index.file=VacuumIn20Ga80N.opt
#material region=3 index.file=VacuumIn20Ga80N.opt
#InGaN
#material material=InGaN EG300=2.6612 index.file=In20Ga80N.opt
# Gold
material material=Gold real.index=1.2 imag.index=1.8
## Models [InGaP cell, 1; GaAs cell, 5&6; InGaNAs cell, 7]
models region=1 CONMOB
MODELS CHUANG CONMOB FLDMOB SRH OPTR PRINT
## Light beams [GaAs b1,0.55-0.75,200 b2,0.75-0.88,65] 0.12-2.7,50 [630,825]
beam num=1 x.origin=0 y.origin=$lightY angle=90 back.refl \
wavel.start=0.12 wavel.end=2.4 wavel.num=50
struct outfile=SingleCell_webf.str
#tonyplot SingleCell_webf.str
solve init
method gummel newton maxtraps=10 itlimit=25
solve b1=0.9
## Getting Isc for I-V curve points
method newton maxtraps=10 itlimit=100
solve b1=0.95
extract name="isc" max(i."cathode")
set isc=$isc*$width3d
set i1=$isc/10
set i2=$i1+$isc/10
set i3=$i2+$isc/10
set i4=$i3+$isc/10
set i5=$i4+$isc/10
set i6=$i5+$isc/20
set i7=$i6+$isc/20
set i8=$i7+$isc/20
set i9=$i8+$isc/20
set i10=$i9+$isc/20
set i11=$i10+$isc/40
set i12=$i11+$isc/40
set i13=$i12+$isc/40
set i14=$i13+$isc/40
set i15=$i14+$isc/40
set i16=$i15+$isc/80
set i17=$i16+$isc/80
set i18=$i17+$isc/80
set i19=$i18+$isc/80
set i20=$i19+$isc/80
set i21=$i20+$isc/80
set i22=$i21+$isc/80
set i23=$i22+$isc/80
set i24=$i23+$isc/80
set i25=$i24+$isc/80-0.00001
log outfile=In20Ga80N.log
solve b1=0.95
contact name=anode current
## Pmax points [InGaP 18-25; GaAs 15-25; InGaNAs 13-25; Ge 11-25]
solve ianode=-$i25 b1=0.95
solve ianode=-$i24 b1=0.95
solve ianode=-$i23 b1=0.95
solve ianode=-$i22 b1=0.95
solve ianode=-$i21 b1=0.95
solve ianode=-$i20 b1=0.95
solve ianode=-$i19 b1=0.95
solve ianode=-$i18 b1=0.95
solve ianode=-$i17 b1=0.95
solve ianode=-$i16 b1=0.95
solve ianode=-$i15 b1=0.95
solve ianode=-$i14 b1=0.95
solve ianode=-$i13 b1=0.95
solve ianode=-$i12 b1=0.95
solve ianode=-$i11 b1=0.95
solve ianode=-$i10 b1=0.95
solve ianode=-$i9 b1=0.95
solve ianode=-$i8 b1=0.95
solve ianode=-$i7 b1=0.95
solve ianode=-$i6 b1=0.95
solve ianode=-$i5 b1=0.95
solve ianode=-$i4 b1=0.95
solve ianode=-$i3 b1=0.95
solve ianode=-$i2 b1=0.95
solve ianode=-$i1 b1=0.95
solve ianode=0 b1=0.95
log off
extract name="iv" curve(v."anode", i."cathode") outfile="IVcurveIn20Ga80N.dat"
tonyplot IVcurveIn20Ga80N.dat
log outfil
I have never seen any user on this forum (or any other) that has described any ability to use or knowledge of basic semi conductors simulator software. That's as far apart from electronics as a human being drinking water has anything to do with it's formation from solar processes.
