series capacitors?
jrz126
Active Member
I'm working on my strobelight, I need ~150uF cap rated at 400 V. however, I have 2 330uF caps. Can I just wire them in series?
Thanks nigel, thats what I was looking for. I tried connecting 15V across both of them and I ended up with 11V on 1 and 4V on the other.
I tried connecting it to the wall outlet, but it didnt work, I think I screwed something up in my timing circuit.
Also, I'm using a smaller capacitor for C1, would this cause it to not work?
https://www.aaroncake.net/circuits/strobe2.htm
It's only a voltage doubler, to compensate for your low mains voltage, check what voltage you have on the second capacitor.
If C1 is slighter smaller, it shouldn't make a great deal of difference.
Why not change the circuit to use a conventional voltage doubler. The capacitors then share the voltage.
HTH
Edit, Adjust the voltages for US mains.
