So what's the equivalent resistance formed by R4, R5 & R6? Once you've found it, let's call that Ry.
So what's the equivalent resistance formed by R2, R3, R4, R5 & R6? Once you've found it, let's call that Rx.
Work out the voltage at the junction (use resistor voltage divider equation) between R1 and Rx; we'll call that Vx. From this you can work out the voltage across two resistors.
Using Vx, work out the voltage at the junction between R3 and Ry. From this you can work out the voltage across another two resistors.
You shouldn't have any trouble working out the voltages for the final two resistors.
