hi how are you!?
i try many times to edit my code but problem it does not work it just shift little
this is my code ,,withonly the text showing without any scrolling
can you tell me how i can add the fuction for scrolling the text please ??
#include <hidef.h>
#include <mc9s12e128.h>
#pragma LINK_INFO DERIVATIVE "SampleS12"
#define setEN 0x04 // 0000 0100 - activate enable bit only
#define cmd 0x00 // set rs=0(command) and rw=0
#define dat 0x01 // set rs=1(data) and rw=0
void initPort(void);
void initPort(void) {
PORTK = 0x00; //clear and set PORT K
DDRK = 0xFF;
PTP=0x00; //and P as output port
DDRP=0XFF;
void delay(unsigned int);
void delay(unsigned int x) //delay - approx 1ms delay
unsigned int y;
while(x>0){
for(y=2750;y>0;y--);
x--;
void LCDWrite(unsigned char, unsigned char);
void LCDWrite(unsigned char val, unsigned char mode) {
PTP = setEN | mode;
delay(1);
PORTK = val;
delay(1);
PTP = mode;
delay(1);
void initLCD(void);
void initLCD(void){
char x;
unsigned char init[]={0x30,0x30,0x30,0x38,0x0C,0x01,0x06};
for(x=0;x<7;x++) {
LCDWrite(init[x],cmd);
void LCD_String(unsigned char* , unsigned char);
void LCD_String(unsigned char* str, unsigned char addr){
char x;
addr = addr | 0x80;
LCDWrite(addr,cmd);
for(x=0;str[x]!='\0';x++) {
LCDWrite(str[x],dat);
void main(void) {
unsigned char name[]="Omaini ";
delay(1000);
initPort();
initLCD();
EnableInterrupts;
LCD_String(name,0);
for(;
all thanks
#include <hidef.h>
DDRK = 0xFF;
DDRP=0XFF;
unsigned int y;
while(x>0){
x--;
PTP = setEN | mode;
delay(1);
PORTK = val;
delay(1);
PTP = mode;
delay(1);
void initLCD(void);
void initLCD(void){
char x;
for(x=0;x<7;x++) {
char x;
addr = addr | 0x80;
LCDWrite(addr,cmd);
void main(void) {
delay(1000);
initPort();
initLCD();
EnableInterrupts;
LCD_String(name,0);
for(;
all thanks
