    Dismiss Notice
Reputation Explained
Discussion in 'Site Issues & Feedback' started by ElectroMaster, Jan 18, 2013.
  1. ElectroMaster
    ElectroMaster Administrator
    Jul 5, 2002
    2,057
    127
    Broadbeach, AU
    We have numerous questions about the red or green squares which displays next to your username/avatar in each post.
    Reputation Levels
    -1 Bad
    0+ Newbie
    50+ Showing Promise
    100+ Okay
    500+ Good
    5000+ Excellent
    Questions and Answers
    Why does someone have red squares?
    You can give positive or negative feedback on each post and if the user has more negative feedback than positive then that user will display red squares.
    Why does my rep increase at different rates?
    When a member gives you reputation, the amount that you will receive is based the amount of reputation they have. So if a user gives reputation that has alot already, then your rep will go up much higher than someone with low reputation.
    Why don't you use names like "Experience Circuit Builder", or "Electronics Guru"?
    We tried this, and unfortunately it didn't work. The reputation system is not an accurate measure of someone technical ability, it's more a gauge of how helpful a user has been in the past. Newer members were mislead and is why we now have more generic terms.
    What's the difference between using the add reputation star and clicking +/-?
    The star allows you to write a comment and give either a positive or negative vote toward the member. This vote passes reputation which ever way you voted. The +/- is slightly different and it is more focused toward showing a post's value within the thread, and not so much on giving reputation. For this reason, reputation is only given on a + vote (not a - vote) and is only a fraction of what the star would have given.
    Note: I'll add to this post as time goes on.
  2. picbits
    picbits Well-Known Member
    Jan 29, 2007
    2,003
    95
    Northants, United Kingdom
    Nice explaination :)
    Can I assume you've tweaked it slightly as I was on "excellent" the other day and have gone "down" to good ?
    My rep points have remained the same but the description has changed.
  3. jpanhalt
    jpanhalt Well-Known Member Most Helpful Member
    Jun 21, 2006
    5,985
    511
    Cleveland, OH, USA
    A short time ago, the +1 and -1 feature (lower right-hand corner)was changed so that +1 gave points, but -1 did not deduct any points.
    Has that now been changed again?
    John
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. ElectroMaster
    Jul 5, 2002
    2,057
    127
    Broadbeach, AU
    Yes, you are correct, the 'Excellent' has been re-adjusted so that only a small percentage of members have it.
    It's still the same. Good question though. I added the full answer to the first post :)
  6. magvitron
    magvitron Active Member
    Jan 11, 2013
    257
    28
    John Lennon !magine land.
    Can you re-explain the reputation? as per new site change?
    may I suggest that the reputation bar makes the newbie members and others to post more? I have even sat down for hours and hours on a forum to improve my rating, because the progress in the rating bar can be "seen" like a progress bar with regular update. You might have seen this forum, will you do something like that?
  7. DerStrom8
    DerStrom8 Super Moderator Most Helpful Member
    Aug 9, 2010
    5,500
    503
    Vermont (GMT-5:00)
    Now that the system has changed again I wonder if this should be updated? No rush, just wondering.
Share This Page
