    Dismiss Notice
Replace an LL4148 with a zener diode?
Discussion in 'Repairing Electronics' started by halleffector, Jun 20, 2017.
  1. halleffector
    halleffector Member
    Jan 30, 2016
    98
    0
  2. ericgibbs
    ericgibbs Well-Known Member Most Helpful Member
    Jan 4, 2007
    21,187
    644
    Ex Yorks' Hants UK
    The LL4148 diode has the same electrical specification as the regular 1N4148, why do want to use a zener.?
    E
  3. alec_t
    alec_t Well-Known Member Most Helpful Member
    Jul 10, 2011
    9,255
    1,218
    Cardiff, Wales
    Why would you want to replace a signal diode with a zener diode?
    What part of the PSU circuit is involved (which would determine the voltage rating)?
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. halleffector
    halleffector Member
    Jan 30, 2016
    98
    0
    Thanks. I want to use a zener diode simply because I don't have a signal diode at hand to use.
    Edit: Actually I don't have 1N4148 either, guess I have to order something anyway.
  6. Nigel Goodwin
    Nigel Goodwin Super Moderator Most Helpful Member
    Nov 17, 2003
    39,228
    641
    Derbyshire, UK
    A 4148 is a bog-standard small silicon diode, you can use pretty well any little silicon diode to replace it.
    However, you don't give any indication of what the diode does?, the diodes datasheet is no use at all.
  7. halleffector
    halleffector Member
    Jan 30, 2016
    98
    0
    Sorry about that.
    https://www.scribd.com/doc/207782153/Dell-2407-WFP-Power-Supply-Rev-A11-Schematic-Diagram
    The diode in question is D655, which is found on the first page, connected to pin 7 of the L6561D PFC.
    It is for the same PSU I've posted about before, http://www.electro-tech-online.com/threads/repairing-a-dell-2407wfp-lcd.149287/
    All I have as far as SMD diode parts go are various zener diodes. In particular, these are all I have: http://www.ebay.com/itm/1280Pcs-080...169824?hash=item2a75b12420:g:eSEAAOSw2gxYuQzB
    As you can understand, I'm a beginner when it comes to repairs of SMD stuff, I guess I should spend my time in a better way than attempting to repair that PSU but I want to do it. It is my own device, and I don't intend to assemble it fully and run it permanently with a non-optimal part that may be a hazard. But if I could just use something and at least test it to see if it is working, then I can always order what it actually should have and replace that final part before it put it back together. Or would it be fine to use one of the zener diodes that I have? What voltage should I use in that case?
  8. ericgibbs
    Jan 4, 2007
    21,187
    644
    Ex Yorks' Hants UK
    IMO a fast switching signal diode is required, in order to quickly discharge the MOSFET Gate capacitor.
    Zener diodes are inherently slow and 'soft' and are not suitable for this repair.
    If you have access to any scrapped electronic modules, you should be able recover a suitable signal diode
    E
    • Like Like x 1
  9. hyedenny
    hyedenny Member
    Jan 17, 2009
    68
    2
    The link you mentioned is for SMD resistors. I hope you don't think resistors and Zener diodes are the same thing...
    In any case, you could probably just leave the diode and the resistor out -- the datasheet for the L6561 shows neither on that pin in the applications notes. It looks like the gate driver circuit in the L6561 would make anything else redundant.
  10. Willen
    Willen Well-Known Member
    May 22, 2012
    1,293
    115
    Nepal (GMT +5:45)
    Do you have scrap boards? I can get hundreds from such boards.
Share This Page
