joshsstuff
I wish to remove the audio properties of my HDMI display cables.
Is there a way to do this by making an adapter that cuts out certain pins?
(Windows 10 has a tendency to re-route Audio to a newly plugged in device. This has been a problem for my system.)
I've already tried the Software solution of disabling all audio sources, however when Windows updates mysteriously these audio sources get re-enabled!
I've searched this topic and found a few places where people wanted to extract the Audio from HDMI.
(SPDIF- so perhaps there is a way to omit the Audio?)
DVI output:
Since DVI does not carry audio, a DVI to HDMI cable is safe from this behavior.
(Windows does not even recognize the display as a potential audio device)
Using DVI outputs from the graphics card and HDMI adapters would solve the problem, however I don't have enough.
Here is the pinout of HDMI from Wikipedia:
Compared with the pinout of DVI:
(Single link pins circled)
If you count the flat pin, This seems to be a 19pin to 19pin direct connection.
But I didn't think HDMI and DVI used the same standard.
Does anyone know of a way to disable only the pins responsible for Audio?
The problem:
I'm having problems with Audio being diverted to my monitors instead of the desired audio device. (Windows 10 has a tendency to re-route Audio to a newly plugged in device. This has been a problem for my system.)
Solutions I've tried:
Software: I've already tried the Software solution of disabling all audio sources, however when Windows updates mysteriously these audio sources get re-enabled!
DVI output:
