Pwm and swordfish basic
Here the whole code and working good thank's to 3v0
SetAllDigital
// main program...
SetFreq(5000)
Duty = 0
While true
       PWM.SetDutyPercent(Duty)
      If ( (sw0 = 1) And (Duty < 10) ) Then
        Inc(Duty)
        DelayMS(10)
      EndIf
      If ( (sw1 = 1) And (Duty >0) ) Then
        Dec(Duty)
        DelayMS(20)
      EndIf
   Wend
End
This is what I was saying about switches it works but not to good it's like the denounce is not working all the time
Device = 18F1220
Clock = 8
Config OSC = INTIO2
Include "INTOSC8.bas"
Include "Utils.bas"              // local duty variable...
Dim sw0 As PORTB.0
Dim led As PORTB.3
Sub Debounce()
    DelayMS(10)                     // Small delay to stop "bouncing"
    While sw0 = 1                // Wait for the switch to be de-pressed
    Wend                            //
End Sub
SetAllDigital
Input (sw0)
Output (led)
Low (led)
 While true
               If ( (sw0 = 1) And (led = 0) ) Then //check switch and led
               led =  1  // turn on led
       ElseIf( (sw0 = 1) And (led = 1) ) Then //check led to see if on ans switch
               led = 0  // turn off led
       EndIf
 Wend
You need to start thinking like a computer when you look at code. Also a comment to tell what it does would be nice. You have morphed the PWM program into blinking an LED here.
your main loop is
 While true
               led = 1
               led = 0
       EndIf
 Wend
You never call the debounce subroutine. Why would it do anything ?
And because you use a specific switch in the debounce sub you have to write two of them in the PWM code. Given that you can not use each sub more then once just put the debounce code inline.
While true
               led = 1
               DelayMS(5) // Small delay to stop "bouncing"
               While sw0 = 1
               led = 0
               While sw0 = 1
       EndIf
 Wend
I was just trying it out to see if i could get it to work right. Been tryng to think like computer ha ha. I said if I was a computer and some 1 put a sub for switches like that how would I no if they had more switches. dum sub. That's the part i been leaving out
While sw0 = 1
hot dam this is it use one switch to turn on or off a led
Device = 18F1220
Clock = 8
Config OSC = INTIO2
Dim sw0 As PORTB.0
Dim led As PORTB.3
Sub debounce()
End Sub
SetAllDigital
Input (sw0)
Output (led)
Low (led)
 while true
      if ( (sw0 = 1) And (led = 0) ) then   // check switch
       debounce
       While sw0 = 1       // make sure switch reads as good press
       wend
 endif
     if ( (sw0 = 1) And (led = 1) )  then  // check switch
      led = 0
      debounce            // turn off led
      while sw0 = 1
      wend               // make sure switch reads as good press
 endif
 wend
:D
Good deal. You've just made an alternate action switch function from a momentary switch. One of the handiest functions that can come in really handy!
