Pickit 2 VPP Voltage Level error
nachum
Hi
I bought a MINI KIT2 for programming. But when I try to program I get a message on the voltage level on VPP is lower than that message "Pickit 2 VPP Voltage Level error. Check target and retry operation." . Any idea what could be done to resolve the problem.
I checked with a FLUKE the VPP showed me just 1+- volt.
Attached pictures of programmer And the development board kit.
Thank you for your help
Not familiar with that dev board, but it looks like a far east Pickit2 clone.
I would first prove that the Mini Kit2 was working ok by simply putting your 16F chip in a breadboard etc and connecting short 5 wires to the programmer and first see if it can recognise the chip and then program.
The results of that should show what the next step is.
You should connect the two -
16F877a.......................Pickit2
pin 1 VPP .......................1
pin 32 & 11 + Vss ......... 2
pin 31 & 12 - Gnd ..........3
pin 40 Data.....................4
pin 39 Clock ...................5
kit2 pin 6 not used , see the Microchip Pickit2 Help - User Manual for helpful info and trouble shooting is this does not work.
Hi
I connected the micro to the PICKIT 2.
I check with PICkit 2 v2.61 and i Received "Pickit 2 VPP Voltage Level error. Check target and retry operation"
Just need to establish some facts.
The 16F877, did that come preprogrammed with some sample led flashing progam for the dev board, if so, did it work on the dev board OK ? - Does it still work on the dev board ok ?
Your first attempt to program was with the 16F in the dev board zip socket and the minkkit2 plugged into the dev board ?
The attempt you have just done was in a breadboard with nothing else connected to the 16F and the wires between the two not longer that 150mm / 6" ?
Do you have any other pic chips to hand ?
Test the pickit2 with it's software it has tools to test the programmer with like Bill said. If all good with your pickit2 then make sure you don't have Vpp
pulled low it should be pulled to Vdd with a 10k resistor
I bought a development kit + programmer (PICKIT2).
Right now I could not do anything.
I always get an error message on the problem of voltage VPP.
I downloaded the software that checks voltage programmer. And there I get no voltage on VPP.
There could be a problem with the programmer or I did not connect properly??
You're sure? That is the problem then, USB output for Vpp to GND is around 5V. Check that from the USB output of your PC (it is USB connected ain't it?) according to this:
Figure out the problem from that point, USB ain't gonna be the problem, probably some short-circuit problems you overlooked.
USB properly. the VDD shows 5v.
But when I try to Check Communication i get an error message on VPP.
I attached pictures.
If your last Vpp test was done with nothing connected to your Mini Kit2, and the Vdd looks ok, then it would seem you have a faulty unit and it needs returning to your supplier.
Is it a far east mail order unit ?
Internally they are smd devices and little you can do to them.
The reason I asked earlier about if you had run any demo on the dev board was to try and establish if that board was also ok, particularly the connections to pin1 the Mclre / Vpp pin.
I checked the PICKIT 2 even without the development kit also received an error message on the VPP
I bought the programmer in China
If I did not connect the pic16f877a to PICKIT 2 Which result I should get When I check the VPP ??
The Troubleshooting via the Pickit2 program must be intially done, as the opening screen states, with nothing connected to it other than your test meter wires.
So with the Minikit2 plugged into the usb lead and the output connector totally empty, connect your meter + lead to Vpp pin 1 and your meter - lead to pin 3 - your meter should be set to the dc volts range.
Do you get anything near 12v being shown ?
Also try the +5v Vdd again.
Well even if you test it without the Fluke connected it should still show 12v on the diagnostic screen - looks like you have been unlucky and got a duff one.
Back to the suppliers then...
Vpp will not appear if a chip is not recognised by the programmer and will not appear until the actual time of "burning."
Hi
How do I see 11+ volts? the USB is 5 volts.
I get an error vpp
I tried to burn and i receive notification problem on VPP.
So I installed the software PICkit 2 v2.61 and saw that PICKIT 2 volts on VPP.
Could be that the PICKIT not know to program the PIC16F877??
link ---http://cgi.ebay.com/DIY-PICKIT-2-PICKIT2-Microchip-PIC-Programmer-Debugger_W0QQitemZ390148784464QQcmdZViewItemQQptZBI_Electrical_Equipment_Tools?hash=item5ad6ae0150
Current PICkit 2 Programming Support (Mar 2007) Bold font indicates new parts supported in Application v2.20 and device file v1.20
PICkit 2 MPLAB 7.51 & 7.52 Support
Debugging & Programming
PIC12F683*
PIC16F684*, 685*, 687*, 688*, 689*, 690*
PIC16F883, 884, 886, 887
PIC16F913, 914, 916, 917, 946
These devices require an ICD header board to enable debugging with them Programming only
PIC12F508, 509, 510
PIC12F675
PIC16F505, 506
For the most current MPLAB support information, see Readme for PICkit 2 in the “Readmes” subdirectory of “MPLAB IDE.”
(Typically C:\Program Files\Microchip\MPLAB IDE\Readmes)
Notice: (please read this carefully for some often asked questions)
1 Device Support List (For reference only) (IDE 7.62, for latest version please check your readme file)
1.1 Debugger - Full Support
PIC16F690*
PIC16F884
PIC16F887
PIC16F883
PIC16F886
PIC16F917
1.2 Debugger - Beta Support
PIC12F629*
PIC12F635*
PIC12F675*
PIC12F683*
PIC16F627A*
PIC16F737
PIC16F874A
PIC16F628A*
PIC16F747
PIC16F876
PIC16F630*
PIC16F767
PIC16F876A
PIC16F631*
PIC16F777
PIC16F877
PIC16F636*
PIC16F785*
PIC16F877A
PIC16F648A*
PIC16F818
PIC16F88
PIC16F676*
PIC16F819
PIC16F882
PIC16F677*
PIC16F87
PIC16F913
PIC16F684*
PIC16F870
PIC16F914
PIC16F685*
PIC16F871
PIC16F916
PIC16F687*
PIC16F872
PIC16F946
PIC16F688*
PIC16F873
PIC16HV785*
PIC16F689*
PIC16F873A
PIC16F716*
PIC16F874
PIC18F1220
PIC18F2682
PIC18F6310
PIC18F1230+
PIC18F2685
PIC18F6390
PIC18F1320
PIC18F4220
PIC18F6410
PIC18F1330+
PIC18F4221
PIC18F6490
PIC18F2220
PIC18F4320
PIC18F6520
PIC18F2221
PIC18F4321
PIC18F6525
PIC18F2320
PIC18F4331
PIC18F6527
PIC18F2321
PIC18F4410
PIC18F6585
PIC18F2331
PIC18F442
PIC18F6620
PIC18F2410
PIC18F4420
PIC18F6621
PIC18F242
PIC18F4423
PIC18F6622
PIC18F2420
PIC18F4431
PIC18F6627
PIC18F2423
PIC18F4450
PIC18F6628
PIC18F2431
PIC18F4455
PIC18F6680
PIC18F2450
PIC18F4458
PIC18F6720
PIC18F2455
PIC18F448
PIC18F6722
PIC18F2458
PIC18F4480
PIC18F6723
PIC18F248
PIC18F4510
PIC18F8310
PIC18F2480
PIC18F4515
PIC18F8390
PIC18F2510
PIC18F452
PIC18F8410
PIC18F2515
PIC18F4520
PIC18F8490
PIC18F252
PIC18F4523
PIC18F8520
PIC18F2520
PIC18F4525
PIC18F8525
PIC18F2523
PIC18F4550
PIC18F8527
PIC18F2525
PIC18F4553
PIC18F8585
PIC18F2550
PIC18F458
PIC18F8620
PIC18F2553
PIC18F4580
PIC18F8621
PIC18F258
PIC18F4585
PIC18F8622
PIC18F2580
PIC18F45K20
PIC18F8627
PIC18F2585
PIC18F4610
PIC18F8628
PIC18F25K20
PIC18F4620
PIC18F8680
PIC18F2610
PIC18F4680
PIC18F8720
PIC18F2620
PIC18F4682
PIC18F8722
PIC18F2680
PIC18F4685
PIC18F8723
1.3 Programmer - Full Support
PIC12F510
PIC12F675
PIC16F506
PIC16F88
PIC16F887
PIC16F684
PIC16F883
PIC16F917
PIC16F690
PIC16F884
PIC16F87
PIC16F886
1.4 Programmer - Beta Support
PIC12F508
PIC12F509
PIC12F629
PIC12F635
PIC12F683
PIC16F505
PIC16F716
PIC16F874
PIC16F627A
PIC16F737
PIC16F874A
PIC16F628A
PIC16F747
PIC16F876
PIC16F630
PIC16F767
PIC16F876A
PIC16F631
PIC16F777
PIC16F877
PIC16F636
PIC16F785
PIC16F877A
PIC16F648A
PIC16F818
PIC16F882
PIC16F676
PIC16F819
PIC16F913
PIC16F677
PIC16F870
PIC16F914
PIC16F685
PIC16F871
PIC16F916
PIC16F687
PIC16F872
PIC16F946
PIC16F688
PIC16F873
PIC16HV785
PIC16F689
PIC16F873A
PIC18F1220
PIC18F2682
PIC18F6310
PIC18F1230
PIC18F2685
PIC18F6390
PIC18F1320
PIC18F4220
PIC18F6410
PIC18F1330
PIC18F4221
PIC18F6490
PIC18F2220
PIC18F4320
PIC18F6520
PIC18F2221
PIC18F4321
PIC18F6525
PIC18F2320
PIC18F4331
PIC18F6527
PIC18F2321
PIC18F4410
PIC18F6585
PIC18F2331
PIC18F442
PIC18F6620
PIC18F2410
PIC18F4420
PIC18F6621
PIC18F242
PIC18F4423
PIC18F6622
PIC18F2420
PIC18F4431
PIC18F6627
PIC18F2423
PIC18F4450
PIC18F6628
PIC18F2431
PIC18F4455
PIC18F6680
PIC18F2450
PIC18F4458
PIC18F6720
PIC18F2455
PIC18F448
PIC18F6722
PIC18F2458
PIC18F4480
PIC18F6723
PIC18F248
PIC18F4510
PIC18F8310
PIC18F2480
PIC18F4515
PIC18F8390
PIC18F2510
PIC18F452
PIC18F8410
PIC18F2515
PIC18F4520
PIC18F8490
PIC18F252
PIC18F4523
PIC18F8520
PIC18F2520
PIC18F4525
PIC18F8525
PIC18F2523
PIC18F4550
PIC18F8527
PIC18F2525
PIC18F4553
PIC18F8585
PIC18F2550
PIC18F458
PIC18F8620
PIC18F2553
PIC18F4580
PIC18F8621
PIC18F258
PIC18F4585
PIC18F8622
PIC18F2580
PIC18F45K20
PIC18F8627
PIC18F2585
PIC18F4610
PIC18F8628
PIC18F25K20
PIC18F4620
PIC18F8680
PIC18F2610
PIC18F4680
PIC18F8720
PIC18F2620
PIC18F4682
PIC18F8722
PIC18F2680
PIC18F4685
PIC18F8723
* These devices require a header board to be able to debug the device. See the Header Board Specification (DS51292) for more information. This document is available in the “Downloads” section of the PICkit 2 web page.
