    Dismiss Notice
PIC12F509 C Code will not compile...build errors
Discussion in 'Microcontrollers' started by Flyback, Jun 4, 2017.
  1. Flyback
    Flyback Well-Known Member
    Jan 5, 2007
    1,989
    34
    Hello,
    Do you know why this code for PIC12F509 will not compile?
    It is written in MPLAB X IDE and using XC8 C compiler.
    All the code does is pick out a low to high transition on PORT GP4 and then wait 3 ms, then take PORT GP2 high.
    I am festooned with build errors at the moment.
    Code (c):
     * File:   zapper.c
     * Author:
     * Created on 03 June 2017, 23:55
    //This code turns the product ON at the mains peak voltage
    //It does this by using the zero crossing detector input.
    //This uses PIC12F509
    //MPLAB X IDE
    //XC8 C compiler (free)
    #define  _XTAL_FREQ 4000000
    #include <xc.h>
    #include <stdint.h>
    #pragma config OSC = ExtRC      // Oscillator Selection bits (external RC oscillator)
    #pragma config WDT = OFF        // Watchdog Timer Enable bit (WDT disabled)
    #pragma config CP = OFF         // Code Protection bit (Code protection off)
    #pragma config MCLRE = ON       // GP3/MCLR Pin Function Select bit (GP3/MCLR pin function is MCLR)
    //I have not set the MCLR pin as an input because it will be noise susceptible.
    //Therefore i set MCLR up as reset, but i will never use it as reset..but will
    //simply tie the pin top Vdd on the PCB.
    //Define output
    #define FETS     LATBbits.RB2;
    //Define input
    #define zero_x     PORTBbits.RB4;
    //Define actions
    #define ON    LATBbits.RB2 = 1  /*Turn ON FETs*/
    //Declare functions which set up the microcontroller
    void    disable_interrupts(void);   //How do this?
    void    disable_pullups(void);      //How do this?
    void    setup_ports(void);
    void    setup_ports(void) {
        TRISB = 0b00011000;
        return;
    //Declare variables
    uint8_t    count;
    void main(void) {
        setup_ports();
        //10 second delay
        for (count=1;count<=100;count++)   {
        __delayms(100);
    here:
        if {zero_x = 1} {goto here;}
    here1:
        if {zero_x = 0} {goto here1;}
        //When it gets to this point, the zero crossing input has just gone high
        __delayms(3);   //delay to get to the mains peak
        ON;              //Turn ON FETs...at the mains peak
        while(1){;}
        return ();
  2. Ian Rogers
    Ian Rogers Super Moderator Most Helpful Member
    Mar 28, 2011
    9,141
    907
    Rochdale UK
    Replace this with this
    while(zero_x == 1 );
    while(zero_x == 0);
    using goto's in C will haunt you..
    is wrong... You don't need a return as the function main() is declared void
    Untested but try this
    Code (c):
     * File:   zapper.c
     * Author:
    //MPLAB X IDE
    #include <xc.h>
    #include <stdint.h>
    //Define output
    //Define input
    //Define actions
    //void    disable_interrupts(void);   //How do this?  No need to do it at all
    //void    disable_pullups(void);      //How do this?
    //void    setup_ports(void);
    void    setup_ports(void) {  // this will work without definition as it comes first!!
        TRISB = 0b00011000;
        return;
    //Declare variables
    uint8_t    count;
    void main(void) {
        setup_ports();
        //10 second delay
        __delay_ms(100);
     while(zero_x == 1);
     while(zero_x == 0);
        __delay_ms(3);   //delay to get to the mains peak
        while(1){}
    • Like Like x 1
  3. jjw
    jjw Member
    Apr 16, 2012
    257
    15
    Helsinki, Finland
    The semicolon at the end of #define sentence is an error.
    If zero_x = 1 should be if zero_x == 1
    If zero_x = 0 -> if zero_ x == 0
    Return statements are not needed.
    How does the compiler know which PIC is used?
    • Like Like x 1
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. Ian Rogers
    Mar 28, 2011
    9,141
    907
    Rochdale UK
    Yep missed that... I knew I should have tested it...
    It picks it up from MPLAB ide..
    • Like Like x 1
  6. jpanhalt
    jpanhalt Well-Known Member Most Helpful Member
    Jun 21, 2006
    5,885
    500
    Cleveland, OH, USA
    Just a few points: The 12F509 is a simple chip. It does not have any LATx register, TRISx is simply TRIS, and the port is not PORTx, but rather GP0..GP5 . The 12F505, a 14-pin chip, is different.
    Flyback is apparently Treez on other forums.
    John
    • Like Like x 1
  7. Flyback
    Jan 5, 2007
    1,989
    34
    Thankyou so much,
    Massive reduction in errors now, but still wont compile...error remaining says "struct/union required" and points to the 'while' lines.
    Any ideas greatly appreciated.
    * File: zapper.c
    * Author:
    //MPLAB X IDE
    #include <xc.h>
    #include <stdint.h>
    //Define output
    #define FETS GPIO.GP2
    //Define input
    #define zero_x GPIO.GP4
    //Define actions
    #define ON GPIO.GP2 = 1; /*Turn ON FETs*/
    // TRIS = 0b00011000;
    TRIS = 0x18;
    return;
    //Declare variables
    uint8_t count;
    void main(void) {
    setup_ports();
    //10 second delay
    __delay_ms(100);
    while(zero_x == 1 ) {;}
    while(zero_x == 0) {;}
    while(1){;}
    return;
  8. Flyback
    Jan 5, 2007
    1,989
    34
    ...Thankyou all
    Now solved.
  9. jpanhalt
    Jun 21, 2006
    5,885
    500
    Cleveland, OH, USA
    Hi Flyback,
    You know, for such a simple program, you may want to consider the 10F32x chips. The 10F320 is $0.42 each in lots of 100 and the 12F509 is $0.52 each in lots of 100 from Digikey. The 10F32x offers the LATx register, interrupts, and 16 MHz. I didn't do a full comparison of alternatives, but since it seems you are starting almost from scratch, a newer chip might be much better, smaller, and cheaper.
    John
    • Like Like x 1
Share This Page
