"|=" operator in C Language: Solved
eblc1388
Active Member
Can't find anything using "|=" as search phase in Google.
Found it at last. It is bitwise inclusive OR. So A |= B means A = A .OR. B
eblc1388 said:
Joel Rainville said:
What about ^= and &= ?
;):lol:
Both "|=" and "^=" resulted in nothing in Google. "&=" works the same as "&".
Yep :
(A = A | B) == (A |= B) // inclusive OR
(A = A ^ B) == (A ^= B) // eXclusive OR
(A = A & B) == (A &= B) // AND
The unary NOT operator is !, and of course the != operator isn't a bitwise operator, but a comparison operator meaning "different than"...
I guess Google has its limits :D
So "!=" is the XOR instruction in C then?
It is already mentioned that ! is a unary operator. This means it will only invert 0 to 1 and 1 to 0.
But that is true only if the data is in bytes
This means if you write 0XFF != a, then a will contain 0 and if you again invert it by saying !a then the answer will be 1
in binary
!(0000 0000) = (0000 0001)
whereas if you use ~ then it will simply invert each bit as it is a bitwise operator.
NOT operators are unary ie operate on single bit or byte
But "!=" means "not equal". If A & B are Boolean, then A != B means !(A==B), right?
So is it the same as A XOR B, assuming there is a logical XOR instruction in C?
in binary
This is misleading.
!= is a logical (or comparison) operator that evaluates to a boolean value of 0 for false or 1 for true. So the following is true, but not for the reason you're thinking :
The same goes for !, which is also a logical operator.
The bitwise NOT operator in C is ~ [edit: previously wrong statement edited out]
eblc, the XOR operator in C is ^. != is a comparison operator, just like ==.
To sum it up :
Comparison operators that evaluate to 0 or 1 : ==, !=, &&, ||
Binary operators (taking 2 operands) : +, -, ^, |, & and their "lazy programmer" versions : +=, -=, ^=, |=, &=
Unary operators : !, ++, --
Yes, but "^" is a bitwise operator.
If A & B are Boolean, how to express A XOR B in C Language? Still A^B ???
Yes, you got it.
A logical XOR doesn't exist in C because it doesn't evaluate strictly to boolean values on non-boolean operands... But you do have a bitwise XOR ;)
If A & B are Boolean, what is A XOR B in C Language? Still A^B ???
Yes... I don't understand why you insist on A & B being boolean though, since it doesn't change anything?
Say A = 0001, B = 0000. (A ^ B) == 0001
Say A = 1010, B = 0101. (A ^ B) == 1111
As you can see, what the ^ operator can't do is give you a straight boolean value from non-boolean operands. That's why there is no ^^ logical (or comparison) operator.
Because they are "states" of something like switches, pin logic level...i.e. condition.
I have a perfectly good reason to test that "Either my switch1 or switch2 is closed but not both" and this needs a XOR test.
So we come back to the original question, can A!=B gives me the required result?
Yes, but it's not a XOR, it's just plain english ;) It litterally means "A is not equal to B." It just happens to give the same result as a XOR when A and B are boolean.
To elaborate a little, != on the PIC would probably compile into a corresponding XOR operation. Other RISC platforms might do the same. But not all platforms would do it like that, especially CISC platforms.
It is all how you use the things.
!= can be (In normal cases always be) used in conditional loops like
 if(i != j)
while(n != p)
!= = Not equal to
Now case 2 is as follows
i += 1
will result in
 i = i + 1
same with - , && ! and ||,~,!,&,^,|,*,/
Now here one must be very careful about bitwise operators and bytewise operators
Bitwise and &
Bytewise and &&
Bitwise or |
Bytewise or ||
Bitwise not ~
Bytewise not !
While writing code in embedded C, few instructions are supported though they are not ANSI standard just to match some assembly instructions.
What if I want to rotate accumulator through carry?
So there should be no confusion in that.
!= is not XOR as
a != b can't be
!(a == b) but is
a = !b
While we can use "&&" to test for both conditions to be true and "||" for either one to be true, I now wonder whether it is legal in C to write:
/* condition1: true/false
condition2: true/false */
If (condition1 != condition2)
Possible workaround:
If ( (condition1 && !condition2) || (!condition1 && condition2) )
But it seems too long-winded.
sarang1_in said:
Bitwise and &
Bytewise and &&
Bitwise or |
Bytewise or ||
Bitwise not ~
Bytewise not !
There is no such thing as a "bytewise" operator in C. I don't know where you got this idea. There are bitwise and logical operators that are either unary (taking 1 operand) or binary (taking 2 operands). What you describe as "bytewise" operators are really logical operators that make an expression like (A && B) evaluate to a boolean value of 0 or 1, no matter the size of A and B.
It is perfectly legal... although you would get fired from any software development firm for driving your coworkers to insanity! :p Your "workaround" is very hard to read. ;)
