Octave and Scilab.
yup got them emerged atm
Octave is just as good, it lacks some of the specific commands (stats stuff in detail) but I dont need that kind of stuff
The main use for me of Matlab/Octave is data manipulation (filtering,RMSing of recorded data)
I tried Scilab and unfortunatly SimuLink is far too advance for it to be of any use
trouble with cygwin.
I downloaded octave and am running it in windows using cygwin.
I tried the ./compile and got a few warning which were non fatal.
When I ran ./make, I got an error saying something about "could not stat octave-bug"
it is stat not start.. ??? :?:
Styx, how did you manage to install?
Please help.
Thank you in advance.
Well I run Linux:Gentoo as my primary operating system and it has the best package managment system called PORTAGE
Rather then installing BINARY programs (via RPM files or DEB files) Gentoo users download the source-code from the net and compile locally
most of the time it involves a
wget http:\\\URL-to_src.tar.gz
targ -uzt the-src.tar.gz
./configure
make
make install
this is automated in Gentoo so all we have to do is go emerge octave and it runs all those command to automatically install octave.
Saying that I have issued abt a dozen ebuilds myself to Portage so I know how they work
Here is the context of the ebuild for octage
# Copyright 1999-2005 Gentoo Foundation
# Distributed under the terms of the GNU General Public License v2
# $Header: /var/cvsroot/gentoo-x86/sci-mathematics/octave/octave-2.1.71.ebuild,v 1.2 2005/10/22 23:39:18 cryos Exp $
inherit flag-o-matic
DESCRIPTION="GNU Octave is a high-level language (MatLab compatible) intended for numerical computations"
HOMEPAGE="http://www.octave.org/"
SRC_URI="ftp://ftp.octave.org/pub/octave/bleeding-edge/${P}.tar.bz2
		ftp://ftp.math.uni-hamburg.de/pub/soft/math/octave/${P}.tar.bz2"
LICENSE="GPL-2"
SLOT="0"
KEYWORDS="~alpha ~amd64 ~ppc ~sparc ~x86"
IUSE="emacs static readline zlib tetex hdf5 mpi ifc blas"
DEPEND="virtual/libc
	>=sys-libs/ncurses-5.2-r3
	>=media-gfx/gnuplot-3.7.1-r3
	>=sci-libs/fftw-2.1.3
	>=dev-util/gperf-2.7.2
	zlib? ( sys-libs/zlib )
	hdf5? ( sci-libs/hdf5 )
	tetex? ( virtual/tetex )
	x86? ( ifc? ( dev-lang/ifc ) )
	blas? ( virtual/blas )
	!=app-text/texi2html-1.70"
# NOTE: octave supports blas/lapack from intel but this is not open
# source nor is it free (as in beer OR speech) Check out...
# http://developer.intel.com/software/products/mkl/mkl52/index.htm for
# more information
pkg_setup() {
	use ifc || if [ -z `which g77` ] && [ -z `which gfortran` ]; then
		#if ifc is defined then the dep was already checked
		eerror "No fortran compiler found on the system!"
		eerror "Please add fortran to your USE flags and reemerge gcc!"
		die
	fi
src_compile() {
	filter-flags -ffast-math
	local myconf="--localstatedir=/var/state/octave --enable-rpath"
	myconf="${myconf} --enable-lite-kernel"
	use static || myconf="${myconf} --disable-static --enable-shared --enable-dl"
	# Only add -lz to LDFLAGS if we have zlib in USE !
	# BUG #52604
	# Danny van Dyk 2004/08/26
	use zlib && LDFLAGS="${LDFLAGS} -lz"
	econf \
		$(use_with hdf5) \
		$(use_with mpi) \
		$(use_enable readline) \
		${myconf} \
		LDFLAGS="${LDFLAGS}" || die "econf failed"
	emake || die "emake failed"
src_install() {
	make install DESTDIR=${D} || die "make install failed"
	use tetex && octave-install-doc
	if use emacs; then
		cd emacs
		exeinto /usr/bin
		doexe otags
		doman otags.1
		for emacsdir in /usr/share/emacs/site-lisp /usr/lib/xemacs/site-lisp; do
			insinto ${emacsdir}
			doins *.el
		done
		cd ..
	fi
	dodir /etc/env.d
	echo "LDPATH=/usr/lib/octave-${PV}" > ${D}/etc/env.d/99octave
	# Fixes ls-R files to remove /var/tmp/portage references.
	sed -i -e "s:${D}::g" ${D}/usr/libexec/${PN}/ls-R || die
	sed -i -e "s:${D}::g" ${D}/usr/share/${PN}/ls-R || die
pkg_postinst() {
	echo
	einfo "Some users have reported failures at running simple tests if"
	einfo "octave was built with agressive optimisations. You can check if"
	einfo "your setup is affected by this bug by running the following test"
	einfo "(inside the octave interpreter):"
	einfo
	einfo "octave:1> y = [1 3 4 2 1 5 3 5 6 7 4 5 7 10 11 3];"
	einfo "octave:2> g = [1 1 1 1 1 1 1 1 2 2 2 2 2 3 3 3];"
	einfo "octave:3> anova(y, g)"
	einfo
	einfo "If these commands complete successfully with no error message,"
	einfo "your installation should be ok. Otherwise, try recompiling"
	einfo "octave using less agressive \"CFLAGS\" (combining \"-O3\" and"
	einfo "\"-march=pentium4\" is known to cause problems)."
	echo
octave-install-doc() {
	echo "Installing documentation..."
	insinto /usr/share/doc/${PF}
	doins doc/faq/Octave-FAQ.dvi
	doins doc/interpreter/octave.dvi
	doins doc/liboctave/liboctave.dvi
	doins doc/refcard/refcard-a4.dvi
	doins doc/refcard/refcard-legal.dvi
	doins doc/refcard/refcard-letter.dvi
from this it seems all that is needed are these 3 steps
./configure
make
make install
all done in the directory where the cource-code is.
what the ./configure does is checks yr setup to ensure all the libaries needed are present as well as a working compiler. This creates abt a dozen files that tell "make" what to do.
./configure took about 5 minutes and went on fine.
make took half an hour and ended up as gcc : fork forbidden or something simsilar and the wholw thing went into the recycle bin. :( :cry:
I shall try extracting the source from my saved ZIP file again and try it all over again... Hope it works...
Initially I had to run the cygwin setup several times to get each of the package it kept asking for...
yer there are a few dependacies with Octave
from the EBUILD file (this list all the deps)
not to mention GCC
