New Feature: Syntax Highlighting
ElectroMaster
Administrator
Hi Guys,
I know alot of members have been asking for this, especially in the Microcontrollers forum.
It's really easy to use, simply use the code tag with a language parameter. There are heaps of languages to select:
[ CODE=c ]
[ CODE=c++ ]
[ CODE=asm ]
[ CODE=basic4gl ]
An example in C:
C:
/* This is a "Hello world" example for the dsPIC30F2020. It will toggle all
*  IO pins on the chip at a rate which is visible from a LED connected to
*  one of the IO pins. It uses the slow internal oscillator so all that is
*  needed is a 10K pullup resistor on MCLR (pin 1 on a 28 pin DIP chip) and
*  power connected to ALL Vdd, Vss, AVdd, and AVss pins. Don't forget to
*  put some 0.1uF bypass capacitors across the power pins close to the PIC.
#include <p30f2020.h>
_FOSC(CSW_FSCM_OFF & FRC_LO_RANGE & OSC2_IO); //Oscillator Configuration
_FOSCSEL(FRC); //Oscillator Selection
_FWDT(FWDTEN_OFF); //Turn off WatchDog Timer
_FGS(CODE_PROT_OFF); //Turn off code protect
_FPOR( PWRT_OFF ); //Turn off power up timer
int main(void)
	unsigned long x;
	ADPCFG = 0xffff; //make ADC pins all digital
	TRISA = 0; //Make all PORTs all outputs
	TRISB = 0;
	TRISD = 0;
	TRISE = 0;
	TRISF = 0;
	while(1)
		for( x=0; x<100000; x++){;} //Delay apx 200ms
		LATA = ~LATA; //Toggle all bits on ALL ports
		LATB = ~LATB;
		LATD = ~LATD;
		LATE = ~LATE;
		LATF = ~LATF;
	return 0;
section	.text
    global _start			;must be declared for linker (ld)
_start:					;tell linker entry point
	mov	edx,len	;message length
	mov	ecx,msg	;message to write
	mov	ebx,1	;file descriptor (stdout)
	mov	eax,4	;system call number (sys_write)
	int	0x80	;call kernel
	mov	eax,1	;system call number (sys_exit)
section	.data
msg	db	'Hello, world!',0xa	;our dear string
len	equ	$ - msg			;length of our dear string
Testing,
C:
//Write a string to the LCD
void PutMessage(rom char *Message){
char i=0;
    while(Message[i]!=0)
        PutChar(Message[i++]);
void SetPos(unsigned char X,unsigned char Y){
    Xpos=X;
    Ypos=Y;
    if(Y&1)
        X+=0x40;
    if(Y&2)
        X+=Width;
    WriteCommand(0x80+X);
//Set position and write string.
void PutMessageAt(unsigned char X,unsigned char Y,rom char *Message){
char i=0;
    SetPos(X,Y);
void PutHex(unsigned int Num,char Digits){
char i;
    Num<<=(4-Digits)*4;
    for(i=0;i<Digits;i++){
        PutNibble((Num>>12)&0x0f);
        Num<<=4;
Not sure about yellow on white. Can the colours be changed?
deleted post
deleted post
Ha! I love it! Thanks, EM :D
Just a question...How does this work if I put this
     movlw   0x5
     movwf   PORTA
it doesn't seem to work
Ian, try capitalizing "code" in "
" and see if it changes anything. That may be it--not sure how EM programmed this thing :D
Der Strom
