need a switch
andrew2022
i need a switch but dont know if this type is available
it has to have 3 options and double pole
on pole one it needs OFF/ON/ON
the secons pole needs to be OFF/OFF/ON
voltage will be 230VAC on pole 1, at lunder 1A
voltage will be 12VDC on pole 2, at under 1A
basically its to switch between 3, mains/auto and backup.
when set to mains, both need to be off. on auto, pole 1 needs to be on and pole 2 needs to be off and on backup, both need to be on
i have had a look thru some catalogues but couldnt find any
Based on the description of what you need, why not just use
a regular on-off-on switch? It seems that it would accomodate
what you need. They are easily available at the V/I you talk
about in DPDT.
