Multi-Engine T-Bar Fader Switch
dknguyen
Most Helpful Member
Finger-sized Multi-Throttle T-Lever
I'm looking for some finger-sized (as not hand-sized or full-sized) multi-engine throttle T-levers with 2 or 3 sliders. Pretty much like this:
So you can grab all the handles at once as a single handle to adjust everything at the same time, or grab them individually and adjust them independently. The closet one I found was this:
https://www.ikasinc.com/chproducts/halleffect_tbar.htm
But at $170 a pop, I'm just barely willing to get one...and not two to place side-by-side. The reason is for independent simultaneous control of flaps and spoilers on a sailplane for use as flaps, spoilers, or airbrakes. I could use a single lever and a switch that changes the mode of the lever but then I can only have airbrakes (spoilers+flaps), spoilers + zero flaps, or flaps + zero spoilers. So you wouldn't have immediate access to the airbrakes or be able to fly with spoilers with a fixed flap setting (or vice versa) which can be important.
