    Dismiss Notice
Measuring 2 Volt Cells in Parallel
Discussion in 'Renewable Energy' started by bryan1, Aug 4, 2012.
  1. bryan1
    bryan1 Well-Known Member
    Aug 4, 2004
    1,679
    46
    Adelaide Hills Sth Oz
    G'Day Guy's,
    The main problem with measuring 2 volt cells with a common ground is each cell will rise 2 volts on average so that causes a major problem using ADC on a pic. I have been talking with a mate over this issue and we came up will a possible solution that uses a RFpic say a RF12f675. Now by doing it this way each pic can measure 2 cells and have a IR sensor to be signalled when a packet needs to be sent. Each pic can be powered by 2 cells so power won't be a problem.
    This is one complicated idea but if any guy's have any easier way chime in as this is one project I want to do.
    Cheers Bryan
  2. Nigel Goodwin
    Nigel Goodwin Super Moderator Most Helpful Member
    Nov 17, 2003
    39,228
    641
    Derbyshire, UK
    I'm a bit confused about exactly what you're trying to do?.
    Do you mean you've got a number of lead/acid (2V) cells in series, and you want to individually measure the voltage of each cell?.
    Simply use a DPDT relay for each cell, and switch both ends of the individual battery you're testing to the PIC monitoring circuit.
  3. nickelflippr
    nickelflippr Member
    Oct 20, 2006
    891
    18
    Oregon, USA
    Any modern PIC of say 18 pins is going to have 12 adc (e.g. 16f1827) and up from there to 30 channels on a 40 pin device (e.g. 18f46k22). Hook them up, and just subtract the previous reading from the next one up the ladder of 2V battery cells.
    EDIT: Of course you would have to use a voltage divider to cover the range of the overall battery pack :)
    • Like Like x 1
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. alec_t
    alec_t Well-Known Member Most Helpful Member
    Jul 10, 2011
    9,255
    1,218
    Cardiff, Wales
    If the 2V cells are in parallel, as the post title states, then they will all have the same terminal voltage; so a single-channel ADC will suffice.
Share This Page
