    Dismiss Notice
Maximizing volume on ISD1700
Discussion in 'General Electronics Chat' started by mik3ca, Sep 3, 2017.
  1. mik3ca
    mik3ca Member
    Jun 24, 2017
    208
    1
    Is there a way I can maximize sound volume with the ISD1700 so that I can hear it at least 1 meter away in a room through a 4.5W 8 ohm speaker?
    I asked because then I tried using an LM386 with it, I was told that I'd get worse results when I hooked the LM386 to the analog output pin.
    So I wondered at first if the analog in section could be improved on. I know it says 0.1uF capacitor but I used 0.047uF because thats what I can get an abundance of dirt cheap and because its more compact and filters out hum better. The good news is I can still record and playback audio with the 0.047uF capacitor. This is what the datasheet says about the analog input:
    Now what really gets me is the AGC pin. They say use 4.7uF capacitor between AGC and ground. Here's the datasheet details:
    Since I'm recording sound directly from my laptop's earphone output, could I just directly ground this pin to get max gain and adjust the volume from the laptop until I get max volume without distortion, then all my problems be solved? or should I use a lower capacitor value?
    or am I thinking this all wrong?
    Here's a link to the datasheet:
    http://www.nuvoton.com/resource-files/EN_ISD1700_Datasheet_Rev-2.0.pdf
  2. Nigel Goodwin
    Nigel Goodwin Super Moderator Most Helpful Member
    Nov 17, 2003
    39,319
    653
    Derbyshire, UK
    ONLINE
    As was explained endlessly in your previous thread, power output is restricted by the supply voltage you're using - to add a more powerful amplifier you first need a higher supply voltage for it.
  3. audioguru
    audioguru Well-Known Member Most Helpful Member
    Mar 16, 2004
    32,572
    950
    Canada, of course!
    The preamplifier and AGC are for the microphone input that you are not using.
    Aren't you using a 5V supply? Then the maximum output to an 8 ohm speaker connected to both speaker terminals is about 0.5W which is like a cheap clock radio.
    Maybe the headphones output of your laptop is too low. The input level should be 1V p-p.
    Does the volume control button work so that you can increase and decrease the volume? When the volume is increased to maximum output level then the sound will be distorted if the volume is increased higher. Does this happen?
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. mik3ca
    mik3ca Member
    Jun 24, 2017
    208
    1
    So I guess I wasted a capacitor then
    Well if a cheap clock radio is loud enough then I'd be happy. I guess I'll add a class-d amplifier powered by a higher voltage to the analog output.
    With the AGC capacitor in place I haven't heard distortion. I can change the volume of the laptop's earphone output.
  6. audioguru
    Mar 16, 2004
    32,572
    950
    Canada, of course!
    The datasheet says (and its block diagram shows) that the microphone preamp has AGC (not the aux input).
    You should be able to turn up the volume controls until the amplifier output clips like mad producing severe clipping distortion. Your laptop signal is too low for this chip.
  7. mik3ca
    mik3ca Member
    Jun 24, 2017
    208
    1
    Ok, so I need a larger input signal source to make distortion. Would the AGC stop distortion though? This part confuses me. Well at least if I get a teensy amount of distortion then I know I'm on the right track because then I can turn the volume down somewhat at the source to correct things.
  8. audioguru
    Mar 16, 2004
    32,572
    950
    Canada, of course!
    Why don't you understand that the microphone preamp has AGC but you do not have a microphone. The Aux input does not have AGC.
    AGC is "automatic gain control" so that when you scream into the microphone the AGC detects that the input signal is too high then it reduces the gain so that the output has no clipping distortion.
    If the input signal into the aux input is too high then the output to the speaker will have clipping distortion.
    The mic input can be attenuated but since its circuit is a differential and your laptop signal is not then it would be difficult without seeing its schematic of the circuit that is inside the IC.
Share This Page
