Low power relay
Scarr
Hi all,
I want to switch 2A @ 3.4-3.9v with a ATtiny13 MCU what is the best way t do this with the least components, SSR, Relay? Ideally I want a pin from MCU to pin of XXX that is then used to switch the voltage on/off
Thx
Scarr said:
Hi all,
Thx
Look for SSR. you buy those to switch your mentioned conditions.
They typically have a diode on input with a series limiting resistor and only require about 10mA to drive. The resistor can be very small.
The ones I have found are 3v and my I/O Pin will be 2.5v
I will be running the MCU at between 3.4v and 3.6v and the spec sheet for the ATtiny13 says that at 3v the min output voltage from a I/O pin will be 2.5v (page 119 of the spec sheet) it does not give a typical or max voltage and I can't see a graph that gives a I/O voltage based on VCC.
Having said that, the PDF is a little confusing for a novice like me so it might be in there.
All the SSR I have found require 3v to turn them on.
Thx
Re: The ones I have found are 3v and my I/O Pin will be 2.5v
Thx
umm look at this guy. Mosfet isolated SSR
Its small, you can drive the LED with 10mA so 3V I/O is fine. It can switch 2A
Positive side switching
Thnaks Optikon for that,
looking at the spec it shows switching on the negative side, I want to switch on the live sideis this OK with this device?
Thx
Does anyone know?
Does anyone know if I can use the above mosfet relay on the positive supply to the load?
