Loading 2200µF with 30V
Exo
Active Member
I've made a circuit here and i'm trying to test it ... It's unloaded so for safety purposes i use a 1A fast fuse.
The fuse blows immediately, but i can't find anything wrong with the circuit. everything measures out fine.
Could it be that the initial loading current of the 2200µF capacitor is so high it makes the fuse blow ?
2200µF at 30V would that draw a currentspike enough to blow a 1AF fuse ?
Quite probably - you shouldn't use a fast blow fuse for something like that.
Personally I only ever use anti-surge fuses, in fact they are all we stock at work!.
If you want to keep such a fuse rating for normal operation you can do one of two things.
you can put the fuse after the capacitor, thus initial in-rush will go into cap and thus the main cct will not see the rush of current - IF there is a prob with the cap no protection.
OR (a better option) is use a pre-charge resistor. This resistor limits the charging current to the DC-link capacitor, when it reaches a preset threshold short out the resistor with either a Thyristor or another switching device.
or as Nigel said up-rate the fuse, just some ideas
