    Dismiss Notice
Linear vreg Thermal spreader
Discussion in 'Electronic Projects Design/Ideas/Reviews' started by Mosaic, Jul 13, 2017.
  1. Mosaic
    Mosaic Well-Known Member
    Jun 3, 2010
    2,568
    128
    Caribbean
    This is useful enough to bear repeating.
    If u have a design and discover your v.reg is running too hot due to a large voltage drop, offloading the heaitng with a couple resistors in parallel can save the day.
    I had a design that spec'd the D2 PAK size LM317 surface mount part. But due to limited PCB space it was downgraded to the smaller D-PAK case.
    Eventually I discovered the unit was running at about a 72°C delta:arghh:.
    No space for a heatsink...what to do?:confused:
    The Vreg was dropping 8.4V @ 120mA.
    I squeezed in a couple 39Ω , 0805 resistors in parallel and placed them 1mm away from the 1/4" spade terminal Vcc input for heat dissipation. I added a soldermask stop to permit thick solder on the 1mm PCB trace length. The resistors drop about 2.4V and have a 50°C delta. The LM317 also has a 50°C delta now.:) Without the 1/4" spade terminal the resistors have a 75°C delta.
    The 50°C delta is useful as the module being designed might have to sit in subzero temps and not form condensation on the PCB. Sealed Enclosure Air volume is only 0.02L
  2. crutschow
    crutschow Well-Known Member Most Helpful Member
    Mar 14, 2008
    10,592
    477
    L.A., USA Zulu -8
    I assume you mean the resistors are in series with the regulator input, not in parallel.
  3. MikeMl
    MikeMl Well-Known Member Most Helpful Member
    Mar 17, 2009
    11,044
    541
    AZ 86334
    If the load on the regulator varies, say +- 25% of its average load, you could put a resistor around (in parallel with) the regulator. That might help if the regulator is already operating close to its dropout voltage.
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. ci139
    ci139 Active Member
    Apr 12, 2012
    389
    34
    39/2*(0.12,0.06,0.03,...) ≉8.4 -- e.g. which is not the case this time
    see Power Sharing Resistor p.53
  6. Mosaic
    Jun 3, 2010
    2,568
    128
    Caribbean
    Actually, since my load is about 120mA, I did both series (20Ω net) and parallel (500Ω net) resistors to obtain a 35°C improvement in the V reg op temp.
  7. ci139
    ci139 Active Member
    Apr 12, 2012
    389
    34
    i've used parallel resistance as an extreme last measure to quiet a noisy supply's switch element in few occasions
  8. AnalogKid
    AnalogKid Well-Known Member
    Sep 22, 2011
    1,103
    160
    Ohio - GMT-5
    As long as there is a firm minimum load current, parallel will work.
    ak
Share This Page
