    Dismiss Notice
Is this Real ?Free Energy Magnet Motor fan used as Free Energy Generator "Free Energy" light bulb
Discussion in 'Alternative Energy' started by Jeez, Oct 29, 2016.
Thread Status:
  1. Jeez
    Jeez New Member
    Oct 29, 2016
    8
    0
    bangalore
    Hi ,
    Can anyone please let me know is this fake , if fake why ? if not what are the pros and cons of this method to generate electriccity
  2. MaxHeadRoom78
    MaxHeadRoom78 Active Member
    Jun 9, 2015
    888
    71
    Canada Geog Cen of N.A.
    No1 the fan has to generate enough power to light the lamp, any load presented to the fan (generator) has to provide the same energy in as is required to light the lamp, in other words you don't get anything for nothing, any P.M. motor will usually act as a generator provided the input power is sufficient for the load, I could not play the video so I don't know how the fan blades are being rotated.
    Max.
  3. nsaspook
    nsaspook Well-Known Member
    Mar 24, 2010
    1,141
    219
    Fairview, Or
    Yes, it works. Just add one fool.
    • Agree Agree x 4
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. chemelec
    chemelec Well-Known Member
    Apr 4, 2004
    2,122
    77
    Hedley, B.C. Canada
    You have to Play the Video on YouTube, Not on this forum.
    Once Started to spin the fan, It Will light the bulbs, If the Magnet is in correct position, But it will not generate much power.
  6. cowboybob
    cowboybob Well-Known Member Most Helpful Member
    Oct 22, 2011
    3,037
    478
    James Island, SC
    Welcome to ETO, Jeez!
    Thousands of these "free energy" scams on the net. Don't believe any of them. The Laws of Physics dictate that you can not get something from nothing.
    Google "entropy" and the 2nd law of thermodynamics.
    • Like Like x 1
    • Agree Agree x 1
  7. tcmtech
    tcmtech Well-Known Member Most Helpful Member
    Feb 22, 2009
    6,677
    429
    Sawyer, North Dakota, USA
    The way I have always explained as what could be commonly seen as 'Free energy'/overunity is,
    'If you're really smart enough to figure out how to make it really you're also wise enough to know why to keep it to yourself and why it's not for the reasons everyone thinks you would." ;)
  8. nsaspook
    Mar 24, 2010
    1,141
    219
    Fairview, Or
    If you're really smart enough to figure out how to make it then you won't switch it on because that will likely be the last thing you do along with maybe a sizable part of the country from the energy-feedback explosion. With an efficiency of 110%, you could still get unlimited power output easily and maybe in milliseconds(the OU process might be FTL so it could blow-up before you switched it on) . That's too short to say the F-word before you're vaporized into atoms.
    [​IMG]
    [​IMG]
    • Like Like x 1
  9. audioguru
    audioguru Well-Known Member Most Helpful Member
    Mar 16, 2004
    32,513
    942
    Canada, of course!
    The "generator" looked like a DC computer fan with little magnets mounted on its blades. Bringing another magnet near it "at the correct angle" will not cause it to continuously spin.
    I wonder why the lights blinked on and off when the "fan" was spinning pretty fast. The lights should have been steady if something (some wind?) was propelling the fan.
  10. Nikolai Petrenko
    Nikolai Petrenko Member
    Oct 8, 2015
    399
    16
    Vietnam-motherland
    Hmm, seem be the light bulbs had powered by room's THERMAL®®® energy. Then the bulb generated electricity. Then it cause the fan rotated. The man put his hand above the fan just for cooling because the room so HOT®®® (so "THERMALLY")!!! :D :D :D
  11. spec
    spec Well-Known Member Most Helpful Member
    Oct 27, 2015
    5,828
    709
    Somerset UK GMT
    There are two tests you can do with any proposition in life:
    (1) Is it too good to be true
    (2) If it were true, what would the consequences
    Any over unity energy scheme falls flat on it's face on both counts.:D
    spec
  12. crutschow
    crutschow Well-Known Member Most Helpful Member
    Mar 14, 2008
    10,610
    478
    L.A., USA Zulu -8
    Not to get too technical, a fundamental law of Mother Nature is "There's no free lunch." :rolleyes:
  13. Nikolai Petrenko
    Oct 8, 2015
    399
    16
    Vietnam-motherland
    Yes, I see the effect like you. The bulbs blinking pretty constantly while the speed of the propeller was serious varied. Seem be the bulbs are lit by a hidden wireless generator.
  14. DerStrom8
    DerStrom8 Super Moderator Most Helpful Member
    Aug 9, 2010
    5,500
    503
    Vermont (GMT-5:00)
    • Informative Informative x 1
  15. tcmtech
    Feb 22, 2009
    6,677
    429
    Not turning it on and just not telling everyone about what you have are two different things. ;)
    If you have a device that lets you live your life at whatever terms and freedom you want without hassle are you really going to mess that up for life by becoming a permanent public spectacle of yourself with zero privacy for the rest of your life? :(
    If you have the technical mindset, skills and discipline to create such a device that uses a non conventional power source to produce an excess of usable common form energy you're also of the mindset that likely sees the point of having fame and high levels of public recognition as being counter productive to your lifestyle and that's just the tip of the situations and problems that come into play. :rolleyes:
    As I said, If you know how to make it work you know why you keep your mouth shut and it isn't for the reasons everyone else may think. If you want to use it to save the world you go do it through proxies and not directly yourself. Fame and fortune are little more than a golden cage. A very small golden cage compared to being an anonymous nobody who can do what they want and go where they want without recognition or hassle.
    But what do I know? I'm just a free range bum who only does normal jobs for fun when he feels like they might be interesting enough to pursue for while and spends the majority of his life doing as he pleases and has done so since his 20's for reasons most can't begin to grasp that obviously still has all his needed molecules intact. :troll:
  16. Nigel Goodwin
    Nigel Goodwin Super Moderator Most Helpful Member
    Nov 17, 2003
    39,290
    647
    Derbyshire, UK
    Pointless thread moved to 'correct' forum and closed.
    Moderator.
    • Like Like x 2
Thread Status:
Share This Page
