interfacing ADC0808 with 89C51
code to interface 0808 with 89c51 and display result on LCD
mnoman said:
do any one have code for interfacing ADC0808 with 89C51
I used port 1 of 89c51 to read data from 0808 and port3 to display data at LCD.The assembly code is:
;;;;======================== LCD================================:
;PORT 3 is used for 8bit data :
; p3.7 is used as busy flag :
; p2.0 for RS select to select command or DATA register :
; P2.1 for R/W :
; P2.2 E to Enable latch :
;;;;========================= ADC ==============================:
; PORT 1 for 8bit data ;
; P 2.7 EOC intrupt to UC that conversion is complete ;
; P 2.6 SC to start conversion ;
; P 2.5 OE for read operation to get converted data for ADC toUC;
; p 2.4 for ALE ;
; p 0.0,p0.1,p0.2 for chanel selection ;
org 0
BEGIN:
mov A,#38h ;initialie 2 line LCD
ACALL command
mov A,#0ch ;LCD on cursor off
ACALL command
mov A,#01h ;clear LCD
ACALL command
mov A,#06h ;Shift cursor right
ACALL command
mov A,#'V'
ACALL DISPLY
mov A,#'O'
ACALL DISPLY
mov A,#'L'
ACALL DISPLY
mov A,#'T'
ACALL DISPLY
mov A,#'A'
ACALL DISPLY
mov A,#'G'
ACALL DISPLY
mov A,#'E'
ACALL DISPLY
mov A,#'='
ACALL DISPLY
ACALL ADC
ACALL BINTOASC
;;;;;;;;;;;;;;;;;;;;;DISPLAY ASCII NUMBERS;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
ACALL command
mov A,34h ;Disply MSb of ASCII
ACALL DISPLY
ACALL command
mov A,33h ;Display middle ASCII
ACALL DISPLY
ACALL command
mov A,32h ;DISPLAY LSb ASCII
ACALL DISPLY
mov A,#'m'
ACALL DISPLY
mov A,#'V'
ACALL DISPLY
jmp BEGIN ;Jump to the top repeat the whole process
;;;;;;;;;;;;;;;;;;;TO INIALIZE LCD BY;;;;;;;;;;;;;;;;;;;
command:
ACALL READY ;Is LCD ready
mov p3,A ;Issu command
clr p2.0 ;RS=0 for comand instruction
clr p2.1 ;R/W=0 to write LCD
setb p2.2 ;H->L for to latch information in at data lines
clr p2.2
ret
;;;;;;;;;;;;;;;;;;TO DISPLAY USER DATA;;;;;;;;;;;;;;;;;;;;;
DISPLY:
ACALL READY
mov p3,A ;Issu data
setb p2.0 ;RS=1 for data
clr p2.2
ret
;;;;;;;;;;;;;;;;;TO CHECH LCD READY TO RECIEVE DATA TO SHOW;;;;;;;;;;;;;;;;;;;;;;;;;
READY:
setb p3.7
clr p2.0 ;RS=0 for command register
setb p2.1 ;R/W=1 to read command register
BACK:
clr p2.2 ;H->L to latch the data
setb p2.2
jb p3.7,BACK ;Busy flag(P1.7)=1 indicates LCD is not ready to recieve data
ret
;;;;;;;;;;;;;;;;;;;;;;;;;;READS ADC DATA;;;;;;;;;;;;;;;;;;;;;;
ADC:
mov p0,#0fFh
clr p0.0 ;Address 000 to select chanel 0
clr p0.1
clr p0.2
clr p2.4 ;L->H for ALE enable
setb p2.4
setb p2.6 ;SC=1->0
clr p2.6 ;H->L to start conversion
WAIT:
JB p2.7,WAIT ;Wait for end of conversion EOC
setb p2.5 ;OE 1->0 to enable output from ADC
clr p2.5
mov A,p1 ;Read data
MOV 35H,A
setb p2.5 ;To disable read to start next conversion
setb p2.7
ret
;;;;;;;;;;;;;;;;;;;;;;;;;;;;;BINARY TO ASCII CONVERSION;;;;;;;;;;;;;;;
BINTOASC:
mov A,35h ;Input from ADC
mov B,#10 ;Divide by 10
div AB
mov r0,B ;Move remainder into R0
mov B,#10
div AB ;Divide quatient by 10
mov r1,b ;Move remainder in R1
mov r2,A ;Move quatient in R2
mov A,r1 ;Move second BBCD in A
swap A
orl A,r0 ;OR 3rd & 2nd BCD to form compact BCD
mov 30h,A ;Saves 2nd&3rd BCD at RAM location 30h
mov 31h,r2 ;Saves 1st BCD at RAM location 31h
;;;;;;;;;;;;;;;;;;;;;;;;;;CONVERTION FROM BCD TO ASCII;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
mov A,30h ;Takes 2nd&3rd BCD from RAM location 30h
ANL A,#0fh ;Mask the upper NIBBLE
orl A,#30h ;Convert lower nibble in ASCII
mov 32h,A ;Save MSb ASCII at RAM location 32H
mov A,30h ;Move BCD into A from RAM location 30H
anl A,#0f0h ;Mask lower NIBBLE of BCD
swap A ;Interchange lower and higher NIBBLE
orl A,#30h ;Convert it in ASCII
mov 33h,A ;Save 2nd ASCII at RAM location 33H
mov A,31h ;Takes 1st BCD from RAM location 31H
anl A,#0fh ;Masks upper nibble
orl A,#30h ;COnvert into ASCII
mov 34h,A ;Saves MSb ASCII at RAM location 34H
ret
end
