I'm using 2 x 400V caps in series. They are the same capacitors used on a 415V VSD I opened from a major and well known manufacturer. Can you tell me what's wrong with the inductor wiring? I'm not sure about the size and whether I made it large enough.
If you need to have this run on 415V why not combine your $80 240V unit with a 415/240 stepdown transformer?
In the schematic you posted, you also show "COM" pin#21 wired to the Vss pin. It, COM, is the return from the IGBT's not to be wired to signal ground,Vss.
it looks to be a common mode inductor and they are supposed to be wired series opposing and it looks like you are showing the wires crossed to be series adding.
general rule of thumb is 1000uF/A, though you need to check the ripple rating that it is over 1.5 times the load current.
dan
So you want US to debug your product so YOU can make money off of it?
5000 units at $100+ profit each. $500K+ in your pocket and we get what for our part of the work?
Hey guys,
Just so you know, I have a degree in Electronics Engineering. Oh, and I graduated with first class honours. I have been designing circuits for about 5 years now. I definitely wouldn't say I am an expert, but I can usually hold my own.
