This implant is HID WG26 compatible it uses a CET5500 chip.
This implant is re-wirteable both the site code and identifier codes can be re-written.
I only have 5 and these were a engineering sample from a RFID manufacture.
They are 2mmX 8mm.
I will include a ready to use sterile injector that is preloaded with a 13.5mhz animal ID tag.
but you must sterilize the 125.5mhz tag before implanting it.
I strongly suggest that you have it done by a body piercing professional or a DR.
If you can get a DR to do it he can use local anesthesia.
I have had this implant and two others in my left hand for the last 3 years with no ill-effect.
I copied my access badge RFID codes for my work to my implant and I don't have to worry about losing my badge by taking it on and off to open doors.
This device is very rare and only 10 were made.
I am asking only $20.00 each, that includes the 125.5khz implant , 13.5mhz implant (inside the injector) and the sterile injector.
You will need a RFID read/writer to program the implant. Or if you have control access to the access system you can just simply add the code that is already on the chip by reading the chip at one of the readers in the system.
I do have other 125.5 kHz implants that are EM based .
They are 2mmX 8mm.
