Help with visual basic animation
Hi people,
can someone help on how to write a code on how to increase and decrease the time interval of the timer in the scroll bar procedure as stated on the attached file of this thread?
thanks.
Which file is that.?
EDIT: hint.
The timer interval is in millisec.
In the HScroll1 bar Properties set Min Max to say 0 and 1000, thats a max of 1second.
Set the Timer1.Interval to HScroll1.value
Use a Label.caption to display the Int(HScroll1.value /10) as a percentage.
Hi Eric,
The file i attached to this original thread,word document of my homework on the visual basic animation.
Hi Eric,
I thought it may be that file, the hints my last post should get you started, if not just ask.
Thanks Eric, I think I understand what you said it your previous post.I will give it a try before I ask.
Thank you.
My Bad and sorry as I did not see the more recent post and posted the code sample. There is really no change in using a VScroll in VB 4, 5, 6 or the newer versions.
Ron
