i found a code that is used with lcd i understood most of it but there's still one part that i didn't understand actually the code is written for a micro that i don't know how to use i only know the pic family 16f and 18fthis part of the code that i didn't understand is:; Procedure of step by step and scan
STP_SC:
MOV C,S_S
JC STEP
RET
STEP:
MOV C,STP
MOV R5,#0FH
LOPE:
MOV R6,#0FFH
LOPH:
DJNZ R6,LOPH
DJNZ R5,LOPE
JNB S_S,LOUT
JNC STEP
LOUT:
RET
the whole code is this:
; KS0107,KS0108
.SYMBOLS
; DEFINE OUTPUT PORORT
RS REG P3.0
E REG P3.4
CS1 REG P3.3
CS2 REG P3.5
R_W REG P3.7
STP REG P2.0
S_S REG P2.1
BCD EQU 01H
ORG 0H
LJMP START
ORG 50H
START: ;program reset start here
;INITIAL
MOV A,#40H ;Set Y Column Address >From 0
LCALL WRITE_COMMAND1
LCALL WRITE_COMMAND2
MOV A,#B8H ;Set Page From 0
MOV A,#C0H ;Set Display Start Line
MOV A,#3FH ;Set Display ON
; FULL ON
FULL_ON:
MOV R0,#0
MOV R1,#0
FOLOOP1:
MOV A,R1 ;Set Page Address FROM 00H
ORL A,#B8H ;Command B8H~BFH
CALL WRITE_COMMAND1
CALL WRITE_COMMAND2
MOV A,#40H ;Set Column Address FROM 40H
CALL WRITE_COMMAND1
CALL WRITE_COMMAND2
MOV R0,#0 ;Rest Counter
FOLOOP2: ;Write Data To Chip I
MOV A,#FFH
CALL WRITE_DATA1
INC R0
CJNE R0,#64,FOLOOP2
FOLOOP3: ;Write Data To Chip II
MOV A,#FFH
CALL WRITE_DATA2
INC R0
CJNE R0,#128,FOLOOP3
INC R1
CJNE R1,#8,FOLOOP1
LCALL DELAY
LCALL STP_SC
SJMP SHOWM
; SHOW MODEL
SHOWM:
MOV R0,#0
MOV R1,#0
MOV DPTR,#SHOW_WG
SMLOOP1:
MOV A,#B8H ;Set Page Address FROM 00H
ADD A,R1 ;Command B8H~BFH
CALL WRITE_COMMAND1
CALL WRITE_COMMAND2
CALL WRITE_COMMAND1
CALL WRITE_COMMAND2
SMLOOP2: ;Write Data To Chip I
XRL A,A
MOVC A,@A+DPTR
CALL WRITE_DATA1
INC R0
INC DPTR
CJNE R0,#64,SMLOOP2
SMLOOP3: ;Write Data To Chip II
XRL A,A
MOVC A,@A+DPTR
CALL WRITE_DATA2
INC R0
INC DPTR
CJNE R0,#128,SMLOOP3
INC R1
CJNE R1,#8,SMLOOP1
LCALL DELAY
LCALL STP_SC
SJMP VLINE
; VERTIAL LINE
VLINE:
MOV R0,#0
MOV R1,#0
VLLOOP1:
CALL WRITE_COMMAND1
CALL WRITE_COMMAND2
CALL WRITE_COMMAND1
CALL WRITE_COMMAND2
VLLOOP2: ;Write Data To Chip I
MOV A,#FFH
CALL WRITE_DATA1
INC R0
MOV A,#00H
CALL WRITE_DATA1
INC R0
CJNE R0,#64,VLLOOP2
VLLOOP3: ;Write Data To Chip II
MOV A,#FFH
CALL WRITE_DATA2
INC R0
MOV A,#00H
CALL WRITE_DATA2
INC R0
CJNE R0,#128,VLLOOP3
INC R1
CJNE R1,#8,VLLOOP1
LCALL DELAY
LCALL STP_SC
SJMP HLINE
; HORIZONTAL LINE
HLINE:
MOV R0,#0
MOV R1,#0
HLLOOP1:
CALL WRITE_COMMAND1
CALL WRITE_COMMAND2
CALL WRITE_COMMAND1
CALL WRITE_COMMAND2
HLLOOP2: ;Write Data To Chip I
MOV A,#AAH
CALL WRITE_DATA1
INC R0
CJNE R0,#64,HLLOOP2
HLLOOP3: ;Write Data To Chip II
MOV A,#AAH
CALL WRITE_DATA2
INC R0
CJNE R0,#128,HLLOOP3
INC R1
CJNE R1,#8,HLLOOP1
LCALL DELAY
LCALL STP_SC
SJMP CROSS_DOT
; BIG CROSS DOT
CROSS_DOT:
MOV R0,#0
MOV R1,#0
CDLOOP1:
CALL WRITE_COMMAND1
CALL WRITE_COMMAND2
CALL WRITE_COMMAND1
CALL WRITE_COMMAND2
CDLOOP2: ;Write Data To Chip I
MOV A,#CCH
CALL WRITE_DATA1
CALL WRITE_DATA1
MOV A,#33H
CALL WRITE_DATA1
CALL WRITE_DATA1
INC R0
CJNE R0,#16,CDLOOP2
CDLOOP3: ;Write Data To Chip II
MOV A,#CCH
CALL WRITE_DATA2
CALL WRITE_DATA2
MOV A,#33H
CALL WRITE_DATA2
CALL WRITE_DATA2
INC R0
CJNE R0,#32,CDLOOP3
INC R1
CJNE R1,#8,CDLOOP1
LCALL DELAY
LCALL STP_SC
SJMP SHOWC
; SHOW CHARACTER
SHOWC:
MOV R0,#0
MOV R1,#0
MOV DPTR,#SHOW_CH
SCLOOP1:
CALL WRITE_COMMAND1
CALL WRITE_COMMAND2
CALL WRITE_COMMAND1
CALL WRITE_COMMAND2
SCLOOP2: ;Write Data To Chip I
XRL A,A
MOVC A,@A+DPTR
CALL WRITE_DATA1
INC R0
INC DPTR
CJNE R0,#64,SCLOOP2
SCLOOP3: ;Write Data To Chip II
XRL A,A
MOVC A,@A+DPTR
CALL WRITE_DATA2
INC R0
INC DPTR
CJNE R0,#128,SCLOOP3
INC R1
CJNE R1,#8,SCLOOP1
LCALL DELAY
LCALL STP_SC
LJMP START ;repeat test
CHK_BUSY:
MOV P1,#0FFH ;SET PORT1=INPUT
CLR RS ;SET IR MODE RS=0
SETB R_W ;SET READ MODE R/W=1
SETB E ;ENABLE LCM
MOV C,P1.7 ;CHECK BUSY FLAGE(BIT7)
CLR E
JC CHK_BUSY
RET
; DELAY
DELAY:
CALL CBCD
MOV R4,BCD
LOPC:
MOV R5,#2FH
LOPB:
MOV R6,#0FFH
LOPA:
DJNZ R6,LOPA
DJNZ R5,LOPB
DJNZ R4,LOPC
RET
;* Timing
WRITE_COMMAND1: ;Write Command To CS1
CLR CS1
SETB CS2
CLR RS
CLR R_W
MOV P1,A
SETB E
NOP
CLR E
RET
WRITE_DATA1: ;Write Data To CS1
CLR CS1
SETB CS2
SETB RS
CLR R_W
MOV P1,A
SETB E
NOP
CLR E
RET
WRITE_COMMAND2: ;Write Command To CS2
CLR CS2
SETB CS1
CLR RS
CLR R_W
MOV P1,A
SETB E
NOP
CLR E
RET
WRITE_DATA2: ;Write Data To CS2
CLR CS2
SETB CS1
SETB RS
CLR R_W
MOV P1,A
SETB E
NOP
CLR E
RET
STP_SC:
MOV C,S_S
JC STEP
RET
STEP:
MOV C,STP
MOV R5,#0FH
LOPE:
MOV R6,#0FFH
LOPH:
DJNZ R6,LOPH
DJNZ R5,LOPE
JNB S_S,LOUT
JNC STEP
LOUT:
RET
; BCD DELAY TIME SELECT
CBCD:
PUSH A
MOV A,P0
ANL A,#0FH
RL A
RL A
MOV BCD,A
POP A
RET
;* DISPLAY DATA
SHOW_CH:
DB 0FFH,01H,01H,01H,01H,0C1H,01H,01H
DB 01H,01H,01H,01H,0C1H,0C1H,01H,0C1H
DB 0C1H,01H,01H,01H,0C1H,01H,01H,01H
DB 0C1H,01H,01H,01H,81H,81H,0E1H,81H
DB 81H,01H,01H,81H,41H,81H,01H,01H
DB 01H,01H,01H,81H,41H,41H,41H,81H
DB 01H,01H,01H,01H,01H,0C1H,0C1H,01H
DB 01H,01H,01H,01H,01H,01H,01H,81H
DB 41H,01H,01H,01H,41H,81H,01H,01H
DB 01H,01H,01H,01H,01H,01H,01H,01H
DB 01H,01H,01H,01H,81H,41H,41H,41H
DB 81H,01H,01H,01H,01H,81H,0C1H,01H
DB 81H,01H,01H,01H,81H,41H,41H,41H
DB 81H,01H,01H,01H,01H,01H,01H,0FFH
DB 0FFH,00H,00H,00H,00H,9FH,00H,00H
DB 00H,00H,00H,00H,02H,01H,00H,02H
DB 01H,00H,00H,41H,0FFH,41H,41H,41H
DB 0FFH,41H,00H,67H,88H,88H,0FFH,88H
DB 88H,73H,00H,41H,22H,11H,08H,0C4H
DB 22H,0C1H,00H,0E3H,14H,08H,14H,0A3H
DB 0C0H,20H,00H,00H,00H,02H,01H,00H
DB 00H,00H,00H,00H,00H,00H,3EH,0C1H
DB 00H,00H,00H,00H,00H,0C1H,3EH,00H
DB 00H,00H,00H,08H,08H,08H,7FH,08H
DB 08H,08H,00H,00H,14H,08H,3EH,08H
DB 14H,00H,00H,03H,00H,00H,0B0H,08H
DB 08H,07H,00H,00H,01H,00H,0FFH,00H
DB 00H,00H,00H,0C3H,20H,10H,10H,08H
DB 08H,07H,00H,41H,80H,08H,08H,08H
DB 94H,63H,00H,00H,00H,00H,00H,0FFH
DB 0FFH,00H,00H,00H,00H,01H,0C0H,20H
DB 0F0H,00H,00H,0F0H,10H,10H,10H,10H
DB 10H,00H,00H,0C0H,21H,10H,10H,10H
DB 21H,40H,00H,70H,10H,10H,13H,90H
DB 50H,30H,00H,0C0H,20H,10H,10H,10H
DB 21H,0C0H,00H,0C0H,21H,11H,11H,10H
DB 20H,0C1H,00H,0E0H,10H,10H,10H,90H
DB 70H,0E0H,00H,00H,00H,80H,80H,00H
DB 01H,00H,00H,00H,01H,80H,80H,00H
DB 00H,00H,00H,40H,20H,10H,10H,10H
DB 20H,0C0H,00H,00H,00H,00H,00H,00H
DB 80H,40H,00H,00H,00H,00H,01H,00H
DB 00H,00H,00H,00H,00H,01H,01H,01H
DB 00H,00H,00H,81H,41H,21H,11H,21H
DB 41H,81H,00H,0F0H,10H,11H,11H,11H
DB 20H,0C0H,00H,00H,00H,00H,00H,0FFH
DB 0FFH,00H,00H,10H,1CH,13H,10H,10H
DB 7FH,10H,00H,13H,22H,41H,41H,41H
DB 22H,1CH,00H,1FH,22H,41H,41H,41H
DB 22H,1CH,00H,00H,00H,00H,7EH,01H
DB 00H,00H,00H,18H,25H,42H,42H,42H
DB 25H,18H,00H,11H,22H,44H,44H,44H
DB 22H,1FH,00H,3FH,70H,4CH,42H,41H
DB 40H,3FH,00H,00H,00H,0B1H,71H,00H
DB 00H,00H,00H,00H,00H,31H,31H,00H
DB 00H,00H,00H,3EH,41H,41H,3EH,40H
DB 40H,3FH,00H,10H,08H,04H,02H,01H
DB 00H,00H,00H,00H,00H,0B0H,70H,00H
DB 00H,00H,00H,00H,00H,60H,60H,00H
DB 00H,00H,00H,7FH,08H,08H,08H,08H
DB 08H,7FH,00H,7FH,42H,42H,42H,42H
DB 25H,18H,00H,00H,00H,00H,00H,0FFH
DB 0FFH,00H,00H,0F0H,08H,04H,04H,04H
DB 08H,10H,00H,04H,0FCH,04H,04H,04H
DB 08H,0F0H,00H,0FCH,84H,84H,84H,84H
DB 84H,04H,00H,0FCH,84H,84H,84H,84H
DB 84H,04H,00H,0F0H,08H,04H,04H,84H
DB 88H,90H,00H,0FCH,80H,80H,80H,80H
DB 80H,0FCH,00H,00H,00H,04H,0FCH,04H
DB 00H,00H,00H,00H,00H,00H,00H,04H
DB 0FCH,04H,00H,0FCH,80H,40H,20H,10H
DB 08H,04H,00H,00H,0FCH,00H,00H,00H
DB 00H,00H,00H,0FCH,08H,10H,60H,10H
DB 08H,0FCH,00H,0FCH,08H,30H,0C0H,00H
DB 00H,0FCH,00H,0F0H,08H,04H,04H,04H
DB 08H,0F0H,00H,0FCH,04H,04H,04H,04H
DB 88H,70H,00H,0F0H,08H,04H,04H,04H
DB 08H,0F0H,00H,00H,00H,00H,00H,0FFH
DB 0FFH,00H,00H,07H,08H,10H,10H,10H
DB 08H,04H,00H,10H,1FH,10H,10H,10H
DB 08H,07H,00H,1FH,10H,10H,10H,10H
DB 10H,10H,00H,1FH,00H,00H,00H,00H
DB 00H,00H,00H,07H,08H,10H,10H,10H
DB 08H,1FH,00H,1FH,00H,00H,00H,00H
DB 00H,1FH,00H,00H,00H,10H,1FH,10H
DB 00H,00H,00H,0CH,10H,10H,10H,08H
DB 07H,00H,00H,1FH,00H,01H,02H,04H
DB 08H,10H,00H,00H,1FH,10H,90H,10H
DB 00H,1FH,00H,1FH,00H,00H,00H,03H
DB 04H,1FH,00H,07H,08H,10H,10H,10H
DB 08H,07H,00H,1FH,01H,01H,01H,01H
DB 00H,00H,00H,07H,0CH,12H,12H,12H
DB 0CH,17H,00H,00H,00H,00H,00H,0FFH
DB 0FFH,00H,00H,0FFH,21H,21H,61H,0A1H
DB 12H,0CH,00H,0CH,12H,21H,21H,21H
DB 42H,84H,00H,01H,01H,01H,0FFH,01H
DB 01H,01H,00H,0FFH,00H,00H,00H,00H
DB 00H,0FFH,00H,0FFH,00H,00H,00H,00H
DB 00H,0FFH,00H,0FFH,00H,80H,60H,80H
DB 00H,0FFH,00H,07H,88H,50H,20H,50H
DB 88H,07H,00H,07H,08H,10H,0E0H,10H
DB 08H,07H,00H,01H,81H,41H,21H,11H
DB 09H,07H,00H,00H,00H,00H,87H,00H
DB 00H,00H,00H,00H,00H,00H,00H,00H
DB 00H,00H,00H,00H,00H,00H,0FFH,01H
DB 01H,00H,00H,00H,01H,01H,0FFH,00H
DB 00H,00H,00H,00H,00H,20H,0DEH,01H
DB 01H,00H,00H,00H,01H,01H,0DEH,20H
DB 00H,00H,00H,00H,00H,00H,00H,0FFH
DB 0FFH,80H,80H,87H,80H,80H,80H,80H
DB 83H,84H,80H,81H,82H,84H,84H,84H
DB 82H,81H,80H,80H,80H,80H,87H,80H
DB 80H,80H,80H,83H,84H,84H,84H,84H
DB 84H,83H,80H,80H,81H,82H,84H,82H
DB 81H,80H,80H,81H,86H,81H,80H,81H
DB 86H,81H,80H,87H,80H,80H,80H,80H
DB 80H,87H,80H,80H,80H,80H,87H,80H
DB 80H,80H,80H,87H,84H,84H,84H,84H
DB 84H,84H,80H,80H,80H,80H,87H,80H
DB 80H,80H,80H,84H,84H,84H,84H,84H
DB 84H,84H,80H,80H,80H,80H,87H,84H
DB 84H,80H,80H,80H,84H,84H,87H,80H
DB 80H,80H,80H,80H,80H,80H,83H,84H
DB 84H,80H,80H,80H,84H,84H,83H,80H
DB 80H,80H,80H,80H,80H,80H,80H,0FFH
SHOW_WG:
DB 010h,010h,000h,000h,003h,000h,040h,080h
DB 040h,08Fh,040h,080h,040h,080h,043h,080h
DB 040h,080h,040h,08Fh,040h,080h,040h,080h
DB 043h,080h,040h,080h,040h,08Fh,040h,080h
DB 040h,080h,043h,080h,040h,080h,040h,08Fh
DB 040h,080h,040h,000h,003h,000h,080h,080h
DB 080h,00Fh,080h,080h,080h,000h,003h,000h
DB 040h,080h,040h,080h,043h,080h,040h,080h
DB 040h,08Fh,040h,080h,040h,000h,003h,000h
DB 080h,000h,080h,08Fh,080h,000h,080h,080h
DB 083h,000h,000h,000h,040h,08Fh,040h,080h
DB 040h,080h,040h,080h,055h,0AAh,055h,0AAh
DB 042h,042h,002h,002h,000h,000h,055h,0AAh
DB 055h,0AAh,055h,0AAh,055h,0AAh,055h,0AAh
DB 055h,0AAh,055h,080h,040h,080h,04Bh,08Ah
DB 04Eh,080h,04Fh,088h,04Fh,080h,040h,080h
DB 055h,0AAh,055h,0AAh,055h,080h,040h,080h
DB 04Fh,080h,04Fh,088h,04Fh,080h,04Fh,088h
DB 04Fh,080h,040h,080h,055h,0AAh,055h,0AAh
DB 008h,008h,008h,008h,000h,000h,055h,0AAh
DB 021h,021h,020h,020h,000h,000h,055h,0AAh
DB 084h,084h,080h,080h,000h,000h,055h,0AAh
DB 010h,010h,000h,000h,000h,000h,015h,08Ah
DB 095h,08Ah,015h,08Ah,095h,08Ah,015h,00Ah
DB 042h,042h,002h,002h,000h,000h,040h,08Bh
DB 04Ah,08Eh,040h,08Fh,048h,08Fh,040h,080h
DB 058h,0A8h,058h,0A8h,050h,0A0h,055h,0AAh
END
STP_SC:
MOV C,S_S
JC STEP
RET
STEP:
MOV C,STP
MOV R5,#0FH
LOPE:
MOV R6,#0FFH
LOPH:
DJNZ R6,LOPH
DJNZ R5,LOPE
JNB S_S,LOUT
JNC STEP
LOUT:
RET
; KS0107,KS0108
.SYMBOLS
RS REG P3.0
E REG P3.4
CS1 REG P3.3
CS2 REG P3.5
R_W REG P3.7
STP REG P2.0
S_S REG P2.1
BCD EQU 01H
ORG 0H
LJMP START
ORG 50H
;INITIAL
; FULL ON
FULL_ON:
MOV R0,#0
MOV R1,#0
FOLOOP1:
CALL WRITE_COMMAND1
CALL WRITE_COMMAND2
CALL WRITE_COMMAND1
CALL WRITE_COMMAND2
MOV A,#FFH
CALL WRITE_DATA1
INC R0
CJNE R0,#64,FOLOOP2
MOV A,#FFH
CALL WRITE_DATA2
INC R0
INC R1
CJNE R1,#8,FOLOOP1
LCALL DELAY
LCALL STP_SC
SJMP SHOWM
; SHOW MODEL
SHOWM:
MOV R0,#0
MOV R1,#0
MOV DPTR,#SHOW_WG
SMLOOP1:
CALL WRITE_COMMAND1
CALL WRITE_COMMAND2
CALL WRITE_COMMAND1
CALL WRITE_COMMAND2
XRL A,A
MOVC A,@A+DPTR
CALL WRITE_DATA1
INC R0
INC DPTR
CJNE R0,#64,SMLOOP2
XRL A,A
MOVC A,@A+DPTR
CALL WRITE_DATA2
INC R0
INC DPTR
INC R1
CJNE R1,#8,SMLOOP1
LCALL DELAY
LCALL STP_SC
SJMP VLINE
; VERTIAL LINE
VLINE:
MOV R0,#0
MOV R1,#0
VLLOOP1:
CALL WRITE_COMMAND1
CALL WRITE_COMMAND2
CALL WRITE_COMMAND1
CALL WRITE_COMMAND2
MOV A,#FFH
CALL WRITE_DATA1
INC R0
MOV A,#00H
CALL WRITE_DATA1
INC R0
CJNE R0,#64,VLLOOP2
MOV A,#FFH
CALL WRITE_DATA2
INC R0
MOV A,#00H
CALL WRITE_DATA2
INC R0
INC R1
CJNE R1,#8,VLLOOP1
LCALL DELAY
LCALL STP_SC
SJMP HLINE
; HORIZONTAL LINE
HLINE:
MOV R0,#0
MOV R1,#0
HLLOOP1:
CALL WRITE_COMMAND1
CALL WRITE_COMMAND2
CALL WRITE_COMMAND1
CALL WRITE_COMMAND2
MOV A,#AAH
CALL WRITE_DATA1
INC R0
CJNE R0,#64,HLLOOP2
MOV A,#AAH
CALL WRITE_DATA2
INC R0
INC R1
CJNE R1,#8,HLLOOP1
LCALL DELAY
LCALL STP_SC
SJMP CROSS_DOT
; BIG CROSS DOT
CROSS_DOT:
MOV R0,#0
MOV R1,#0
CDLOOP1:
CALL WRITE_COMMAND1
CALL WRITE_COMMAND2
CALL WRITE_COMMAND1
CALL WRITE_COMMAND2
MOV A,#CCH
CALL WRITE_DATA1
CALL WRITE_DATA1
MOV A,#33H
CALL WRITE_DATA1
CALL WRITE_DATA1
INC R0
CJNE R0,#16,CDLOOP2
MOV A,#CCH
CALL WRITE_DATA2
CALL WRITE_DATA2
MOV A,#33H
CALL WRITE_DATA2
CALL WRITE_DATA2
INC R0
CJNE R0,#32,CDLOOP3
INC R1
CJNE R1,#8,CDLOOP1
LCALL DELAY
LCALL STP_SC
SJMP SHOWC
; SHOW CHARACTER
SHOWC:
MOV R0,#0
MOV R1,#0
MOV DPTR,#SHOW_CH
SCLOOP1:
CALL WRITE_COMMAND1
CALL WRITE_COMMAND2
CALL WRITE_COMMAND1
CALL WRITE_COMMAND2
XRL A,A
MOVC A,@A+DPTR
CALL WRITE_DATA1
INC R0
INC DPTR
CJNE R0,#64,SCLOOP2
XRL A,A
MOVC A,@A+DPTR
CALL WRITE_DATA2
INC R0
INC DPTR
INC R1
CJNE R1,#8,SCLOOP1
LCALL DELAY
LCALL STP_SC
CHK_BUSY:
SETB E ;ENABLE LCM
CLR E
JC CHK_BUSY
RET
; DELAY
DELAY:
CALL CBCD
MOV R4,BCD
LOPC:
MOV R5,#2FH
LOPB:
MOV R6,#0FFH
LOPA:
DJNZ R6,LOPA
DJNZ R5,LOPB
DJNZ R4,LOPC
RET
;* Timing
CLR CS1
SETB CS2
CLR RS
CLR R_W
MOV P1,A
SETB E
NOP
CLR E
RET
CLR CS1
SETB CS2
SETB RS
CLR R_W
MOV P1,A
SETB E
NOP
CLR E
RET
CLR CS2
SETB CS1
CLR RS
CLR R_W
MOV P1,A
SETB E
NOP
CLR E
RET
CLR CS2
SETB CS1
SETB RS
CLR R_W
MOV P1,A
SETB E
NOP
CLR E
RET
STP_SC:
MOV C,S_S
JC STEP
RET
STEP:
MOV C,STP
MOV R5,#0FH
LOPE:
MOV R6,#0FFH
LOPH:
DJNZ R6,LOPH
DJNZ R5,LOPE
JNB S_S,LOUT
JNC STEP
LOUT:
RET
CBCD:
PUSH A
MOV A,P0
ANL A,#0FH
RL A
RL A
MOV BCD,A
POP A
RET
;* DISPLAY DATA
SHOW_CH:
SHOW_WG:
END
