help me out guys...
deal2die
Is it possible to transmit a video signal from a cro/dso to pc??
pls help me wit any circuits r ideas guys..
Why don't just use a simple webcam to record the screen on the scope.
It's a drop-dead* simple solution.
*It's so simple that you can almost do it without thinking
its a old technique...
in my college thy wont allow these stuffs....
thy need everythin to be done manually.....
cathode ray oscilloscope
OK acording to the spec sheet for your scope..........
Who made it? What model is it?
The hole point being not every scope is the same, some may have outputs and others will not. have you looked up your scope? It should tell you if you can output the video and what you need to do with the output to use it.
