    Dismiss Notice
Help Deriving a Circuit
Discussion in 'General Electronics Chat' started by driftlogic, Oct 1, 2011.
  1. driftlogic
    driftlogic New Member
    Oct 1, 2011
    29
    0
    Hi all.
    Could anyone help me with a schematic from the following DIY video series:
    (Part 1) http://www.youtube.com/watch?v=2M0l6tdvFBE
    In part 1 he covers populating the board, and the later parts he describes some wiring.
    Essentially this project is a police light bar, that uses eight 3W LEDS to flash and is controlled by a PIC unit.
    Before anyone brings it up, I have a valid permit in my state (I'm in the USA) that allows me to use emergency lights (of the colors Red/White) for certain situations.
    While the quality of the part 1 video is tolerable, parts 2 and on I have difficulty following.
    I have sent the user a message but have not heard back. My background is not in CS or ECE so any help would be appreciated. The user does not share the code either for the PIC so that is something I may later have to figure out.
    I think a schematic coupled with the videos would be useful to other individuals looking for a similar project. I also am aware that LED flashers and its variations are also discussed on this forum, but the end result this user achieved is really what I'm after. Again any help would be appreciated.
    Thank you.
  2. SimonW
    SimonW New Member
    Feb 3, 2006
    45
    0
    Sale, UK
    If all else fails, you can design and build your own, using the cheaper easier and simpler micro controller Arduino.
    Great place to start is to watch the youtube series:
    http://www.youtube.com/watch?v=fCxzA9_kg6s
  3. carbonzit
    carbonzit Active Member
    Mar 19, 2011
    1,958
    13
    Arduino? Overkill. Just use a counter chip. No code required.
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. driftlogic
    Oct 1, 2011
    29
    0
    Thank you for the suggestions. I think Arduino while powerful is a little too much for the project, while a PIC much cheaper to use. As far as using a counter chip, I'm not too familiar with how to modify that project shown in the video series but I'll keep it in mind. Most discussions I've read say that you can get a better strobe effect when using a microcontroller rather than other alternatives.
  6. 4pyros
    4pyros Well-Known Member Most Helpful Member
    Oct 22, 2010
    4,368
    282
    Pennsylvania, USA
    The video was made years ago. Without the code it is wothless. Find something newer.
  7. driftlogic
    Oct 1, 2011
    29
    0
    I'm not sure if it is entirely worthless. While I've tried to find something newer, this is the best I've currently found. Will keep my eyes open though.
  8. driftlogic
    Oct 1, 2011
    29
    0
    As a quick aside (and motivated by carbonzit's post), could anyone tell me what modifications would be made to the circuit below to change the LEDs to four 3W White LEDs for one side and four 3W Red LEDS for the other? (like these LEDs Link). My understanding is that the circuit below would flash those LEDs three times then alternate.
    [​IMG]
  9. carbonzit
    Mar 19, 2011
    1,958
    13
    Well, for starters you'll need much bigger switch transistors. Those BC547s won't be able to handle 12 watts of LEDs.
  10. BrownOut
    BrownOut Banned
    Jun 10, 2009
    4,630
    60
    Huntsville, Alabama USA
    Don't think so. I think one will 'flicker' while the other is off for about 1.5S. Then switch. The flicker will be about 20 times a second.
  11. driftlogic
    Oct 1, 2011
    29
    0
  12. BrownOut
    BrownOut Banned
    Jun 10, 2009
    4,630
    60
    I basically agree with the author, but I think you get more than 3 flashes. I think the author is a member here, so maybe he'll comment.
  13. QuietMan
    QuietMan Member
    Nov 6, 2009
    155
    3
    Dallas, TX
    Some circuits I've come up with over the years.
    http://forum.allaboutcircuits.com/showthread.php?t=18182
    http://forum.allaboutcircuits.com/showthread.php?t=37409
    http://forum.allaboutcircuits.com/showthread.php?t=17499
    http://forum.allaboutcircuits.com/showthread.php?t=16484
    The 3rd link ought to be interesting, since it is a situation similar to yours.
    Side note, I've been made a moderator at All About Circuits. Automotive applications are not allowed over there, so while I might link to some past threads over there I can only discuss this circuit over here (unless the local moderators object).
    Flash pattern is the thing, it is the most complex aspect of what you want to do.
    The other issue is heat sinking. High power LEDs definitely require somewhere to dump their heat.
  14. driftlogic
    Oct 1, 2011
    29
    0
    Very informative posts QuietMan. I appreciate you digging up those threads. From what I'm seeing you have designed numerous circuits that produce flash patterns between LED groups such as this: [​IMG]
    As you know, in my case I have been interested in using just a few 3W LEDs because I figured it would be easier to arrange, having a total of 8 LEDs for example, (4 per side), rather than the 30 in that circuit above. I am certainly open to changing my LED use if it leads to a better design.
    In doing my research/searching I've seen so many different circuits that I don't know what's the best approach in terms of simplicity, efficiency, and meeting the design criteria.
    If I may I'd also like to get your thoughts also about this circuit:
    [​IMG]
    The programmed PIC produces this effect: Link
    This is one of the few circuits I've found with a schematic and available source (in this case its compiled, but i think it can be decompiled) that yields a good strobe effect. The example from my original post (pg 1) has a good strobe effect too, but the source is not available.
    (Someone from AAC stated the following about that circuit: "Firstly it is not clear why the original designer choose to use emitter followers to drive the LEDs. Secondly there is also doubt why he uses two 10K resistors on a single node at Pin#17 & #18. I think you can use just one 10K instead." )
    With the compiled source of the PIC available, do you think this would be suitable to drive the 3W LED pairs, powered from say a cigarette lighter of a car? In my opinion the flash pattern of this example is superior to an alternating flash of (2x, or 3x) one can achieve using 555/4017 chips, but would it be worth it to go this route? Could the PIC even be used to power that many 3W LEDs?
    In the end I would be satisfied with the 2x or 3x alternating flasher such as you have designed, but think the more complex strobe pattern would leave something to be desired. Ultimately, I hope to house it in a similar fashion to this:
    [​IMG]
    In the meantime I will continue to review the links you have posted. I guess what it really comes down to is either seeing if the microcontroller version from above is possible and modifying it, or choosing a flasher circuit you've designed and modifying that. Either way, I think we are making some progress, and again I thank you for your assistance.
  15. carbonzit
    Mar 19, 2011
    1,958
    13
    In case you don't already know, keep in mind that decompiled code ≠ source code (unless you're some kind of genius who can make sense out of a bunch of machine instructions).
  16. driftlogic
    Oct 1, 2011
    29
    0
    Valid point. This was what resulted from decompiling the hex. (means nothing to me)
    Code (text):
    goto lbl_1  ; lbl_1 = 0x28
    lbl_13  clrf 0x23
        movwf 0x22
    lbl_4   movlw FF    ; d'255' b'11111111' a''
        addwf 0x22,f
        btfss status,c
        addwf 0x23,f
        btfss status,c
        goto lbl_2  ; lbl_2 = 0x23
        movlw 3 ; d'3' b'11' a'¶'
        movwf 0x21
        movlw DF    ; d'223' b'11011111' a''
        call lbl_3  ; lbl_3 = 0xF
        goto lbl_4  ; lbl_4 = 0x3
        clrf 0x21
    lbl_3   addlw E8    ; d'232' b'11101000' a''
        movwf 0x20
        comf 0x21,f
        movlw FC    ; d'252' b'11111100' a''
        btfss status,c
        goto lbl_5  ; lbl_5 = 0x18
    lbl_6   addwf 0x20,f
        btfsc status,c
        goto lbl_6  ; lbl_6 = 0x15
    lbl_5   addwf 0x20,f
        nop
        incfsz 0x21,f
        goto lbl_6
        btfsc 0x20,0
        goto lbl_7  ; lbl_7 = 0x1E
    lbl_7   btfss 0x20,1
        goto lbl_8  ; lbl_8 = 0x22
        nop
        goto lbl_8
    lbl_8   return
    lbl_2   bcf status,irp
        bcf status,rp0  ; switch to bank 0
        bcf status,rp1
        nop
        return
    lbl_1   movlw 7 ; d'7' b'111' a'¶'
        movwf 0x1F
    lbl_10  bcf portb,0
        bcf portb,1
        btfsc porta,0
        goto lbl_9  ; lbl_9 = 0x31
        btfsc porta,1
        goto lbl_9
        goto lbl_10 ; lbl_10 = 0x2A
    lbl_9   bsf porta,0
        clrf 0x27
    lbl_17  movlw 4 ; d'4' b'100' a'¶'
        subwf 0x27,w
        btfsc status,c
        goto lbl_11 ; lbl_11 = 0x5B
        clrf 0x26
    lbl_14  movlw 7 ; d'7' b'111' a'¶'
        subwf 0x26,w
        btfsc status,c
        goto lbl_12 ; lbl_12 = 0x47
        movlw 1 ; d'1' b'1' a'¶'
        xorwf portb,f
        bsf status,rp0  ; switch to bank 1
        bcf trisb,0
        movlw 32    ; d'50' b'110010' a'2'
        call lbl_13 ; lbl_13 = 0x1
        btfss porta,0
        goto lbl_10
        incfsz 0x26,f
        goto lbl_14 ; lbl_14 = 0x38
    lbl_12  bcf portb,0
        clrf 0x26
    lbl_16  movlw 7 ; d'7' b'111' a'¶'
        subwf 0x26,w
        btfsc status,c
        goto lbl_15 ; lbl_15 = 0x58
        movlw 2 ; d'2' b'10' a'¶'
        xorwf portb,f
        bcf trisb,1
        call lbl_13
        btfss porta,0
        goto lbl_10
        incfsz 0x26,f
        goto lbl_16 ; lbl_16 = 0x49
    lbl_15  bcf portb,1
        incfsz 0x27,f
        goto lbl_17 ; lbl_17 = 0x33
    lbl_11  clrf 0x28
    lbl_23  movlw 7 ; d'7' b'111' a'¶'
        subwf 0x28,w
        btfsc status,c
        goto lbl_18 ; lbl_18 = 0x84
        clrf 0x26
    lbl_20  movlw 2 ; d'2' b'10' a'¶'
        subwf 0x26,w
        btfsc status,c
        goto lbl_19 ; lbl_19 = 0x70
        xorwf portb,f
        bcf trisb,0
        call lbl_13
        btfss porta,0
        goto lbl_10
        incfsz 0x26,f
        goto lbl_20 ; lbl_20 = 0x61
    lbl_19  bcf portb,0
        clrf 0x26
    lbl_22  movlw 2 ; d'2' b'10' a'¶'
        subwf 0x26,w
        btfsc status,c
        goto lbl_21 ; lbl_21 = 0x81
        xorwf portb,f
        bcf trisb,1
        call lbl_13
        btfss porta,0
        goto lbl_10
        incfsz 0x26,f
        goto lbl_22 ; lbl_22 = 0x72
    lbl_21  bcf portb,1
        incfsz 0x28,f
        goto lbl_23 ; lbl_23 = 0x5C
    lbl_18  goto lbl_9
        goto lbl_10
    lbl_24  sleep
        goto lbl_24 ; lbl_24 = 0x86
    ORG 0x2007
        addlw 22    ; d'34' b'100010' a'"'
  17. driftlogic
    Oct 1, 2011
    29
    0
  18. QuietMan
    QuietMan Member
    Nov 6, 2009
    155
    3
    Dallas, TX
    The only reason you would want to go with a µC is if you have patterns, and even then you have other options. I don't disagree with using a µC, but I wouldn't be much help with it.
    If all you want is simple alternating lights then a variation of the circuit on post #16 would work, but it could be built much simpler and be as reliable. If you want a pattern then you need to decide on that early in the process.
    The main thing is the mounts, you must include some way to mount the power LEDs to a heat sink of some kind. This is pretty critical.
    One last word on the pattern, I remember reading that drunks tend to try to drive between two alternating lights, causing some spectacular rear end collisions. I strongly suggest some research on your part for this, a couple of extra hours reading could save your car later.
  19. colin55
    colin55 Well-Known Member
    Feb 14, 2009
    3,534
    82
    Melbourne Australia
    The circuit in #7 flashes each LED 3 times. Simply adjust the components until you get the flash-rate you want.
  20. driftlogic
    Oct 1, 2011
    29
    0
    I have decided to put the microcontroller path on the backburner.
    I would like to learn what modifications would be needed to the circuit from post#16 to produce either a 2x or 3x alternating flash of four 3W LED pairings. Is it possible to have the rate variable- Is that what R2 is doing in the circuit? Also, would it be necessary at this point to pick out the 3W LEDs go get the specifics of the circuit? I'll also look into the issue of heat, and any resources for heat sinks with high power LEDs.
    As for your last point, it seems this phenomenon associated with the moth effect and target fixation. It seemed there is some debate if it is a real occurance. Either way, it is certainly something to be aware of.
  21. BrownOut
    BrownOut Banned
    Jun 10, 2009
    4,630
    60
    I don't think the circuit in post #16 will work for you. Look at post #18. I think colon is the author of that circuit from post #7. It could work with some modifications. Try making the 2U2 cap about 50U. Those timers aren't synchronized, so it wont' be an exact 3:1. Also may need to beef up the transistor drivers. I've lost track of how much power you want to switch.
Share This Page
