Hello world - computer screen version
Inquisitive
Super Moderator
Hello everyone,
Just an idea I thought might be interesting. How many different computer languages can we represent with just a simple "Hello World"
The criteria here is output must be to the computer monitor and as simple as possible.
The purpose is to show the subtle and not so subtle differences between the various computer languages available today.
Example Python 2.7
Save text file as hw.py
Contents of hw.py
Python:
print "Hello World!"
To execute this file at a terminal window prompt, type - python hw.py
Note: Python language must be installed on computer for this to work.
Forth
One line is needed to define the world HELLO.
When we type HELLO followed by a CR the computer will respond with "Hello World". The computer output is in italics.
: HELLO  ( -- )  CR ." Hello, world!" ;  / define HELLO
HELLO <cr>
Hello, world!
Or you can do it interactively
" Hello, world!" <cr>
Hello, world!
Note: The Forth language must be installed on computer for this to work.
Forth was a great language because you could write and test you code on the target without anything but a serial port. This was back when emulators cost thousands and rom monitors hundreds. Still a great language but I use c.
Lisp
Lisp along with prolog were the two main languages use for artificial intelligence research.
;;; HWorld.lsp
;;; =========== HELLO WORLD SIMULATION ============== ;;;
;;; This function simply returns the string Hello World that is in quotes.
(DEFUN HELLO ()
  "HELLO WORLD"
I think by now we can see that this is not a very interesting program in most if not all languages. The main use of HELLO WORLD programs is to prove that one has the compiler or interpreter working. That you can build and run a program.
Java 1.7
Java:
//    Program name:    hw.java
//    Text-printing program
public class hw
    // main method begins execution of Java application
    public static void main(String[] args)
        System.out.println("Hello World!");
    }    //    end method main
}    //    end class hw
6502 on Apple II
  1 ;PROGRAM TO PRINT "HELLO WORLD!"
  2 ;ON THE SCREEN
  3 ;WRITTEN ON: today
  4 ;
  5 HOME    EQU $FC58
  6 COUT    EQU $FDED
  7          ORG $300
  8 MAIN:
  9          JSR HOME            ;CLEAR SCREEN
  10          LDY #00
  11 REPEAT  LDA MESSAGE,Y
  12          BEQ EXIT
  13          JSR COUT
  14          INY
  15          JMP REPEAT
  16 EXIT    RTS
  17 MESSAGE  ASC "HELLO WORLD!"
  18          HEX 00
  19          END
Moo:
@program hello:run
player:tell("Hello world!");
Cow:
MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO Moo MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO Moo MoO MoO MoO MoO MoO MoO MoO Moo Moo MoO MoO MoO Moo OOO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO Moo MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO Moo MOo MOo MOo MOo MOo MOo MOo MOo MOo MOo MOo MOo MOo MOo MOo MOo MOo MOo MOo MOo MOo MOo MOo MOo MOo MOo MOo MOo MOo MOo MOo MOo MOo MOo MOo MOo MOo MOo MOo MOo MOo Moo MOo MOo MOo MOo MOo MOo MOo MOo Moo MoO MoO MoO Moo MOo MOo MOo MOo MOo MOo Moo MOo MOo MOo MOo MOo MOo MOo MOo Moo OOO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO MoO Moo
VB6
Private Sub Form_Load()
    Form1.Show
    Print "Hello World!"
End Sub
Produces,
quickbasic:
CLS : PRINT "HELLO WORLD"; DO WHILE INKEY$="":LOOP:END
this clears the screen, prints HELLO WORLD, and waits for a key press before terminating, because usually with the Qbasic interpreter, you go back to the editor screen as soon as the program finishes....
most M$ versions of basic have the ability to write "one-liners". back in the day, i used to drive Radio Shack sales people crazy with a "one-liner-of-death" that would run on the TRS-80 Color Computer. the BASIC code was stored as tokens near the top of RAM, and the video RAM was somewhere just below that, so the following "one-liner" would start at the bottom oF RAM, and fill it with random characters, until it first overwrote the video display with garbage, and then the program would overwrite itself, and the CoCo would lock up:
FOR X=0 TO 65535 : POKE X(INT(RND*255)) : NEXT X
GNU C
C:
#include <stdio.h>
int main(int argc, char *argv[])
    puts("Hello World!");
    return 0;
C:
#include "stdio.h"
#define e 3
#define g (e/e)
#define h ((g+e)/2)
#define f (e-g-h)
#define j (e*e-g)
#define k (j-h)
#define l(x) tab2[x]/h
#define m(n,a) ((n&(a))==(a))
long tab1[]={ 989L,5L,26L,0L,88319L,123L,0L,9367L };
int tab2[]={ 4,6,10,14,22,26,34,38,46,58,62,74,82,86 };
main(m1,s) char *s; {
    int a,b,c,d,o[k],n=(int)s;
    if(m1==1){ char b[2*j+f-g]; main(l(h+e)+h+e,b); printf(b); }
    else switch(m1-=h){
        case f:
            a=(b=(c=(d=g)<<g)<<g)<<g;
            return(m(n,a|c)|m(n,b)|m(n,a|d)|m(n,c|d));
        case h:
            for(a=f;a<j;++a)if(tab1[a]&&!(tab1[a]%((long)l(n))))return(a);
        case g:
            if(n<h)return(g);
            if(n<j){n-=g;c='D';o[f]=h;o[g]=f;}
            else{c='\r'-'\b';n-=j-g;o[f]=o[g]=g;}
            if((b=n)>=e)for(b=g<<g;b<n;++b)o[b]=o[b-h]+o[b-g]+c;
            return(o[b-g]%n+k-h);
        default:
            if(m1-=e) main(m1-g+e+h,s+g); else *(s+g)=f;
            for(*s=a=f;a<e;) *s=(*s<<e)|main(h+a++,(char *)m1);
If you want simple, you may like the "whitespace" language.. because there is nothing to look at. Something that looks simple is not simple. When the OP asked for a simple "hello world", that is a good challenge. Simple code requires a very complicated compiler (on modern computers/processors).
Pic Basic Pro
'*  Name  : Hello World.BAS
'*  Author  : Mike2545
'*  Notice  : Copyright (c) 2013 under penalty of death
'*  : All Rights Reserved
'*  Date  : 10/6/2013
'* Version  : 1.0
'*  Notes  :
' Example program to display "hello world" on the serial debug screen
' Pic Basic is a derivitive of the Basic Stamp
  INCLUDE "modedefs.bas"
  INCLUDE "ALLDIGITAL.pbp"
  OSCCON =$60 'clock speed
  DEFINE OSC 4
  DEFINE DEBUG_REG PORTB  ' Set Debug pin bit
  DEFINE DEBUG_BIT 4
  DEFINE DEBUG_BAUD 2400
  DEFINE DEBUG_MODE 1 ' Set Debug mode: 0 = true, 1 = inverted
  Debug "Hello World"
' Hello World for AmigaBASIC
PRINT "Hello world!"
And this is the speech synthesis version:
SAY TRANSLATE$ ("HELLO WORLD")
