    Dismiss Notice
FTDI FT230X USB-Serial CBus confusion
Discussion in 'General Electronics Chat' started by BobW, Sep 19, 2017.
  1. BobW
    BobW Active Member
    Apr 28, 2010
    501
    52
    Canada
    Has anyone any experience with setting up these USB-Serial I/O chips using the FT_Prog utility? I have a couple of these on breakout boards, datasheet here:
    http://www.ftdichip.com/Support/Documents/DataSheets/Modules/DS_UMFT201_220_230XB.pdf
    The chip itself has four configurable general purpose I/O lines, CB0, CB1, CB2, CB3, with CB0 and CB1 brought out to the 10 pin connector on the breakout board.
    Here's the problem. The above referenced datasheet has conflicting information. Table 4.5 on page 6 says that the factory default setting for CB0 is PWREN#, and CB1 is SLEEP#; whereas Table 10.1 on page 13 says that the factory default setting for both CB0 and CB1 are GPIO. Making things even more confusing, when I read the configuration of the breakout board using the FT_Prog utility program, it says that all of the lines are configured as TRISTATE, which disagrees with both tables. While I can certainly use FT_Prog to set the function to whatever I want, I'm concerned that it may not have correctly read the configuration from the chip, and so I may be working with corrupt data that could brick the device when I send the revised configuration back to it. Has anyone encountered this problem?
  2. Pommie
    Pommie Well-Known Member Most Helpful Member
    Mar 18, 2005
    10,013
    317
    Brisbane Australia
    The tables don't disagree, they both state I/O with 4.5 adding how they are configured. If when you read the config it's different, could it be that someone has configured it different from the factory default and then returned it to the supplier?
  3. BobW
    BobW Active Member
    Apr 28, 2010
    501
    52
    Canada
    I think they do disagree. GPIO in this context is a specific type of I/O, as it is listed separately from PWREN# and SLEEP# in the same table. Hence, PWREN# is not GPIO.
    I doubt that they would have been reconfigured and then returned to the supplier, though not impossible, I guess. I have two different ones that were in different factory sealed packages. Both have the same configuration or lack thereof.
    Anyway, I'm more confident that the configuration that was read in from the chip is not corrupted, because I saved the config file to disk and then read it in an xml editor. The parameters all look reasonable. So, I'll probably take a chance and try reconfiguring the chip.
Share This Page
