Worth a try. Not sure if 20mS is long enough for everyone to see, but I guess it depends on an individual's vision.Can the LED work w/o D3 & C4? It will be very short pulse then but I think will be visible, no?
It's unconnected.The Q- on U1a is not connected in the circuit?
If you can't have the reed inside the coil then I think you will need a coil with a [ -shaped ferrromagnetic core having two pole pieces, one at each end region of the reed, so that half the reed sees a N pole and the other half sees a S pole. I don't know of any commercially-available coil like that; you'd probably have to make one yourself.Maybe there is a solution with a coil that centers it magnetic field all at the top or 1 point
They'll do.I found BC547B (instead of the 2N3904) and 1N4007 (instead of 1N4148) is that OK?
If you want to use a 3V supply then only R4 needs changing, to 100 Ohms.
If you don't like 470uF you could change it to 2.2uF and add a transistor stage as in the attached
Edit: As you say, before doing anything else it would be best to find a coil and see how much current is needed to operate the old reed.
