Hello,
I am writing MPASM code for MPLAB.X and its gotten too long...is there a free C compiler for PIC18F65K22 in MPLAB.X?
Here is my code so far..
;Code for 3 channel led driver on the updated 550587 PCB
;REMEMBER RESET ADDRESS
;WE ARE TRUNCATING THE ADC REGISTER SO JUST USE UPPER 8 BITS
; XXX DIPSWITCH POLARITY:- XXX
;DIP 1...ON = EXTERNAL CONNECTOR CONTROL
;DIP 2...ON = LOGIC HIGH (note 'ON' gives a low input)
;DIP 3...ON = LOGIC HIGH
;DIP 4...OFF = 10V is for max current
;DIP 5...OFF = 80degC, ON = 90degC
;DIP 6... UNUSED
;DIP 7... UNUSED
;DIP 8...ON = NO FAN FITTED, OFF = FAN FITTED
; XXX EXTERNAL CONTROL CONNECTOR POLARITY:- XXX
;CLEAR = ACTIVE HIGH
;RESET = ACTIVE HIGH
;CH1...HIGH = ON, LOW = OFF
;CH2...HIGH = ON, LOW = OFF
;CH3...HIGH = ON, LOW = OFF
;List of input ports:
; ************** DIPSWITCH INPUTS:
;DIP1 = RB0
;DIP2 = RB1
;DIP3 = RB2
;DIP4 = RB3
;DIP5 = RB4
;DIP6 = RB5
;DIP7 = RC5
;DIP8 = RE6
;************* External connector INPUTS:
;clear = RC1
;ch3 on/off = RC7
;RESET = RD5
;CH1 on/off = RD6
;ch2 on/off = RD7
;Other inputs (DIGITAL I/O
;Fan tacho = RG2
;mclr = RG5
;Inputs that are ADC inputs:
;RA2 = AN2
;RA3 = AN3
;RA5 = AN4 ADCON0=0x10
;RF1 = AN6
;RF2 = AN7
;RF3 = AN8
;RF4 = AN9
;RF5 = AN10 ADCON0=0x28
;RF6 = AN11 ADCON0=0x2C
;RF7 = AN5 ADCON0=0x1C
;**********ADC INPUTS:
;AN0 = NC
;AN1 = NC
;AN2 = VREF- (0V)
;AN3 = VREF+ (3V)
;AN4 = Therm ch1
;AN5 = I_CH1
;AN6 = 0-10V control input
;AN7 = PCB thermistor
;AN8 = I_ch2
;AN9 = I_ch3
;AN10 = Therm-ch2
;AN11 = Therm-ch3
;OOOOOOOOOOO LIST OF OUTPUTS:
;Trip = RA4
;Indicator LED = RC2
;MCP4013_CS = RC3
;MCP4013_UD = RC4
;Shutdown-Ch2 = RE0
;Shutdown-Ch1 = RE1
;Fancon PWM = RE2
;Shutdown-Ch3 = RG0
;NCNCNCNCNCNCNCNCNC LIST OF NON CONNECTED PINS:
;RA0
;RA1
;RA6
;RA7
; RB6 = PGC
; RB7 = PGD
;RC0
;RC6
; RD0
; RD1
; RD2
; RD3
; RD4
;RE3
;RE4
;RE5
;RE7
; RG1
; RG3
; RG4
#include "p18F65K22.inc"
list p=18f65k22 ;list directive to define processor
; CONFIG1L
CONFIG RETEN = OFF ; VREG Sleep Enable bit (Disabled - Controlled by SRETEN bit)
CONFIG INTOSCSEL = HIGH ; LF-INTOSC Low-power Enable bit (LF-INTOSC in High-power mode during Sleep)
CONFIG SOSCSEL = HIGH ; SOSC Power Selection and mode Configuration bits (High Power SOSC circuit selected)
CONFIG XINST = ON ; Extended Instruction Set (Enabled)
; CONFIG1H
CONFIG FOSC = INTIO1 ; Oscillator (Internal RC oscillator, CLKOUT function on OSC2)
CONFIG PLLCFG = OFF ; PLL x4 Enable bit (Disabled)
CONFIG FCMEN = OFF ; Fail-Safe Clock Monitor (Disabled)
CONFIG IESO = OFF ; Internal External Oscillator Switch Over Mode (Disabled)
; CONFIG2L
CONFIG PWRTEN = OFF ; Power Up Timer (Disabled)
CONFIG BOREN = SBORDIS ; Brown Out Detect (Enabled in hardware, SBOREN disabled)
CONFIG BORV = 0 ; Brown-out Reset Voltage bits (3.0V)
CONFIG BORPWR = ZPBORMV ; BORMV Power level (ZPBORMV instead of BORMV is selected)
; CONFIG2H
CONFIG WDTEN = OFF ; Watchdog Timer (WDT disabled in hardware; SWDTEN bit disabled)
CONFIG WDTPS = 1048576 ; Watchdog Postscaler (1:1048576)
; CONFIG3L
CONFIG RTCOSC = SOSCREF ; RTCC Clock Select (RTCC uses SOSC)
; CONFIG3H
CONFIG CCP2MX = PORTC ; CCP2 Mux (RC1)
CONFIG MSSPMSK = MSK7 ; MSSP address masking (7 Bit address masking mode)
CONFIG MCLRE = OFF ; Master Clear Enable (MCLR Disabled, RG5 Enabled)
; CONFIG4L
CONFIG STVREN = ON ; Stack Overflow Reset (Enabled)
CONFIG BBSIZ = BB2K ; Boot Block Size (2K word Boot Block size)
; CONFIG5L
CONFIG CP0 = OFF ; Code Protect 00800-01FFF (Disabled)
CONFIG CP1 = OFF ; Code Protect 02000-03FFF (Disabled)
CONFIG CP2 = OFF ; Code Protect 04000-05FFF (Disabled)
CONFIG CP3 = OFF ; Code Protect 06000-07FFF (Disabled)
; CONFIG5H
CONFIG CPB = OFF ; Code Protect Boot (Disabled)
CONFIG CPD = OFF ; Data EE Read Protect (Disabled)
; CONFIG6L
CONFIG WRT0 = OFF ; Table Write Protect 00800-017FF (Disabled)
CONFIG WRT1 = OFF ; Table Write Protect 01800-03FFF (Disabled)
CONFIG WRT2 = OFF ; Table Write Protect 04000-05FFF (Disabled)
CONFIG WRT3 = OFF ; Table Write Protect 06000-07FFF (Disabled)
; CONFIG6H
CONFIG WRTC = OFF ; Config. Write Protect (Disabled)
CONFIG WRTB = OFF ; Table Write Protect Boot (Disabled)
CONFIG WRTD = OFF ; Data EE Write Protect (Disabled)
; CONFIG7L
CONFIG EBRT0 = OFF ; Table Read Protect 00800-017FF (Disabled)
CONFIG EBRT1 = OFF ; Table Read Protect 01800-03FFF (Disabled)
CONFIG EBRT2 = OFF ; Table Read Protect 04000-05FFF (Disabled)
CONFIG EBRT3 = OFF ; Table Read Protect 06000-07FFF (Disabled)
; CONFIG7H
CONFIG EBRTB = OFF ; Table Read Protect Boot (Disabled)
;DEFINE OUTPUTS
#define ch1bit LATE,LATE1
#define ch2bit LATE,LATE0
#define ch3bit LATG,LATG0
#define ind_ledbit LATC,LATC2
#define fanconbit LATE,LATE2
#define tripbit LATA,LATA4
#define mcp4013_csbit LATC,LATC3
#define mcp4013_udbit LATC,LATC4
;*** TURN LEDS ON AND OFF
#define ON1 bsf LATE,LATE1 ;Turn on chan1
#define OFF1 bcf LATE,LATE1 ;Turn off chan1
#define ON2 bsf LATE,LATE0 ;Turn on chan2
#define OFF2 bcf LATE,LATE0 ;Turn off chan2
#define ON3 bsf LATG,LATG0 ;Turn on chan2
#define OFF3 bcf LATG,LATG0 ;Turn off chan2
;DEFINE INPUTS FROM DIPSWITCH
;Note that the new board has pullups on the dipswitch,
;whereas 550587 PCB had pull downs, thus logic is reversed.
#define modebit dip8,0 ;low = external connector sets power via 0-10V
#define LSBbit dip8,1 ;00 -> 3.52A, 01 -> 2.64A, 10 -> 1.76A, 11 -> OFF
#define MSBbit dip8,2
#define polaritybit dip8,3 ;high = 10V gives max current
#define t80t90bit dip8,4 ;high = 80degC, low=90degC
#define fanbit dip8,8 ;high = fan fitted, low = no fan fitted
;DEFINE INPUTS FROM EXTERNAL CONNECTOR
#define re_setbit ext_in,0
#define ch1_extbit ext_in,1
#define ch2_extbit ext_in,2
#define ch3_extbit ext_in,3
#define clearbit ext_in,4
temp1 equ 0x20 ;register for HOLDING ch 1 temperature
temp2 equ 0x21 ;register for holding ch 2 temperature
temp3 equ 0x22 ;register for holding ch 3 temperature
tempb equ 0x23 ;register for holding board temperature
ana8 equ 0x25 ;holds ADC reading converted to 8 bit from 12 bit
ana_hi equ 0x26 ;holds the ADRESH register
ana_lo equ 0x27 ;holds the ADRESL register
ext_in equ 0x28 ;holds the external connector inputs
del1 equ 0x29 ;Delay register
del2 equ 0x2A ;Delay register
max_temp equ 0x2F ;Holds the max temp
current equ 0x30 ;Holds the current level bits (bits 0=0 to 3)
count equ 0x35 ;count
iset_mcp4013 equ 0x36 ;Holds the set current value in mcp4013 steps
iset_mcp4013_A equ 0x37 ;
max_led_temp equ 0x38 ;Holds the max temp
max_pcb_temp equ 0x39 ;Holds the max temp
dip8 equ 0x4A ;holds dipswitch settings
dip8_init equ 0x4B
dip8_init_therm equ 0x4C
dip8_init_current equ 0x4D
dip8_init_mode equ 0x4E
dip8_therm equ 0x4F
dip8_mode equ 0x50
dip8_current equ 0x51
overtemp_flags equ 0x52 ;bit0=1ot,1open....pcbot,pcbopen.(1 = bad)
board_90C equ 0x2B ;HOLDS 90C VALUE FOR BOARD
board_80C equ 0x2C ;HOLDS 80C VALUE FOR BOARD
led_90C equ 0x2D ;HOLDS 90C VALUE FOR LEDS
led_80C equ 0x2E ;HOLDS 80C VALUE FOR LEDS
ledtherm_open equ 0x05 ;hOLDS -13DEGC FOR THERMIST OPEN
pcbtherm_open equ 0x06 ;holds pcb open
; *** DECLARE MACRO'S ***
;xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
; ******** Read dipswitchs into dip8 register ********
;Remember that the new PCB has pullups, wheras 550587 PCB had pull downs
;..thus logic in the program is reversed
read_dips_m macro
clrf dip8
btfsc PORTB,RB0 ;DIPSWITCH 1 = MODE
bsf dip8,0
btfsc PORTB,RB1 ;DIPSWITCH 2, Power bit 0
bsf dip8,1
btfsc PORTB,RB2 ;DIPSWITCH 3, power bit 1
bsf dip8,2
btfsc PORTB,RB3 ;DIPSWITCH 4, polarity of 0-10V
bsf dip8,3
btfsc PORTB,RB4 ;DIPSWITCH 5, Temp threshold = 80c or 90c
bsf dip8,4
btfsc PORTB,RB5 ;DIPSWITCH 6, unused
bsf dip8,5
btfsc PORTC,RC5 ;DIPSWITCH 7, unused
bsf dip8,6
btfsc PORTE,RE6 ;DIPSWITCH 8, fan or no fan
bsf dip8,7
endm
;****** READ EXTERNAL CONNECTOR DIGITAL INPUTS *******
read_ext_conn_m macro
clrf ext_in
btfsc PORTD,RD5 ;extconn PIN 3; RESET
bsf ext_in,0
btfsc PORTD,RD6 ;extconn PIN 4; CH1_ON/OFF
bsf ext_in,1
btfsc PORTD,RD7 ;extconn PIN 5; CH2_ON/OFF
bsf ext_in,2
btfsc PORTC,RC7 ;extconn PIN 6; CH3_ON/OFF
bsf ext_in,3
btfsc PORTC,RC1 ;extconn PIN 10; CLEAR
bsf ext_in,4
endm
; **** output a tripped signal ****
output_trip_m macro
bsf tripbit
endm
; *****output a non-tripped signal ****
no_output_trip_m macro
bcf tripbit
endm
;***** Make ADC reading 8 bit from 12 bit ***********
ana_to_8bit_m macro
movf ADRESH,w
movwf ana8
endm
;SET UP THE ADC
setupADC_m macro
movlw 0x00
movwf ADCON0 ;channel select, godone, ADON
movlw 0x10
movwf ADCON1 ;vref
movlw 0x3E
movwf ADCON2 ;Right justified, acquisition time
endm
; ************ Define analog pins ***********8
ana_pins_m macro
movlw 0xFC ;
movwf ANCON0
movlw 0x0F ;
movwf ANCON1
movlw 0x00 ;
movwf ANCON2
endm
;XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
; Disable the comparators
comparator_off_m macro
movlw 0x00
movwf CM1CON
movlw 0x00
movwf CM2CON
movlw 0x00
movwf CM3CON
endm
; Disable interrupts
no_interrupts_m macro
clrf INTCON
movlw 0x80
movwf INTCON2
clrf INTCON3
clrf PIE1
clrf PIE2
clrf PIE3
clrf PIE4
clrf PIE5
clrf PIE6
endm
; Disable pullups
no_pullups_m macro
clrf PADCFG1
endm
; disable open drain outputs
no_opendrain_m macro
clrf ODCON1
clrf ODCON2
clrf ODCON3
endm
;set up ports as inputs or outputs
setup_ports_m macro
movlw 0x2C
movwf TRISA
movlw 0x3F
movwf TRISB
movlw 0xA2
movwf TRISC
movlw 0xD0
movwf TRISD
movlw 0x40
movwf TRISE
movlw 0xFE
movwf TRISF
movlw 0x24
movwf TRISG
endm
define_temps_m macro
movlw 0xA8 ;80 DEGC
movwf board_80C
movlw 0xB8 ;90 DEGC
movwf board_90C
movlw 0xA8 ;80 DEGC
movwf led_80C
movlw 0xC9 ;90 DEGC
movwf led_90C
movlw 0x05 ;-13 degC (OPN THERMISTOR)
movwf ledtherm_open
movlw 0x0A ;-13DEGC (OPEN THERMISTOR)
movwf pcbtherm_open
endm
;Make all NC pins low (they are already made to outputs)
;They are outputs for noise immunity reasons
NC_pins_low_m macro
bcf LATA,LATA0
bcf LATA,LATA1
bcf LATA,LATA6
bcf LATA,LATA7
bcf LATB,LATB6 ;PGC
bcf LATB,LATB7 ;PGD
bcf LATC,LATC0
bcf LATC,LATC6
bcf LATD,LATD0
bcf LATD,LATD1
bcf LATD,LATD2
bcf LATD,LATD3
bcf LATD,LATD4
bcf LATE,LATE3
bcf LATE,LATE4
bcf LATE,LATE5
bcf LATE,LATE7
bcf LATG,LATG1
bcf LATG,LATG3
bcf LATG,LATG4
; bcf PORTF,RF0
endm
;INITIALISE OUTPUTS THAT ARE CONNECTED
org 0x04
start
Main movlw b'01010000' ; set internal osc to 4 mhz
movwf OSCCON
;SETUP JOBS
setup_ports_m
no_pullups_m
no_opendrain_m
NC_pins_low_m
ana_pins_m
comparator_off_m
setupADC_m
no_interrupts_m
; >>>>>>>>>>>>>>>>>>>>> PROGRAM STARTS <<<<<<<<<<<<<<<<<<<<<<<<<<<
;XXXXXXXXXXXXXXXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
;OOOOOOOOOOOOOOOOOOOOOOOOOO OOOOOOOOOOOOOOOOOOOOOOOOOOO
;8888888888888888888888 88888888888888888888888888
begin
;Turn LEDs off
OFF1
OFF2
OFF3
call delay_ms
;load temperature maximums.
define_temps_m ;load the max temperature values
;Read the dipswitchs
read_dips_m
movf dip8,w
movwf dip8_init ;load the 'comparison' dips register
call load_temps_c
;Find the maximum current level
call set_current_reg_c
;see if in shutdown
btfsc current,0
goto shutdown_g ;bit 0 of 'current' register was set, so in shutdown
;see if in overtemp....load overtemp_flags (eight of them)
call load_overtemp_flags_c
goto step_stone_g
step_stone_g
;Find whether need internal or external mode.
btfss modebit
goto EXTMODE_g
goto INTMODE_g
;Load the maximum temperature registers
EXTMODE_g ;EEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEE
ext1
nop
goto ext1
INTMODE_g ;IIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIII
int1
call zero_mcp4013_c ;zero the mcp4013 (zero volts out)
call set_mcp4013_c ;Set the led driver current with MCP4013
int2 ;have the dipswitchs been changed?...
read_dips_m
movf dip8,w
bcf STATUS,Z
xorwf dip8_init,w
btfss STATUS,Z ;skip if the registers are the same
goto dipchange_int_g ;dips changed in internal mode
;check temperature too hot
;Read temperture LED1.
movlw 0x10
movwf ADCON0 ;Select AN4 for therm CH1
movlw 0x11
movwf ADCON0 ;Enable ADC
bsf ADCON0,1 ;start ADC conversion
int3
btfsc ADCON0,1 ;check for ADC done
goto int3
;IIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIII
goto int2
goto begin
; ***** END OF MAIN LOOP *******
; FUNCTIONS FUNCTIONS FUNCTIONS FUNCTIONS
;????????????????????????????????????????????????????????????????vvvvv
dipchange_int_g ;what to do if dips changed in int mode^.NOT A CALLED FUNCTION
;check if temp has changed
movlw 0x10 ;mask to isolate the temp bit (others made zero)
andwf dip8_init,w
movwf dip8_init_therm ;just the therm bit
movlw 0x10
andwf dip8,w
movwf dip8_therm ;just the therm bit
movf dip8_therm,w
bcf STATUS,Z
xorwf dip8_init_therm,w ;now check if they are the same
btfss STATUS,Z
call load_temps_c
;check if MODE has changed
movlw 0x01 ;mask to isolate the MODE bit (others zeroed)
andwf dip8_init,w
movwf dip8_init_mode
movlw 0x01
andwf dip8,w
movwf dip8_mode
movf dip8_mode,w
bcf STATUS,Z
xorwf dip8_init_mode,w
btfss STATUS,Z
goto mode_change_g ;change of mode
;CHECK If current has changed
movlw 0x06 ;mask to isolate the MODE bit (others zeroed)
andwf dip8_init,w
movwf dip8_init_current
movlw 0x06
andwf dip8,w
movwf dip8_current
movf dip8_current,w
bcf STATUS,Z
xorwf dip8_init_current,w
btfss STATUS,Z
goto current_change_g
set_current_reg_c
clrf current ;clear current reg prior to loading
btfsc MSBbit
call a0_or_a1_c ;set relevant bit in 'çurrent' register
btfss MSBbit
call a2_or_a3_c ;set relevant bit in 'çurrent' register
;Load the iset_mcp4013 level register with relevant no of pulses
btfsc current,1
call a1p76_c ;1.76A = 33 PULSES to mcp4013
btfsc current,2 ;2.64A = 47 PULSES to mcp4013
call a2p64_c
btfsc current,3 ;3.52A = 61 pulses to mcp4013
call a3p52_c
retlw 0x00
;reset dip8_init to what it is now
dipchange_ext_g ;what to do if dips changed in ext mode
load_temps_c
;Load the maximum temperatures (either 80C or 90C)
movf led_80C,w
movwf max_led_temp
btfss t80t90bit
movf led_90C,w
movwf max_led_temp ;max led temp loaded
movf board_80C,w
movwf max_pcb_temp
btfss t80t90bit
movf board_90C,w
movwf max_pcb_temp ;MAX pcb temp loaded
retlw 0x00
current_change_g
mode_change_g ;
read_dips_m
movf dip8,w
movwf dip8_init
btfss modebit
goto EXTMODE_g
goto INTMODE_g
; **** LOAD THE CURRENT REGISTER LOWER 4 BITS ****
a0_or_a1_c ;Find out if its 0a or 1a
btfsc LSBbit
bsf current,0 ;indicate 0 amps set
btfss LSBbit
bsf current,1 ;indicate 1.76 amps set
retlw 0x00
a2_or_a3_c ;Find out if its 2a or 3a
btfss LSBbit
bsf current,3 ;indicate 3.52 amps set
btfsc LSBbit
bsf current,2 ;indicate 2.64 amps set
retlw 0x00
;xxxxxx Load set current level ((no of pulses to mcp4013) xxxxxxxxxxxx
shutdown_g ;MSB and LSB bits were 0,0
bcf ch1bit
bcf ch2bit
bcf ch3bit
read_dips_m ;check to see if MSB,LSB not give zero current
movf dip8,w
bcf STATUS,Z
andwf 06,w
btfsc STATUS,Z
goto shutdown_g ;result was zero, so its still in shutdown
goto begin
goto begin
a1p76_c ;MSBbit = 1, LSBbit = 0
movlw 0x21 ;33 pulses for 1A76
movwf iset_mcp4013
retlw 0x00
a2p64_c ;MSBbit = 0, LSBbit = 1
movlw 0x2F ;47 pulses for 2A64
movwf iset_mcp4013
retlw 0x00
a3p52_c
movlw 0x3D ;61 pulses for 3A52
movwf iset_mcp4013
retlw 0x00
zero_mcp4013_c ;xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
bsf mcp4013_csbit ;disable mcp4013
bcf mcp4013_udbit ;prep for decrement
movlw 0x42 ;enough to decrement to zero volts
movwf count ;
call delay_1ms
bcf mcp4013_csbit ;enable mcp4013
mcp1
bsf mcp4013_udbit ;do a decrement
nop
bcf mcp4013_udbit
nop
decfsz count,1
goto mcp1
bsf mcp4013_udbit ;disbale change of mcp4013
retlw 0x00
;xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
set_mcp4013_c ;xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
movf iset_mcp4013,w
movwf iset_mcp4013_A
bsf mcp4013_udbit ;prep for increment
call delay_1ms
call delay_1ms
set1
bcf mcp4013_udbit
nop
bsf mcp4013_udbit
nop
decfsz iset_mcp4013_A,f
goto set1
bsf mcp4013_csbit ;disable change of mcp4013
call delay_1ms
retlw 0x00
;TTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTT
clrf overtemp_flags
movlw 0x10 ;Read temperture LED1 (AN4).
movlw 0x11
bsf ADCON0,GO/DONE ;start ADC conversion
tem1
btfsc ADCON0,GO/DONE ;check for ADC done
goto tem1
ana_to_8bit_m ;put ADRESH in ana8
movf ana8,w
bcf STATUS,C
subwf max_led_temp,w
btfsc STATUS,C
bsf overtemp_flags,0 ;ch1 led = overtemp
;SEE IF CH1 OPEN THERMISTOR...
movf ledtherm_open,w
bcf STATUS,C
subwf ana8,w
btfsc STATUS,C
bsf overtemp_flags,1 ;ch1 led = open therm
movlw 0x28 ;Read temperture LED2 (AN10).
movwf ADCON0 ;Select AN10 for therm CH2
movlw 0x29
tem2
goto tem2
movf ana8,w
bcf STATUS,C
btfsc STATUS,C
bsf overtemp_flags,2 ;ch2 led = overtemp
bcf STATUS,C
subwf ana8,w
btfsc STATUS,C
bsf overtemp_flags,3 ;ch2 led = open therm
movlw 0x2C ;Read temperture LED3 (AN11).
movwf ADCON0 ;Select AN11 for therm CH3
movlw 0x2D
tem3
goto tem3
movf ana8,w
bcf STATUS,C
btfsc STATUS,C
bsf overtemp_flags,4 ;ch3 led = overtemp
bcf STATUS,C
subwf ana8,w
btfsc STATUS,C
bsf overtemp_flags,5 ;ch3 led = open therm
movlw 0x1C ;Read temperture PCB (AN7).
movwf ADCON0 ;Select AN7 for therm PCB
movlw 0x1D
tem4
goto tem4
movf ana8,w
bcf STATUS,C
subwf max_pcb_temp,w
btfsc STATUS,C
bsf overtemp_flags,6 ;PCB = overtemp
movf pcbtherm_open,w
bcf STATUS,C
subwf ana8,w
btfsc STATUS,C
bsf overtemp_flags,7 ;PCB = open therm
retlw 0x00 ;overtemp_flags now tell all!
; xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
delay_1ms
movlw 0x05
movwf del1
b1
movlw 0xFF
movwf del2
a1
decfsz del2,f
goto a1
decfsz del1,f
goto b1
retlw 0x00
delay_10ms
movlw 0x0A
movwf del1
b10
movlw 0xFF
movwf del2
a10
decfsz del2,f
goto a10
decfsz del1,f
goto b10
retlw 0x00
delay_ms
movlw 0xFF
movwf del1
zzz
movlw 0xFF
movwf del2
yyy
decfsz del2,f
goto yyy
decfsz del1,f
goto zzz
retlw 0x00
end
