    Dismiss Notice
Formatting issue with number
Discussion in 'Oshonsoft' started by jnilo, Mar 18, 2015.
  1. jnilo
    jnilo New Member
    Mar 15, 2015
    9
    0
    I have two numbers that can vary between 1 and 22. Whenever any of the two is comprised between 1 and 9 I would like to pad them with a zero e.g.
    01/22 or 01/09 so that my result is always displayed at the same place. I cannot find a num to char conversion function. Any trick to suggest ? (I could have four different lcdout statements according to the different values of my two numbers but it seems a bit cumbersome...)
    Jacques
  2. Ian Rogers
    Ian Rogers Super Moderator Most Helpful Member
    Mar 28, 2011
    9,145
    907
    Rochdale UK
    Oshonsoft doesn't cover any formatting of that nature... You need your own integer to ASCII routine ..
    Its dead simple..
    Assume the number is always 4 digits long ( if not you will have to adjust )
    What you are looking for is right align!!
    Here is mine
    Code (basic):
    Sub PrintNumb( value as word)
        dim temp as word
        temp = value / 1000
        Lcdout #temp
        temp = ( value /  100 ) MOD 10
        Lcdout #temp
        temp = (value / 10 ) MOD 10
        Lcdout #temp
        temp =  value  MOD 10
        Lcdout #temp
    End Sub
    I haven't tested this... Its just so you get the idea!!
    • Like Like x 1
  3. jnilo
    jnilo New Member
    Mar 15, 2015
    9
    0
    Nice trick ! The correct code for oshonsoft using sub is:
    Code (basic):
    printnumb:
      Dim temp As word
      temp = value / 1000
      Lcdout #temp
      temp = (value / 100) Mod 10
      Lcdout #temp
      temp = (ii / 10) Mod 10
      Lcdout #temp
      temp = ii Mod 10
      Lcdout #temp
    Return
    Thanks !
    Jacques
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. Ian Rogers
    Mar 28, 2011
    9,145
    907
    Rochdale UK
    Sorry! I have the addin for structured programming... I can use Sub's and Functions in Oshonsoft..
    Using Sub allows you to pass a variable rather than have it global!!!
  6. ericgibbs
    ericgibbs Well-Known Member Most Helpful Member
    Jan 4, 2007
    21,174
    644
    Ex Yorks' Hants UK
    Look under Oshonsoft snippets
    http://www.electro-tech-online.com/threads/code-snippets-for-the-oshonsoft-basic-compiler.112540/
    Code (text):
    Dim ascbfr3 As Byte  'used in convert routing
    Dim ascbfr2 As Byte  'used in convert routing
    Dim ascbfr1 As Byte  'used in convert routine
    Dim ascbfr0 As Byte  'used in convert routine
    binval = volts
    Gosub bin2asc
    bin2asc:
    ascbfr3 = binval / 1000
    temp3 = binval Mod 1000
    ascbfr2 = temp3 / 100
    temp3 = temp3 Mod 100
    ascbfr1 = temp3 / 10
    ascbfr0 = temp3 Mod 10
    'results are BCD so
    'convert to ASCII for LCD
    ascbfr3 = ascbfr3 Or 0x30
    ascbfr2 = ascbfr2 Or 0x30
    ascbfr1 = ascbfr1 Or 0x30
    ascbfr0 = ascbfr0 Or 0
    ' and to show on a lcd after it is set up
    Lcdout "Volts:", ascbfr3, ascbfr2, ".", ascbfr1, ascbfr0
    'this will put a decimal point in and the example shows a voltage reading to 2 decimal places
    • Like Like x 1
  7. jnilo
    jnilo New Member
    Mar 15, 2015
    9
    0
    Ian, Eric: thanks to both of you. In my case the following code works perfectly, j1 and j2 being the two bytes variables comprised between 1 and 22. It seems that I do not need the or x 30 mask. All variables are declared as bytes.
    Jacques
Share This Page
